Horrible grinding noise
Topic: Horrible grinding noise (Read 1386 times)
JBU
Gaggle Mentor
September 21, 2022, 03:47:10 PM »
I need some advice. I have a 74 eldorado that started to make a horrible grinding noise when I hit the starter button. This is what has been done so far. The ring gear is a bit worn but doesn't seem excessively worn. My T3 had about the same wear.
Put in a new odyssey battery
fitted 2 different new valeo starters
Put in a new starter relay
With all of this done the grinding noise is still there. Any suggestions on what to look for next?
JBU
guzzisteve
"Just Ride It"
Re: Horrible grinding noise
Reply #1 on:
September 21, 2022, 03:54:46 PM »
Try a different ring gear on flywheel, sounds like it's trashed from spinning teeth from starter. Why? not meshed, worn although looked to pass. Not much choice now, no magic shims to take up slack.
JBU
Gaggle Mentor
Reply #2 on:
September 21, 2022, 03:57:18 PM »
Thanks Steve, that was the next thing I was planning on throwing at it but wanted to check if there was anything else I might be missing.
JBU
moto-uno
Reply #3 on:
September 21, 2022, 04:58:56 PM »
That's gonna be a lot more work , sure hope you find the 'smoking gun' if you go in there ! Peter
