Author Topic: V7 850 won't start  (Read 23002 times)
Offline bobrebos1
Re: V7 850 won't start
« Reply #30 on: January 19, 2023, 01:47:56 PM »
I know this post is over a year old but my starter switch on my 21 v7 stone centenario acted up today.  If I apply light pressure at about the 3/4 travel point the switch would work.  If I push on it normal in one hard press ….nothing.  It only did it a couple of times and is working fine now.  Il try some DEOXIT Spray contact cleaner I guess.  Geezzz…..
Sober, Retired Air Force!
Offline joe-dean
« Reply #31 on: January 19, 2023, 02:17:31 PM »
crummy switch mine used to do the same thing try contact cleaner
Offline bobrebos1
« Reply #32 on: January 19, 2023, 03:07:12 PM »
I ordered some more spray on contact cleaner and will see if that helps.  Bike does me no good if it won’t start sometimes!  Lol.
Offline Vagrant
« Reply #33 on: January 19, 2023, 06:18:36 PM »
Frankly, the switch is a POS!
When I got to Az a few weeks ago, my 16 V7II pulled the same crap and I thought I had fixed it months ago. I had to flip the kill switch a few times and kept hitting the button maybe ten times and it fired right up.
Offline bobrebos1
« Reply #34 on: January 19, 2023, 10:13:44 PM »
POS IS RIGHT!  Don’t know what I’m going to do other than the Deoxit contact cleaner.  Getting a new switch won’t help if it’s a design flaw!  Geezzzz
Offline bobrebos1
« Reply #35 on: January 19, 2023, 10:43:42 PM »
Good!  I need to look into De-oxit and ACF 50.
Sarah
Is your start switch working well now after applying DE-Oxit and ACF50?  I’m having intermittent issues with mine on the 2021 v7 stone centenario!  Darn it!
Offline bobrebos1
« Reply #36 on: January 21, 2023, 11:56:30 AM »
I rode to the gas station today.  Wouldn’t turn over after I refueled.  Cycled/tried about ten times and voila, the start switch finally made contact.  I’m thinking if I get a new starter switch it will have the same problem if it’s in the design?
Rode bike home and it started on every button push.  Geeezzzz?????  Lol
« Last Edit: January 21, 2023, 01:39:58 PM by bobrebos1 »
Offline buck
« Reply #37 on: January 21, 2023, 12:29:01 PM »
Earlier in this thread after I posted my advice about fixing the starter switch someone posted that you shouldn’t use dielectric grease on the switch. They are wrong. I’ve been certified as a Master Technician for nearly 30 years and stand by my original advice. Disassemble the switch, lightly dress the contacts to get any corrosion, dirt or film off of them, apply dielectric grease and your issue will be solved. It’s been over a year and almost 10,000 miles, and it hasn’t hesitated to crank/start even once since I did this.
Offline bobrebos1
« Reply #38 on: January 21, 2023, 01:39:10 PM »
Thank you
Offline Huzo
« Reply #39 on: January 21, 2023, 02:55:42 PM »
My BIL was a checkout guy at a local grocery when he was in high school.
I remember the day he said this creepy looking customer bought a huge jar of Vaseline and a couple of big cans of tuna fish.
He had this strange feeling the purchases were related.
:rolleyes: :thumb:
Offline Huzo
« Reply #40 on: January 21, 2023, 02:59:01 PM »
I’d be sick to death of it by now.
I would have pulled the relevant wires, blanked off the switch and installed a good quality, heavy duty sealed push button one….
In addition.
If it’s anything like the V85 then it has a piddly little female connector that slides on to the starter motor in the solenoid area. The Norge one is pathetic (at least used to be…).
If this is frail/corroded or otherwise rooted, you’ll not get current to the solenoid to pull the contacts in and you’ll hear no “click” as you describe.
Also when you check the battery cables, do both ends.
