Author Topic: Are Front Drum Brakes a Deal Breaker?  (Read 5252 times)
Offline Kane
« on: August 26, 2022, 11:34:20 PM »
Been looking at loop frames and I know that the front disc 850 Eldorado is very popular, but there are a lot of lovely earlier drum brake bikes around that I like. So how are the drum brakes on the earlier loop frames, Eldorados and Ambassadors? Are they good enough to live with for regular riding? I am not planning on doing any track days, and I like the way the front drum wheel looks on an older bike. Are they good enough or is it a bad idea for a regularly ridden bike?
« Last Edit: August 26, 2022, 11:39:36 PM by Kane »
2001 V11 Sport
1978 850-T3
2009 Ducati 1100 Hypermotard
Offline Huzo
Re: Are Front Drum Brakes a Deal Breaker?
« Reply #1 on: August 26, 2022, 11:56:11 PM »
No…
They’re a back breaker. :sad:
The way I see it these days, it’s dangerous enough out there without knowingly going partly equipped.
When you say…are they “good enough…”?
I guess if you’re happy to potentially collide with a turning vehicle in front of you at 30 mph instead of stopping 2’ short then yes…
They are “good enough…”
The acid test regarding good enough is the same as tyres, lights, helmets, handling…etc.
They are never “good enough” but, they can be deemed “acceptable”.
The latter term is when you roll the dice with a hearty meal versus a wheelchair post ride and decide the odds are worth it.
Jam tin brakes are a known weak spot on any bike, if you can engineer your safety buffer every time you’ll never have a problem.
But you have other drivers actively taking a part in your destiny..No thanks.
« Last Edit: August 27, 2022, 12:07:27 AM by Huzo »
Offline ray bear
« Reply #2 on: August 27, 2022, 12:21:38 AM »
Huzo, that doesnt include postie bikes does it  :azn:
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline xackley
« Reply #3 on: August 27, 2022, 01:02:29 AM »
Just like any vehicle you ride it and learn what it likes.
I've rode my 1958  R69  46k miles and have never had a problem stopping in time.
Every few thousand miles  check and adjust the cables, levers, and cams and you are good to go and stop.
But you will probably crash and burn for lack of ABS on that old bike.
Don
Edit: https://www.youtube.com/watch?v=JzTpAELS1HE&t=346s
« Last Edit: August 27, 2022, 01:09:11 AM by xackley »
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Online Turin
« Reply #4 on: August 27, 2022, 01:17:54 AM »
I have an early Ambassador and it does fine. You do have to think ahead.
1985 Sidlow Guzzi
Offline guzzista
« Reply #5 on: August 27, 2022, 02:46:12 AM »
My Ambassador schooled me on how to ride mountain roads as fast and smooth  as I could within the brakes' limits. Best riders training I could ask for.
Offline Huzo
« Reply #6 on: August 27, 2022, 03:04:21 AM »
It does have ABS..
You can squeeze the lever like Dwayne “The Rock” Johnson and it will never lock.
The “ABS” is for Absolutely Bloody Shocking…
It’s not all bad though, the heat from the glowing front drum can be ducted up to the handlebar ends by copper strap, as a jury rigged heated grips mechanism….
« Last Edit: August 27, 2022, 06:15:34 AM by Huzo »
Offline Don G
« Reply #7 on: August 27, 2022, 03:22:46 AM »
Why ask us, there will never be a straight answer, take one for a ride and judge for your self. Disc brakes can be adapted to a loop, after all that's what the factory did in 74, easily enough done, do some research on Greg Benders site. I adapted a dual disc system on my 71 Ambo-Vert using the proper fork tubes and T3 or Convert wheel, rotors, callipers etc. Easily done for affordable cost.   DonG
« Last Edit: August 27, 2022, 03:24:33 AM by Don G »
« Reply #8 on: August 27, 2022, 04:46:46 AM »
My 72 Eldorado has twin leading shoes, they are quite adequate, I have no intention of upgrading to disks, that would spoil the experience IMHO
Offline Texas Turnip
« Reply #9 on: August 27, 2022, 05:53:03 AM »
With well over a quarter million miles on drum brakes on old Ambos and Eldos I can say they are suitable for an alert rider. Learn how to ride..don't go racing up to the stop sign, watch your traffic lights and be aware of your surroundings. I've ridden in Houston, TX Chicago, IL and even hilly San Fran, CA with drum brakes. Even rode up Pikes Peak when it was gravel.
Realize that drum brakes wont stop you  on a dime and drive accordingly.
If all drivers had to drive a semi pulling a tanker they'd learn how to drive.
Buy one and enjoy it.
