Lights Out
Topic: Lights Out (Read 2182 times)
nsmith
Gaggle Mentor
Lights Out
June 28, 2022, 08:34:10 AM »
1986 V65 Lario
Lights quit working, park lights still work, pass light still works but (lights on) does nothing.
A wiring diagram would be very helpful right about now.
Thanks.
Neil formally from South Dakota now living it up in Arkansas
cowtownchemist
Hatchling
Re: Lights Out
Reply #1 on:
June 28, 2022, 08:39:28 AM »
Have you checked the fuses yet? I had the opposite happen. Headlight worked but passing/bright lights did not. Ended up being a 10amp fuse which was blown.
2014 V7 Stone
2000 V11 Sport
Antietam Classic Cycle
Happily stuck in the past.
Re: Lights Out
Reply #2 on:
June 28, 2022, 08:41:55 AM »
Quote from: nsmith on June 28, 2022, 08:34:10 AM
There's one listed here:
https://www.thisoldtractor.com/guzzi007/sportissimo.html
nsmith
Gaggle Mentor
Re: Lights Out
Reply #3 on:
June 28, 2022, 10:19:58 AM »
Thanks but yes I just checked and all fuses are good.
Kiwi_Roy
Re: Lights Out
Reply #4 on:
June 28, 2022, 12:00:30 PM »
The Lario has a 4 way Molex connector (16) just under the tank, this was a constant cause of problems on the one I had, just cut out for no reason, I tried replacing the components but eventually just crimped a butt splice in parallel to the connector, no more problems.
Guzzistajohn
Re: Lights Out
Reply #5 on:
June 28, 2022, 02:58:34 PM »
My '80 CX needs it's fuses pulled and cleaned every few years. Rubbing on a pair of blue jeans usually get's things sparking again.
nsmith
Gaggle Mentor
Re: Lights Out
Reply #6 on:
June 28, 2022, 03:28:54 PM »
Ok, the problem is in the switch itself, I can jump the switch and everything works great. Now we all know how cheap we can be, I don't know it this is even available but I Doubt it. I'm gonna have to try something, Driving w/o lights at night is a real bitch.
Re: Lights Out
Reply #7 on:
June 28, 2022, 03:35:22 PM »
Yeah....Bambi and her friends.
Clean the switch contacts and/or look for a replacement. Some of the stuff on Amazon will work. There are switches in there.
Last Edit: June 30, 2022, 02:29:16 PM by Tom
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
nsmith
Gaggle Mentor
Re: Lights Out
Reply #8 on:
June 30, 2022, 11:06:22 AM »
One of the solderless connections at the switch had worked its way loose, A touch of solder seems to have thing righted once again. Thanks for most of your advice.
Re: Lights Out
Reply #9 on:
June 30, 2022, 02:29:32 PM »
Lights Out