« Last Edit: January 21, 2023, 03:06:21 PM by Huzo »
Online Moparnut72
« Reply #41 on: January 21, 2023, 06:51:00 PM »
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline bobrebos1
« Reply #42 on: January 22, 2023, 04:00:11 AM »
I will be pulling the switch housing apart today to fix it…..hopefully!
Online john fish
« Reply #43 on: January 22, 2023, 07:02:39 AM »
https://www.thedrive.com/maintenance-repair/39173/dielectric-grease
No more to be said.
kk
Well, there is disagreement on that page.  From that link:
Fun is greater than Fast
3 March, 2021
Dielectric grease is great for any high current, large terminal connectors: batteries, bulbs, spark plugs, etc. But, be very careful when using dielectric grease on smaller connectors.  Dielectric grease is very sticky and will pick up any dust or grit it contacts.  This grit becomes an abrasive and destroys the electrical terminal plating very quickly, leading to a completely failed electrical connection.
Another factor is the fact that some NOx, O2 and pressure sensors use the electrical connection as the atmospheric pressure reference.  Applying grease to these will cause the sensor reading to drift over time.  If you put dielectric grease on a sensor, actuator or ECU you could be spending hours cleaning it all out next time you disconnect it, or replacing that device and harness all together.
Rule of thumb from actual electrical connector companies is: If you need dielectric grease, the connector and/or seals are already damaged and should be replaced.  Do not add grease as a preventative measure unless directed by the manufacturer.
Reply
Share
Brian Ter Keurst
9 December, 2022
as a commercial aviation mechanic, I agree.
In my line of work there are NO DEVIATIONS from THE AMM(aircraft maintenance manual)
PERIOD!!!
lives are at stake in my job and I "NEVER" go beyond what the manufacturer states is the proper procedure to the T.
There is also this bit regarding Vaseline use:
Q: Yeah, But Is Vaseline a Dielectric Grease?
A: Dielectric grease is different from Vaseline, as it uses a silicone base while Vaseline is petroleum jelly, which is made of waxes and minerals. Don’t use Vaseline in your car.
Personally, I tend to listen to the aircraft guys.  That seems to be the safest action.
« Last Edit: January 22, 2023, 07:05:47 AM by john fish »
He lost the run of himself.
Offline bobrebos1
« Reply #44 on: January 22, 2023, 07:59:18 AM »
3 March, 2021
Reply
Share
Brian Ter Keurst
9 December, 2022
PERIOD!!!
Well I’m leaning toward NOT applying do-electric grease to my 2021 v7 stone starter switch then.  Il take it apart and try to see why it’s not making contact intermittently.
Online john fish
« Reply #45 on: January 22, 2023, 11:35:35 AM »
To be perfectly clear, I am not trying to create or win a debate here.  I am just an untrained guy who works on his own bikes and is trying to wade through the mountain of information out there to try to find best practices.
If you have been using dielectric grease for years and it works for you-- awesome.  There is a good chance that you are a better mechanic than I am and are working from your experience.  Again, that's awesome.
For me, I stick with the aviation guys because it is the safest way to proceed.  For me.
Offline bobrebos1
« Reply #46 on: January 22, 2023, 01:38:58 PM »
I tried some spray contact cleaner on the switch.  Il see how it works now.  I couldn’t get it to not work now but I’m sure when I’m on road next and stop, it won’t restart.  Lol
Offline buck
« Reply #47 on: January 22, 2023, 04:34:06 PM »
To each their own. I don’t expect anyone to take my word for anything, but I do openly share my mechanical knowledge to help others when I can. I’ve held Master certification since 1993 and have factory training from Porsche, Audi, Nissan, Mitsubishi, Ford, Harley-Davidson and several others.
The switches on the V7 are easily penetrated by water/moisture. If you buy factory replacements to the best of my knowledge they haven’t been redesigned and they won’t be any better. Dielectric grease gets rid of the issue, but no one has to take my word for it!
