Author Topic: Traction Control  (Read 4211 times)
Offline MMRanch
  • MMRanch
Traction Control
« on: August 04, 2022, 07:56:29 PM »
Last time I had the V7II out the two yellow light came on and stayed on.
So I read in the book that came with the bike on how to reset the tire size thing and how to turn on/off the traction control.
Well none of that will work because the lights never go off .
I hooked the guzzi tec thing up to my computer and blanked out the "Faults" , and still those lights are on !   :rolleyes:
I'm thinking : Unplug those yellow light and forget them rather than throwing $$$ at the dealer so they can replace everything - one thing at a time till the get lucky and find the right part.
Anybody else ever have a problem with the traction control / anti lock brake systems ?
« Last Edit: August 04, 2022, 08:08:37 PM by MMRanch »
2016 V7-II Stone
Offline lucian
Re: Traction Control
« Reply #1 on: August 05, 2022, 06:46:23 AM »
Was there any active or stored faults in the  dash?  Two yellow lights ?, one must be abs . You may need to re calibrate the abs per directions in the manual. The prompts must be followed exactly as directed. I would check and record any faults that may return. Did you change a tire size?  It could be a wheel speed sensor , they can go bad especially if water gets in the sensor from around the wire. Sometimes a hairdryer will dry them out and they will work again,,,or not.  If one is bad it will throw a fault code . Had the same thing happen on a cali 14 and it did throw a code which led me to the rear wheel speed sensor.
Offline greer
« Reply #2 on: August 05, 2022, 08:14:59 AM »
Does the bike run and ride OK?  When a wheel sensor went out on my II it was so down on power I could hardly get it back to the house.
Sarah
Offline MMRanch
  • MMRanch
« Reply #3 on: August 05, 2022, 08:54:33 AM »
Yes one is brake , other is traction.     The normally go off and that is where the "Re-programming"   begins ,  now they never go off so there ain't no reprogramming.
Wheel sensor , how do ya check the "wheel sensor" ya think ?
Another thing (clue) , the front master cylinder locks-up some times ... but I can "over-ride" it with a heavy pull .  I thought it might have been the master cylinder going bad ?   But maybe the ABS system is not letting brake fluid flow through for some reason .   Like a valve in the control unit sticking ???
The whole affair makes me want to either trade it off or convert (by-pass the control unit) it to old fashion "pull the brake to stop" system.
2016 V7-II Stone
Offline lucian
« Reply #4 on: August 05, 2022, 09:00:58 AM »
Re connect the bike to your laptop and check for codes, if any write them down and heres a link to what they mean.
     https://www.apriliaforum.com/forums/showthread.php?341636-Collected-errorcodes
Offline MMRanch
  • MMRanch
« Reply #5 on: August 05, 2022, 10:14:16 PM »
Thanks lucian
Your a GREAT MAN !!  in my eyes anyway .    :thumb:
Well , I went out a while ago and hooked it up.   I did take a nice long ride today after clearing the Faults yesterday.
The code I got just a few minutes ago are :
P0140
P0502  Invalid Signal
P0611  Saved Data File for Safety Invalid Signal
I'll google them if no one has a  clue what they mean ?
« Last Edit: August 05, 2022, 10:58:08 PM by MMRanch »
2016 V7-II Stone
« Reply #6 on: August 05, 2022, 11:38:16 PM »
Could be a help…?
Offline lucian
« Reply #7 on: August 06, 2022, 07:11:44 AM »
Here's a better lists of codes
https://www.guzzitech.com/forums/threads/13-v7-v9-miu-ecu-error-codes.12522/
  It looks like po140 is lambra probe heater and
                   po502  is rear wheel speed sensor signal does not match vehicle speed sensor.