Tex
Offline centauro
« Reply #10 on: August 27, 2022, 06:30:24 AM »
This has always been my way to approach drum brake performance. Realize that in the Ambassador days, brake lining material was still asbestos, which has the best friction coefficient, compared to the composites that are standard these days. When I was working on my son's Eldorado, equipped with the single front standard leading shoe system, he wanted me to install a new brake cable and shoes on the front.  The new shoes, even if not asbestos, had good friction, but the new cable just stretched too much for an adequate lever pull. The original Guzzi one was much stiffer and worked better.
But, overall drum brake performance will never be as effective as discs, but you just adapt to the limitations.
As a Vespa owner myself, in Vespa circles we are fond to state that "Vespas don't stop, they just decelerate"....
And, I am grappling with the same issue on my front Vespa brake myself through a series of improvements.
Val Barone
1984 1000 SP/NT (sold)
1985 Vespa PX150E
1973 Honda CB 350 Four
Offline leafman60
« Reply #11 on: August 27, 2022, 06:30:46 AM »
I have bikes with drum brakes.  Sure, they don't match the performance of the modern discs but you are riding vintage machines that fail that test on other criteria as well.  I have those 2LS on my 500 Falcone and I've ridden it on The Dragon without running off the road or into anyone. Most of the time there, I was feathering the drums to slow down for some kid lagging around on a crotch rocket in front of me! lol
I like the looks of the drums- on vintage bikes.  Try it.  Just ride like a sane person on an old bike.
One note, I once had a beautiful Guzzi 850GT with the famous 4-leading-shoe brakes.  I spent a lot of time setting up the brakes, getting all shoes to free-trail just right. That sumbich would stop much quicker than the disc brakes that followed them on that era of bike.  The self-servo effect of the 4LS would almost throw you over the handlebars if you weren't prepared. I, as others have done, backed of the precise adjustments a little to soften that dramatic snatch down those huge brakes could create.
« Last Edit: August 27, 2022, 06:32:18 AM by leafman60 »
Offline Dave pinchard
« Reply #12 on: August 27, 2022, 06:32:39 AM »
As others have pointed out, the drum brakes can be perfectly adequate........... .if they are set up correctly. The geometry of the levers on the brake plate is very often incorrect, check out photo's of Loops on the web. Go to Greg's brilliant website where all will be revealed. The lining material needs to be correct too, take advise from brake lining specialists. My two Loops, one with a TLS brake and the other with a 4LS brake stop very well but they will never be as good as a modern disc setup. Ride accordingly. :thumb:
« Reply #13 on: August 27, 2022, 08:48:01 AM »
I just re-did the front brakes on jumpmaster's lovely Eldo. Before, they performed only average despite new aftermarket shoes (Newfren) arced to the drum and a quality Barnett cable. I had a pair of NOS Ferodo "green compound" shoes in stock, so we decided to try those.
I mounted them to the backing plate, used the axle as an arbor along with spacers as needed. Slipped an .020" shim between the cam and shoe and then turned them in my big lathe to the drum's inner diameter (8.660"). Huge improvement! Initially, they were too good - at low speeds they were grabby and began to squeal. Great at higher speeds though. I tapered back the leading edge of the lining approx. 1/4" and now they're perfect - powerful, controllable, no squeal.
As mentioned, lever angle and proper link rod adjustment are very important.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #14 on: August 27, 2022, 09:20:02 AM »
It does have ABS..
Agreed.  Never been a fan of ABS equipped bikes.  A "somewhat mushy" front brake seems to be part of the package.  Even on the high dollar sport bikes I have rode.
That said, first time I ever crash due to wheels locking during braking, I'll probably change me mind.
But how would one ever know if ABS saved your butt?  You had ABS, neither wheel locked up, you didn't crash.......?
« Last Edit: August 27, 2022, 06:06:23 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #15 on: August 27, 2022, 09:23:46 AM »
Why ask us, there will never be a straight answer, take one for a ride and judge for your self.   DonG
Well said.
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #16 on: August 27, 2022, 09:26:35 AM »
VERY SLICK Charlie.
Back in the good ole days, we did the same by sanding the high spots off the brake shoes with 60 grit paper.
It several disassemblies and took a lot longer....
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #17 on: August 27, 2022, 09:36:28 AM »
Good point.  Back in the day, Motorcyclist had an article about riding at "The Pace."
Short version, ride as fast as you want on twisty roads using only engine braking.
It is often surprising how fast you can ride by riding a gear lower than usual and only using engine braking.
