Author Topic: Anyone use tire mounting compound paste?  (Read 1427 times)
Offline Bull Tahr
    • My YouTube channel
Re: Anyone use tire mounting compound paste?
« Reply #1 on: September 02, 2022, 08:11:03 PM »
Using something is always good practice. I don't remember seeing any shop do it "dry". Soapy water probably do the same job to be honest.   :thumb:
Utrinque Paratus
On the Face: Dusty Visor Motorcycles
« Reply #2 on: September 02, 2022, 08:12:26 PM »
Yeah, I use diluted water/dish soap in a spray bottle.  Works.  :thumb:
Offline Road Rocket
« Reply #3 on: September 03, 2022, 05:52:11 AM »
 I have used the Bead Don mentioned in the first post...It is way better than soapy water, Pam ow whatever...Try it....
Rough Edge Racing with a new name but still the same pin head
Offline guzziart
« Reply #4 on: September 03, 2022, 06:18:52 AM »
That looks more expensive than Nomar stuff!  I've been using ruglide for lubing.  Between the ruglide, Mojolever & Nomar stand I have been successful in changing my own tires.  Also, letting the tires warm up a bit in the sun turned out to be a big help too.
'72 CL350, '72 Eldo '87 LMIVSE, '91 CT70, '08 Wing, '23 v85 Travel
« Reply #5 on: September 03, 2022, 06:59:56 AM »
I use dish soap strait, when it dries it's powder. Then you wash up rim & tire when mounted. Then it's all clean for the balance weights to stick.
Offline kballowe
  • - Kevin the Great -
« Reply #6 on: September 03, 2022, 07:11:36 AM »
I always try to use something that prevents corrosion.  Right now it's No-Mar tire paste.
According to the label.....
- Vegetable based and non-toxic
- Washes with water and inhibits rust
« Reply #7 on: September 03, 2022, 08:08:57 AM »
I use a mix of oil-soap and water in a spray bottle.
Online Brand X
« Reply #8 on: September 03, 2022, 08:32:48 AM »
If you let the Murphy's oil soap dry out in your lube bucket it almost like No-mar paste. I also have some mixed in a bottle by my tire machine. It has the same smell as the No-mar too.. Works as well, and is much cheaper by the gallon..
