Author Topic: 1973 V7 Sport Cylinder Relining Millennium  (Read 106427 times)
Re: 1973 V7 Sport Cylinder Relining Millennium
« Reply #270 on: February 04, 2023, 12:15:07 PM »
:laugh: :laugh: My reaction as well... but figured if someone here had found one previously buy might have a lead. Custom ones can be made but so far only in bulk.
Thanks though and have an amazing day!
Have you tried contacting "motomatt" on the other forum I sent you a link to? Maybe he can ask the machine shop he used where they got the sleeve they installed.
Offline Richiez22908
« Reply #271 on: February 04, 2023, 12:39:21 PM »
Nope. Let me dig into that email and get it. Thanks again!!
« Reply #272 on: February 04, 2023, 01:23:01 PM »
Yup... answer was there. They ground it down to fit within the closest of the available sleeves... 2.063. The .01(times two) sleeve thickness brought it back up to spec at 2.083. Mine measures at 2.085 right now with my fumbly hands. So looks like it'll work!
https://www.skf.com/us/products/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve/productid-99205
Thank you again Charlie!! And I went ahead and donated over there since I got the information I needed. Also will peruse that thread and site for other pertinent tidbits.
« Last Edit: February 04, 2023, 01:24:08 PM by Richiez22908 »
Online Frenchfrog
« Reply #273 on: February 04, 2023, 02:08:08 PM »
Great info...thanks to both of you
Offline MattP
« Reply #274 on: February 05, 2023, 02:05:12 PM »
look why don,t you use a good stock 850 t t3 1000 crank and just make shims for under the clinders save about a thou vasiline up the v7 sport crank and save it everything will bolt togeather I did this abuut 50 years ago also instaled 1000 pistons nobody  would know the difference except the guy who wacked the throttle.
« Reply #275 on: February 06, 2023, 02:15:56 PM »
Great idea... but trying to stay as stock as possible.
Thanks!
« Reply #276 on: February 06, 2023, 04:58:51 PM »
I would just have a crank grinder take off a few thousandths, maybe 2 or 3. The seal will still fit plenty tight.
Offline matt franklin
« Reply #277 on: February 06, 2023, 08:40:35 PM »
Glad I could be of service!
Matt
« Reply #278 on: February 06, 2023, 09:06:30 PM »
Forgot to add:  buy SKF speedi-sleeve from Rock auto and save some dough.  SKF p/n 99205.
Matt
« Reply #279 on: February 07, 2023, 05:30:48 AM »
Matt
Thanks Matt! Yeah grabbed two(just in case, lol) off eBay of about $33 each.
« Reply #280 on: February 07, 2023, 06:54:09 AM »
Thanks Charlie. I'll bring it all to the crank specialist, including the seal, and see what he thinks will be the best approach. This seems like the least(lol, edit) intrusive option so, if the sleeve becomes unnecessary, that would be great!
« Last Edit: February 07, 2023, 09:28:49 AM by Richiez22908 »
Offline Scout63
« Reply #281 on: February 21, 2023, 09:51:01 PM »
Thread bump and realignment - I got my v7 Sport cylinders back from Millenium today.  They look fantastic.  Who says beauty isn’t on the inside? I like the idea of keeping the original cylinders. It was just over $600.00 with shipping, so still less than a pair of Gilardonis.
Ben Zehnder - Orleans, MA USA
« Reply #282 on: February 28, 2023, 07:45:21 AM »
Beeeuutiful! Yeah mine too... like new! They do good work!
« Reply #283 on: April 09, 2023, 06:35:34 PM »
So sorry for the lack of posts! There's been progress, although not nearly as much as there should have been.
I was concerned about the crankshaft where the seal rides... there was some pitting and a history of leaks, so after some research and deliberation I had it cleaned up. Ended up only needing about a thousandth off, so didn't need any sleeve.
I have two SKF Speedi-Sleeves if anyone needs them.
Also turned out the crank at the front main and at the rods needed to be takin down to 1st under. So got all that done, and back and installed.
« Last Edit: April 13, 2023, 06:58:58 AM by Richiez22908 »
« Reply #284 on: May 01, 2023, 06:49:38 PM »
Oil pump, etc installed. Gears on but not mounted. Unfortunately my cam gear does not have the two painted teeth... only one tiny spotch or paint on one tooth. I lined it up exactly as it was, and then turned it to match an image from Charlie and the one tooth does end up where one of the painted teeth should be. So likely it's ok but will check once the head and valves are on to be absolutely sure.
« Reply #285 on: November 03, 2025, 09:05:43 AM »
Hi all!
I wanted to return to this thread and provide an update... a bit of catharsis I guess.
So with a TON of help from Charlie and Greg I managed to get it all back together. Unfortunately, due to my own mistakes, it was not running well.
I have since, I believe, determined and rectified the issues... along with buying some addional NOS replacement parts...  and am going to give either another shot.
What I had intended to ride and enjoy has become a years long project. I am grateful to those that have provided feedback and info... even if the info was not graciously accepted at the time(So sorry). I will get this wonderful bike back win its feet. In the meantime, since its riding season in South Florida, I am buying another bike to ride until I can get this one sorted.
Thank you again all so much and I will provide more updates.
