Author Topic: Modern replacement instruments for a Loop?  (Read 1692 times)
« on: August 02, 2022, 10:33:01 PM »
Has anyone found a pair of modern replacement instruments for a Loop Eldorado? I think I am on the 3rd tachometer (recent failure a Spanish reproduction that only reads 1/2 actual rpm) and on the second speedometer.
I need an electronic tach and a mechanical speedometer to fit the original dash bezel. Not hung up on the face plates appearing stock, just want a reliable pair of gauges that work and the needles don’t flop around at speed.
Jim
Offline Kane
Re: Modern replacement instruments for a Loop?
« Reply #1 on: August 02, 2022, 11:59:34 PM »
I know that people have had success using the Speedhut gauges on MG V11s. I think the speedo is GPS or can run off a magnetic pulse switch coming off of the speedo drive or wheel. I believe they can reproduce an instrument face graphic if you provide it.
« Last Edit: August 03, 2022, 12:01:05 AM by Kane »
2001 V11 Sport
1978 850-T3
2009 Ducati 1100 Hypermotard
Offline huub
« Reply #2 on: August 03, 2022, 03:00:01 AM »
for the speedo i can recommend the GPS speedo's widely available on ebay/aliexpress
i have one on my lario and 750 ntx , they have been fine for the last 30.000 km.
they also make matching universal tachometers
« Last Edit: August 03, 2022, 06:40:05 AM by huub »
Offline ttietjen
« Reply #3 on: August 03, 2022, 05:44:44 AM »
When the tach on my Eldo quit working I went with a Drag Specialties tach from JP Cycles around $65. I think it was replacement for a 70s sportster. The dia was a little smaller so slipped it into a short piece of 3 in exhaust pipe painted black. It looks so similar to the speedo minus the eagle most people don't even notice.
« Reply #4 on: August 03, 2022, 05:56:03 AM »
I bought the big Koso Multi-function analog round one with integrated idiot lights (BA035k00 TNT-01), but that was for the civilian/single gauge dash. It would need a small trim ring fabricated or 3-d printed, as it is about 4mm small for the opening...   But I sold it with my v65 cafe project, otherwise I would post some pics
Also Canuck, If you want a single-gauge dash to make this conversion, I have one in great condition I can send you for shipping. Your contributions to to forum are legendary... Just shoot me a PM, I can send pics for your consideration
« Last Edit: August 03, 2022, 08:49:01 AM by Mayor_of_BBQ »
« Reply #5 on: August 03, 2022, 10:38:30 AM »
Thank you Mayor!!  pm sent
is this the gauge you have used?
https://fortnine.ca/en/koso-tnt-01-multi-function-meter?utm_id=14215143271&utm_campaign=pla-1433727171082&utm_source=google&utm_medium=paid&utm_content=124431327254&gclid=Cj0KCQjwuaiXBhCCARIsAKZLt3mC0ElYdTiBBLZrV0NEl-LIE4g9OmzwsWvmPi_A-emkbkkEZoUL9yEaAsQEEALw_wcB#76=8830&615=22869
I like that the bezel appears to be removable and I could then make a larger diameter bezel out of aluminum to suit, plus a tach and speedo all in one!!
« Reply #6 on: August 03, 2022, 11:51:47 AM »
Yep, That's it! I had the black face. $199 on Amazon fyi
Online bigbikerrick
« Reply #7 on: August 03, 2022, 07:02:17 PM »
I am still looking for a suitable aftermarket replacement tach to fit the civilian eldo dashboard, with 2 instruments. The speedhut ones I have adapted to my 98 EV, and my Cal II, were a little bit too big, in order to look "correct" next to the oem Veglia speedo.
Rick.
« Reply #8 on: August 03, 2022, 07:41:01 PM »
Yes Speedhut make really nice gauges, they will add a graphic if you send them the file.
I was an early user of these gauges on my VII Sport.
They will even set the odometer to match your old broken gauge.
go with the reset button that plugs into the rear, not the one installed through the glass.
I made a simple reed switch based pulse input for mine. it sat in the gearbox cable drive and pulsed twice per revolution
Once you have a pulse input then you have to calibrate the gauge, this is very simple if you can borrow a runners watch with distance readout. Just press start cover a fixed distance then press End.
Offline huub
« Reply #9 on: August 04, 2022, 02:15:13 AM »
Rick.
get the chinese GPS speedo , and get the matching rev counter
something like 120 euro for the pair ,
Online bigbikerrick
« Reply #10 on: August 04, 2022, 12:25:06 PM »
The only problem with substituting the tach in a civilian dash is the diameter of the gauge faces so they fit in the dash . It would be much easier with one of the single gauge dashboards, with the larger gauge.
Rick
