Author Topic: Whatcha Workin' On ?  (Read 12253 times)
kballowe
« on: July 03, 2022, 07:20:05 AM »
This is a 2004 Honda VTX1300 that needs a complete "once-over"
Of course, the carb needed a bit of attention.
The wheel bearings were good, but there was heavy pitting on the wheels.
It was 100 grit sandpaper to start and a fair amount of time sanding with progressively finer grit and then a polish.
How about a little "spin polish" ?    :boozing:
Stay tuned.
« Last Edit: July 03, 2022, 07:24:37 AM by kballowe »
Offline guzziart
Re: Whatcha Workin' On ?
« Reply #1 on: July 03, 2022, 07:42:24 AM »
Been there, done that for a friend several years ago.
Good luck with yours!
« Reply #2 on: July 03, 2022, 08:20:17 AM »
 :smiley:
« Last Edit: July 03, 2022, 08:21:47 AM by Chuck in Indiana »
Offline acogoff
« Reply #3 on: July 03, 2022, 08:34:22 AM »
    Darned Boxelder, or was it I parked in the wrong place?
Marshall County Minnesota USA
Online cliffrod
« Reply #4 on: July 03, 2022, 08:41:03 AM »
Working on this CX here.  Nothing huge, but lots of little things needing address.
Got some great parts from Ben/Scout63 (thanks, man!!) so my bike now has correct rear turn signals, a tool tray and more installed and waiting.  Many new rubber bits have been installed with more pending, new throttle cables with 90 degree adapters added, went through the handlebar switches, new bushes installed in brake & gearshift pedals, tires & another new battery (sold the new battery I had with my 90 Evo FLHTC...) are coming, rebuilding both master cylinders planned for later this afternoon, ….
« Reply #5 on: July 03, 2022, 08:46:02 AM »
You guys are talented.  I'm working on a nice bottle of 15 year old Bourbon and holiday lunch for the fam.
Cheers!
Online cliffrod
« Reply #6 on: July 03, 2022, 08:54:12 AM »
Online Ncdan
« Reply #7 on: July 03, 2022, 09:07:25 AM »
I’ve been lowering the bridge height a couple thousand’s at a time to lower the strings.
It takes a while due to having to remove the strings before each adjustment.
« Last Edit: July 03, 2022, 05:15:18 PM by Ncdan »
Offline mechanicsavant
« Reply #8 on: July 03, 2022, 09:47:28 AM »
At 6K Mi. I’ve finaly had it with the OEM Dunlop bias ply tires on my V7/850 ! I bought a pair of Continental R A 3’s a month or two ago . Sooo , that’s this long weekend project . As of this post rear is almost did . Relatively easy , taking my time , I hate having to rush a first time gig . I should have the front done by cocktail time , if not there’s manyana. I’ll try to get a ride report out , biggest improvement to Ride & handling on my MkII was tires . Coffee break over back to work
Offline lucian
« Reply #9 on: July 03, 2022, 10:04:20 AM »
Copper thru pan flashing for a chimney tear down
Offline Gusable
« Reply #10 on: July 03, 2022, 12:47:02 PM »
Trying to fab up a horn bracket for my bike.  I don’t know why mine is missing.  Someone put the horns on the side of the headlamp instead.  Bracket looks simple enough to make.  Used bracket with horns is on eBay for like 50 bucks but I’m cheap! Lol
Turned out pretty good I’m happy with it
« Last Edit: July 03, 2022, 04:58:05 PM by Gusable »
1994 California 1100
Offline Texas Turnip
« Reply #11 on: July 03, 2022, 01:02:23 PM »
Finishing off a few boxes of cigars so my friends can make guitars out of the boxes. So many talents that amaze me.
Tex
Online AJ Huff
« Reply #12 on: July 03, 2022, 01:25:08 PM »
Potato salad for the 4th. LOL
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
« Reply #13 on: July 03, 2022, 04:07:16 PM »
Nice work, post a finish photo.
Offline bobrebos1
« Reply #14 on: July 03, 2022, 04:47:21 PM »
Nothing exciting.  Cutting 5 acres of grass, burning brush. Changing oil and rear gear lube on my Gold Wing and organizing the basement!
Sober, Retired Air Force!
Online fotoguzzi
« Reply #15 on: July 03, 2022, 05:04:16 PM »
Offline guzzista
« Reply #16 on: July 03, 2022, 05:18:08 PM »
1970 Triumph TR6
Complete suspension  and steering overhaul, as well as brakes and cooling system.  Almost done
Offline leroysch
« Reply #17 on: July 03, 2022, 06:06:34 PM »
Putting an aftermarket slip-on muffler on the Pan American...but access to all the fasteners holding the stock stuff that needs removal is hampered by the RH side rider foot peg bracket assy...whose removal requires taking off among other things the center stand. Now I know a contributing factor to the effort getting this thing up on the center stand...compared to the Kawasaki.
