Author Topic: Rust removal with acid  (Read 5668 times)
« on: July 02, 2022, 11:01:23 AM »
I am helping a friend get a 1975 GoldWing back on the road after a very long slumber. One of the side jobs is making the bike a bit more presentable, removing the rust bloom from non painted parts. The GoldWing muffler is a huge one piece unit with bolt on flashes of chrome each side, underneath its black painted steel.
After warming the bike up we mixed muriatic acid 1:1 with water and using a small trim paint brush soaked the hot muffler with the solution. In minutes the acid dissolved a very thick coating of rust. It is amazing to see how fast the acid combined with heat cleans the old muffler to shiny steel.
Finish with header paint and looks great.
Brushing the solution on the frame will not damage paint but is gets the rust off quick so that a brush on coat of Por-15 satin black can freshen the frame.
Try and keep the acid off chrome for any length of time as it can discolour the chrome.
Works great on rusty fasteners as well, just brush clear coat over the bolts and nuts once the acid has done its work.
Make sure to do this outside in a well ventilated area and wear rubber gloves. Keep a hose near by to neutralize the acid .
Offline moto-uno
Re: Rust removal with acid
« Reply #1 on: July 02, 2022, 02:36:35 PM »
  Probably my favourite method to de-rust parts , would add goggles as a necessary protection  :thumb: . Peter
« Reply #2 on: July 02, 2022, 07:26:29 PM »
Probably best to neutralize the acid with a base solution then wash and add protective coating.
Any before, during and after pics?
sorry I didn't even think of taking some pictures while I was cleaning the frame and muffler.
we washed the frame and muffler down with a soapy power washer and then rinsed and dried.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #3 on: July 02, 2022, 08:30:11 PM »
Excellent idea.  I think this would be a great way to touch up a motorcycle frame I have.  I don't want to do a complete tear down just to freshen up a few spots on the frame and engine.  Localized clean up with acid never occurred to me.
I thought that satin black paint would be a good match for the original gloss black paint that is 40 years old and no longer shiny.
Thanks.
2019 Beta EVO 250
Offline SIR REAL ED
« Reply #4 on: July 02, 2022, 08:46:23 PM »
Hey Canuck,
I don't see a satin black paint on POR-15's web site.  Is chassis black a satin finish?  Thanks.
2019 Beta EVO 250
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #5 on: July 02, 2022, 08:48:53 PM »
I remember looking into the muriatic acid/ hydrochloric acid idea for chrome and stainless steel pipes once or thrice. While the results of many a pipe I’ve seen look absolutely magical, there were lots of folks needing caution or straight up advising against using the acid, as over time it eats into the metal regardless of how fast you think you got it off. It was enough to scare me away, but maybe one day I’ll give it a go on these stainless aftermarket pipes.
« Last Edit: July 02, 2022, 08:49:21 PM by Dirk_S »
« Reply #6 on: July 02, 2022, 08:52:28 PM »
POR-15 in a can will brush on very easily, it flows to a near flat surface if you use a good quality trim brush, I just buy a good quality, very small brush from Home Depot. The spray cans are good quality but you need to mask carefully, this stuff is very hard to get off of any surface including your skin! Lacquer thinner will clean up spills or drips.
POR-15 is not UV resistant without a clear top coat but for frames I don't bother with a top coat. The gloss black is very shiny and I don't think its a good match for most frames.
A pretty tired looking Laverda frame, I ran 220 grit dry paper over the rough original paint, acid washed the frame, neutralized it and brush painted POR-15, I did a LOT of masking but I did not disassembled the whole bike, motor stayed in the frame.
I removed what was practical and powder coated the center and side stands, fork lowers, foot rest brackets, swing arm and misc parts that were easy to remove.
I did this to see if POR-15 was practical to do as opposed to Powder coating, truth be told I only went this route on one restoration but it was satisfactory
painted frame
one the body work is back on, the eye doesn't pay much attention to a frame provided its not chipped and rusty, plus so little of the frame is visible
« Last Edit: July 02, 2022, 08:58:09 PM by Canuck750 »
« Reply #7 on: July 02, 2022, 08:55:55 PM »
Hey Canuck,
Yes, 'Chassis Black' Direct to Metal Top Coat is what I usually use.
« Reply #8 on: July 02, 2022, 09:00:04 PM »
I would stay away from trying to clean chrome plating with acid, and acid will remove a zinc coating very quickly. I think the acid should be restricted to carbon steel oxide.
« Last Edit: July 02, 2022, 11:18:23 PM by Canuck750 »
Offline Scout63
« Reply #9 on: July 02, 2022, 09:42:30 PM »
Great thread.
Ben Zehnder - Orleans, MA USA
Offline SIR REAL ED
« Reply #10 on: July 03, 2022, 08:09:56 AM »
Mucho thanks Sensei!
2019 Beta EVO 250
« Reply #11 on: July 03, 2022, 08:19:28 AM »
For rust on chrome plating.. aluminum foil and water. Trust me on this one, it doesn't sound as if it would do anything.
Offline SIR REAL ED
« Reply #12 on: July 03, 2022, 08:24:04 AM »
Have you tried using any of their engine paint in a brush on mode on a motorcycle engine?
2019 Beta EVO 250
Offline yogidozer
« Reply #13 on: July 03, 2022, 08:30:31 AM »
Acid never helped Ozzy  :shocked:
« Reply #14 on: July 03, 2022, 10:18:02 AM »
I have not, but I bet it is a very good if it’s anything like the chassis paint.
Thanks Clint, I agree that motorcycle alloy parts were never finished to a fine mirror shine, the side covers I poslihed are probably shinier than they ever left the Pessaro factory.
« Last Edit: July 03, 2022, 01:59:07 PM by Canuck750 »
Offline sign216
« Reply #15 on: July 05, 2022, 07:21:17 AM »
A more effective version is bronze wool.  They have it for ships in hardware stores near the coast.
Bronze is harder than aluminum.  Not as hard as steel wool, but the metal traces it leaves behind won't rust, like steel will.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