          It could be a calibration issue if the rear tire was changed or a faulty rear abs wheel sensor
            po 6011 is just a data file from the factory no worries on that one
« Last Edit: August 06, 2022, 07:21:05 AM by lucian »
Offline greer
« Reply #8 on: August 06, 2022, 08:01:48 AM »
Part number is the same for both front and rear wheel sensors.  I bought one from a parted out wrecked bike and used silicone where the wire goes into the sensor per the advice here.  MMRanch, have you noticed any change in the way the bike runs and rides?  That would be a big clue too, I would think.  I'm wondering about this master cylinder issue you mentioned  :shocked:
Sarah
Offline MMRanch
  • MMRanch
« Reply #9 on: August 06, 2022, 09:29:35 AM »
Thanks Sarah and lucian
Sarah the motor still pulls like a new one .  :grin:
The power level compared to the gearing still feels like there needs to be less number of gears and a taller end result when high gear gets chosen.    Power is good  :thumb:
The first thing I did was to clean the gap between the sensor and the wheel its pointed at.   On the rear the GAP WAS A LOT WIDER than the front.    Its time for a new rear tire (already got one in hand) , so the bike is headed to the shop and the rear  tire is coming off Monday .   So I'll cut the Sensor gap down to about ??? (.010") ???  or do ya'll think that's too close ?
The info I have for the sensors is part #859792 , I'll google it to see how much a part will be "IF" that has to happen.
Owning a Guzzi might be hard to do without back-up sometimes !
Thanks Guys and Gals
Mike
https://www.af1racing.com/oem-speed-abs-sensor-1d003350
« Last Edit: August 06, 2022, 09:41:05 AM by MMRanch »
2016 V7-II Stone
Offline greer
« Reply #10 on: August 06, 2022, 11:06:02 AM »
Part # 859792.  Cadre might have that in stock ready to go, and there's a bunch of used ones on Ebay.  But I hesitate to think it's a wheel sensor, based on the way my bike behaved when one went bad. Glad you've got something else to ride.  Keep us posted.
Sarah
Offline MMRanch
  • MMRanch
« Reply #11 on: September 06, 2022, 04:44:01 PM »
Thanks for all the help .
I got a new wheel sensor off ebay and put it in the rear.    Guess what ... Problem solved ,  :grin:
Nice to have friends to turn too !   :thumb:
2016 V7-II Stone
Offline lucian
« Reply #12 on: September 06, 2022, 07:16:44 PM »
 :thumb:  Now take some silicone sealant and add a wee bit around where the wire enters the plastic sensor body .  The on board diagnostics are pretty handy once you are set up to access them. Glad you got it sorted out.
Offline MMRanch
  • MMRanch
« Reply #13 on: September 06, 2022, 08:40:15 PM »
your a life saver !  :bow:
2016 V7-II Stone
Offline greer
« Reply #14 on: September 07, 2022, 06:30:07 AM »
 :bike-037:
Sarah
Offline hauto
« Reply #15 on: September 07, 2022, 07:28:58 AM »
I'm fight with the same situation on my V85.  Unable to recal the traction control. Mounted new tires and no problem. took the front off again and then put back on. Started back up and pumped up the front brakes and then red traction control warning light came on. No cruise control,ride mode stays flashing. Should this be a warranty/safety issue?
Offline lucian
« Reply #16 on: September 07, 2022, 07:46:15 AM »
here's a link to the service manual pages 56 thru 60 are relevant. First I would check the sensor air gap to the tone wheels.
  https://cadrecycle.com/manuals/manuals/v85-manual.pdf
« Reply #17 on: September 07, 2022, 08:03:40 AM »
Did that fix your front brake also?  When was the last time you changed the brake fluid?
Offline hauto
« Reply #18 on: September 07, 2022, 08:39:18 AM »
No did not repair front brake,just normal pump up after removing a wheel. Wheel spacing should be pretty much repeatable after tightening the axles. Sensor spacing looks to be within spec. I pulled the front spacer and had a look/see. No damage and not sure if there is a way to even adjust the gap. When I try a recal sometimes I get to the "hold speed" message but then it blows out to the "traction  control not activated warning". Tried disconnecting the battery for a period of time,no luck. It has me puzzeled,the day before mounted tires and no issues. The next day when I had the front wheel off and back on I forgot to pump up brakes till after I started it up. When I gave the front brake lever a few pumps thats when the warning light came on.