On the bright side..haven't encountered any of those plastic rivet things...yet.
'88 FLST
'95 Ducati 916
'04 V11 LeMans
'06 FLHX
'17 BMW R Nine T
'19 H2 SX SE+
'22 Pan American
'24 Pan American CVO
Offline SmithSwede
  • I don't want a pickle
« Reply #18 on: July 03, 2022, 06:55:00 PM »
Well, I think Chuck wins on brevity and apparent coolness factor.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #19 on: July 03, 2022, 06:55:11 PM »
Cheers!
I think of you every time..
image to url
« Reply #20 on: July 03, 2022, 06:59:50 PM »
Yeah..
Aircraft builders/restorers are another level, but they say the same about Beetle types and they say the same about wheel builders and they say the same about Law Professors and they say…………etc.
There’s at least one of everything here.
But yes, I’ve crossed paths with these types and I’m always amazed. They’re the sort that could build a piano… :bow:
Offline lucian
« Reply #21 on: July 03, 2022, 07:25:39 PM »
 I'm with you SS. Chuck is a hard act to follow, good thing is, it's guys like him that raise the bar of what's possible for all of us.  I built an airplane once, it was a cox , I flew it in a circle until I got dizzy and fell down and it crashed into the neighbors fence. Glad it was not as series as an endeavor as Chucks projects. If WG ever considers a Hall of fame Chuck has my nomination.
 :bow:
Offline Moparnut72
« Reply #22 on: July 03, 2022, 08:01:49 PM »
After I retired I got a job with a very small business overhauling radial aircraft engines. The owner was restoring a Curtis Robin airplane. Everything had to be absolutely perfect. I don't even have any ideas how many hours he had in machining a new bowl for a fuel valve. I knew he would never finish this project. Unfortunately he didn't,  he is now in a long term care facility suffering from Parkinson's disease. My wife is one of his health care people.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline knockerjoe
« Reply #23 on: July 03, 2022, 08:08:51 PM »
i thirst lyrics
I was searching for a V7iii but I came across this W650. It was sitting awhile so the carbs are now off for a cleaning
among the other usual maintenance to get her properly sorted out.
Offline Scout63
« Reply #24 on: July 03, 2022, 09:50:28 PM »
We spent the day at home hiding from tourists.  I refit the G5 bag brackets after a rear drive overhaul, solved the SR leaking carb (a few good taps with a screwdriver handle), and reinstalled the pump levers in the Ducati carbs.  Then I grilled shrimp and lamb chops for dinner.  Finally I tried to fix a fishing reel for tomorrow’s early trip and dropped all the parts on the floor. Happy Fourth to everyone.
Ben Zehnder - Orleans, MA USA
kballowe
« Reply #25 on: July 04, 2022, 06:32:43 AM »
The UPS driver was probably scratching his head on this delivery.  And maybe cursing me a little.
 :boozing:
The temps for the upcoming week are forecasted to 100+ , so it'll be nice to be working in the basement in the AC.
« Last Edit: July 04, 2022, 06:34:26 AM by kballowe »
« Reply #26 on: July 04, 2022, 07:26:08 AM »
No pics yeat but I just bought a heap of a truck- 1992 Dodge 250 Turbo Diesel...  Strong runner but needs many bits-and-bobs to pass inspection and drive safely...  Soon as I get a tag on it will be heading to the Asheville Tool Library to check out some scaffolding so I can take down my listing & leaning (out of service) chimney.
Offline Stretch
« Reply #27 on: July 04, 2022, 09:55:59 AM »
Lots.
Oil change on the Triumph Trophy SE. Just got back from a 10-day trip from Maine to North
Carolina and back.
Finishing fixing electrical woes on the BMW K75S. Then we have to change all of the fluids,
check the valves and replace the plugs.
Cali 1400 needs a valve adjustment, plugs, oil change, and new tires in 500 miles.
Rocket III needs a valve adjustment at some point.
And all of the above conspired to require new batteries this month......I swear they
talk to each other in the night.
SR500 needs a new oil check valve. I ought to upgrade the oil pump and lines while I'm at it......
I was gonna do this job this past winter, but the dreaded supply chain issue reared
it's ugly head.
And all of the usual work around the house, gardening, wood cutting and splitting, etc..
                                                           -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline chuck peterson
« Reply #28 on: July 04, 2022, 12:09:05 PM »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #29 on: July 04, 2022, 02:31:01 PM »
Tires update . Got them on with the help of my H F m/c tire changer . Not scratching the rims has been a challenge so after some trial & error on previous jobs decided to try wrapping the irons w/cowhide worked great ! Rode about 90 Mi. To scuff them in . WOW , like I rollerskated onto a cork floor . All the small irregularities & jarring , gone . Way smoother. In the last 20 Mi. I gained enough confidence to drag the pegs on both sides ! Nuff said.
