Gas Cap Gasket.
Topic: Gas Cap Gasket. (Read 3180 times)
73 sport
Gaggle Mentor
Gas Cap Gasket.
July 05, 2022, 08:14:13 PM »
Can anyone here provide me with the dimensions of the gasket for the "Flip"type cap on the '73/'74 Sport. I've made several with varying dimensions but they still leak. Thanks in advance.
moto
Fear the deer!
Re: Gas Cap Gasket.
Reply #1 on:
July 06, 2022, 07:59:31 AM »
If it is like the cap on my T3, there is a small screw in the center of the cap as you look at it from the bottom. Adjusting this changes the pressure on the gasket. Just in case you haven't tried that.
Moto
850 T-3
Griso 1100 corretto
Italjet Buccaneer 250 (ex-SSR)
-- now sold
73 sport
Gaggle Mentor
Re: Gas Cap Gasket.
Reply #2 on:
July 06, 2022, 09:05:07 AM »
Thanks for responding Mr. Moto. I understand the center screws functions. The original rubber gasket had decayed and deformed, it could not be used for dimensional reference.
guzzista
Re: Gas Cap Gasket.
Reply #3 on:
July 06, 2022, 11:48:25 AM »
There is an early and a later size. Early has wider diameter gasket. Will take pics and measure both, post later
Last Edit: July 06, 2022, 04:07:27 PM by guzzista
guzzista
Re: Gas Cap Gasket.
Reply #4 on:
July 06, 2022, 04:15:22 PM »
2 pics
The early cap ( mine is from a 1974 850T tank) as in first pic is flattish, seals on outer edge. OD on seal is 72mm.
Later cap protrudes out and seals on the tank filler mouth , seal OD approx. 50mm. I say approx. because another same design cap on my California 1100 shows about 48mm OD on the seal/ gasket , (possibly due to age shrinking/ reaction to fuel ?
73 sport
Gaggle Mentor
Re: Gas Cap Gasket.
Reply #5 on:
July 06, 2022, 05:11:06 PM »
Thank you Guzzista. Mine is your first pix. The other dimension I need is the thickness. My problem was I made them too small, to seal on the inner neck diameter.
lazlokovacs
Re: Gas Cap Gasket.
Reply #6 on:
July 06, 2022, 05:28:19 PM »
I have the exact same problem with the same early type cap
czakky82
Re: Gas Cap Gasket.
Reply #7 on:
July 06, 2022, 05:55:35 PM »
My early cap seal looks horrible but hasn’t leaked a bit…🤷♂️
cliffrod
AC Button II
Re: Gas Cap Gasket.
Reply #8 on:
July 06, 2022, 05:56:24 PM »
The gasket on my V7 Sport (that’s been on my bike since at least 1978-79 so probably original) measured no more than 1.5mm thick a few minutes ago. If it’s old and shrunken, it would probably be no more than 2mm thick when new. It seals fine. Date on neck tag is Dec 1972 iirc, so 1973 model bike.
Given the filler neck that’s in my tank, I’m trying to understand how your cap leaks. Tank would have to be very full. Even then, I would expect the thickness of the gasket has less to do with sealing than the tension of the spring that’s in my cap as long as the gasket was actually wide enough to cover what needs to be sealed.
1973 V7 Sport "Now THAT'S a motorcycle!"- Master Sculptor Giuliano Cecchinelli
73 sport
Gaggle Mentor
Re: Gas Cap Gasket.
Reply #9 on:
July 06, 2022, 06:29:13 PM »
Cliffrod, thanks for the thickness info. As I stated above, I made them too small in diameter. The gasket seals on the outer edge of the filler neck. A long long time ago, when I rode my bike, I rode obscure back roads and ones less travelled . When I tanked, it was to the top. Now my bike is a hanger queen in my living room.
Gas Cap Gasket.