Offline bobrebos1
« Reply #48 on: February 17, 2023, 06:00:08 AM »
I tried deoxit and it started correctly through about two weeks of use, and now it doesent start intermittently again, so i guess il take it off and apply some dielectric grease.  Thanks.  Bob
Offline Vagrant
« Reply #49 on: February 17, 2023, 09:19:59 AM »
I got mad Sunday night after another fail on my switch. Unfortunately I never thought to take a pic.
The rocker itself is cheap somewhat flexible plastic. Why they couldn't just use a plain button like everybody else is beyond me. Take the top off of the switch, remove one throttle cable, warning do not try to start the bike with it off, remove one tiny screw to get the switch out, there is a contact disc on the bottom then a cone shaped spring sitting on it. The spring has a small metal slug like the screw off top on a spark plug. It has a tiny area on one end that is turned down a few thousands to let it sit into the spring. I think this is the problem, it should be sticking down into the spring 1/8" farther to always make good contact. You might be able to put some epoxy or JB weld into the recess of the rocker to make it go down farther. Turning it down on a lathe would be ideal. If I have to take it apart again, I will try that. You can tell the rocker flexes all around and just doesn't shove the little slug positivly into the lower contact disc. If I had thought to do this I think I would have solved the problem once and forever. As it is I just cleaned up the slug and contact plate and used some vaso
line on them. Hopefully the first guy to try this will take good pics.
Bob, reread this.
Knock on wood, it has only acted up once since I did this.
« Last Edit: February 17, 2023, 09:26:36 AM by Vagrant »
Offline bobrebos1
« Reply #50 on: February 17, 2023, 09:51:16 AM »
Bob, reread this.
Offline ozarksguzzi
  • Ozarks Guzzi
« Reply #51 on: February 17, 2023, 10:21:50 AM »
One other option is to find a V7 with points and carbs. 47 years of ownership ( I can't part with ANYTHING) and 70,000 miles it has never left me stranded. Good luck locating the gremlin
The older I get, the faster I was
Offline bobrebos1
« Reply #52 on: June 19, 2023, 12:25:54 AM »
Thats it.  I know this is an old thread BUT!  Im tired of my switch acting up.  Ive taken it apart.  Applied deoxit, applied Vaseline etc etc.  Even tried to "adjust the depth of the plunger or whatever its called" inside the switch.  Still acting up and left me for about five minutes at the gas station until it just decided to work.  To the shop for a new switch that ACTUALLY WORKS or it will be rewired to a different switch.  Something.  This is fricken ridiculous!  :angry: :angry: :angry:
Offline Scout63
« Reply #53 on: June 19, 2023, 05:40:27 AM »
Also check the switch ground path. Bad grounds are common. Given the litany of MG dryer switch issues over the years, I agree with Huzo’s recommendation of installing a good switch.  Maybe even hide it away somewhere cool.
Ben Zehnder - Orleans, MA USA
Offline bobrebos1
« Reply #54 on: June 19, 2023, 06:32:13 PM »
Maybe il install something like this if the dealer cant fix/replace original switch.
Online Tkelly
« Reply #57 on: June 19, 2023, 08:52:48 PM »
Our v7 special did that,I had to flick the kill,switch until it would start.Problem seemed to occur when I used the kill switch sinstead of turning off the key.The fix was to,spray wd 40 while flicking the switch and avoiding moisture.When my wife rode it she never used the kill switch and never had a problem.
Online Moparnut72
« Reply #58 on: June 20, 2023, 08:00:30 AM »
I have read about that in the past. I don't remember if it was on this forum or the Triumph forum. I started riding long before manufacturers were putting these on their bikes so I never got into the habit of using one. So I never touch the thing, that's what the ignition switch is for. Someone somewhere has said that in an owners manual it was stated that the kill switch was for emergencies and not for shutting down the bike. Makes sense to me but I don't know if that would be the cause of your problem.
kk
« Last Edit: June 20, 2023, 08:01:46 AM by Moparnut72 »
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline bobrebos1
« Reply #59 on: June 20, 2023, 10:18:36 AM »
kk
It’s a bad design of the starter button.  I do not use the kill switch.  I use the key/ignition to shut it off.  When it starts…lol
