Author Topic: Does anyone know why my bike is doing this?  (Read 9912 times)
Re: Does anyone know why my bike is doing this?
« Reply #60 on: July 20, 2022, 03:12:09 PM »
Just give me 1 minute of your lives, watch this and listen to what it does @ the 20 second mark..
https://youtu.be/Li8qvFVuAJ8
Is our OP’s bike the same ?
It then settles into a perfect idle..(and it’s not as loud as it sounds on video).
« Reply #61 on: July 20, 2022, 03:19:02 PM »
OP will have to answer for himself (though I think his video sounds very similar).
I'll say YES, that sounds almost identical to what my 2013 does on most cold starts (and that my 2018 has NEVER done).
Follow up question - if you attempt to ride away when it's doing that, what happens?
« Last Edit: July 20, 2022, 03:19:36 PM by Kev m »
« Reply #62 on: July 20, 2022, 03:22:09 PM »
Ummm, I don’t know Kev but next time I can I will.
I can tell you that a blip on the throttle will override the symptom as it’s occurring.
« Reply #63 on: July 20, 2022, 05:46:11 PM »
When this occurs on mine you can try to throttle out of it, but the second you slip the clutch and apply any load it will die.
« Reply #64 on: July 20, 2022, 06:13:08 PM »
Ok.
By the time I’ve put my gloves on and closed the garage door, it’s perfect.
« Reply #65 on: July 20, 2022, 08:48:21 PM »
Ok.
Could be similar.... I've got gravel so I have not done that and I'm seated by the time I start it.  :boozing:
« Last Edit: July 21, 2022, 05:40:58 AM by Kev m »
Offline lucky phil
« Reply #66 on: July 21, 2022, 01:17:09 AM »
I'll tell you what that is, it's caused by fuel puddling in the inlet manifolds with a rich start mixture and a cold engine. So the fuel puddles and periodically the engine sucks it in and goes rich and stumbles. Once the engine gets some temp into it and the manifolds heat up and the fuel stops puddling and the cold engine and start trim leans out a little they settle down. Giving the throttle a quick twist to keep it going just adds fuel and doesn't help. My V10 Sport does it as well and having the high idle lever set at a slightly higher rpm helps until it's warmed up a little.
Phil
« Last Edit: July 21, 2022, 02:33:29 AM by lucky phil »
Offline tris
« Reply #67 on: July 21, 2022, 02:30:31 AM »
Sounds like my V9.
Start bike and lid and gloves on all good
1993 TW125 "POS" - Resting
« Reply #68 on: July 21, 2022, 05:22:11 AM »
Phil
Thanks for that Phil.
I didn’t know what it was.
« Reply #69 on: July 21, 2022, 05:42:33 AM »
Phil
 :thumb: that makes sense...