2002 MZ Skorpion
1994 DR Skorpion
Offline huub
« Reply #18 on: August 27, 2022, 12:40:07 PM »
depends also on the riding you do,
if your riding is mainly in heavy traffic i would not want drum brakes.
if you live in the countryside it might be possible to adjust your riding.
personally , after running , and working on the front drum of my V7sport for 25 years i fitted disks after a accident that could have been avoided with better brakes.
Offline normzone
« Reply #19 on: August 27, 2022, 12:51:45 PM »
All great points above - I put 100K miles on my Eldo with front drum, and while I would have liked a disc the drum worked like it was supposed to. I did have to pump them in the rain to clear them so they would work adequately though.
Offline Motormike
« Reply #20 on: August 27, 2022, 01:58:04 PM »
Take a modern ABS bike and go do a full-on panic stop in the rain.  You'll know!
Offline Huzo
« Reply #21 on: August 27, 2022, 02:49:14 PM »
No Ray.
The postie bike will stop as well as the Norge or V85 due to the light weight.
« Reply #22 on: August 27, 2022, 05:00:59 PM »
I have friends and acquaintances that ride nothing but no front brake, rigid frame choppers, and ride them like the devil is chasing them.  Most of them have crap rear brakes also, and goes without saying that helmets are nowhere to be seen in this crowd.  Sketchy as hell to put it mildly.   Not one of them is capable of a controlled panic stop.  The weird thing is, they don't seem to get killed off more frequently than the AGATT, ABS guys.  Not sure why they haven't all perished by now.
« Last Edit: August 27, 2022, 05:09:33 PM by Dave Swanson »
Offline jumpmaster
« Reply #23 on: August 27, 2022, 06:46:51 PM »
 :thumb: on Charlie's assessment of the improvement after his work!  I'm now in the process of relearning how to stop smoothly with the new & improve front brake.  I don't know how long the improvement will last, & I doubt that my brake adjustment work in the future will be as good as his, but the front brake now feels like I could lock it if I tried - but I won't, of course.  Before, it felt like I could squeeze to the point of breaking the cable & it still wouldn't lock.
JC
Offline SIR REAL ED
« Reply #24 on: August 27, 2022, 06:58:37 PM »
That's good to hear!  When in the hands of a master like Charlie, it is amazing how good the "old. outdated" equipment can function!
Is that a double leading shoe front brake?
IIRC, a few bikes came with Four Leading Shoe front brakes and two front brake cables.  Setup was crucial.
2002 MZ Skorpion
1994 DR Skorpion
Offline jumpmaster
« Reply #25 on: August 27, 2022, 07:01:44 PM »
Yep, mine is 2LS front.  Some on this forum have said that a properly set up 2LS front will just about match the stock 4LS or single disc front brake, but I have no exprience on either of them.
JC
Offline SIR REAL ED
« Reply #26 on: August 27, 2022, 07:28:22 PM »
The way Charlie did it is brilliant.  You get to see all the improvement after one machining/adjustment operation.
The way we used to do it (no lathe) you might feel a small 10-25%? improvement each time you sanded the shoes to get a better match with the drum.  In those situations, I think human nature always dominates and it is easy to delude yourself that the improvements are more significant than they really are, cause of "your skill" and "TLC."
IIRC, way back in the day, one of the big technical sellings point of the early disc brakes were that they were "self-adjusting!"
I think every modern trials bike on the market today has a hydraulically actuated clutch for that reason.
2002 MZ Skorpion
1994 DR Skorpion
Online nc43bsa
« Reply #27 on: August 27, 2022, 08:49:27 PM »
I roadraced a BSA B-50 with the widely maligned 2LS conical front drum brake.  It had Ferodo shoes, and the only other modifications were 1/2" longer arms on the cams and a clutch lever and perch on the handlebars.
I could easily stand the bike on the front wheel coming into the pits after a practice or a race, but I had to tighten the cable DURING the race and loosen it when I got off the bike in the pits.
1990 MilleGT
Offline Kane
« Reply #28 on: August 28, 2022, 12:52:40 AM »
Wow, I didn’t know there were still bikers like that. Like a Dave Mann artwork come to life! All of the Harley guys around here, including the local badass M.C. guys I see, are riding Road Kings and the like. All newer bikes (with disc brakes from bow to stern). But I live in L.A.
« Last Edit: August 28, 2022, 12:55:37 AM by Kane »
2001 V11 Sport
1978 850-T3
« Reply #29 on: August 28, 2022, 06:03:06 AM »
Agreed!
Biggest thing you need to know is you will ALWAYS apply front and rear brakes on a loop in tandem..  not like on modern bikes where I use the front only about 75% of the time.
The brakes arent super great, but they arent exactly rubbish.  They fit the power of the Ambo fine. You are talking about a bike that wont- or will just barely- crack the ton, it's not a rocket ship.
