Author Topic: Grip size / heated grips  (Read 1751 times)
Offline ferchogottlieb
« on: September 26, 2022, 02:51:01 PM »
I'm looking to install heated grips on my 2020 V7 III Racer. Do you guys know which size are the handlebars? Has anyone installed a nice set of heated grips that feel OEM, in other words, the control is built into the grip like this one?
https://www.amazon.com/Koso-AM111030-Apollo-Heated-Grips/dp/B00T6IX42S/ref=sr_1_4?crid=DUR5K30OOIL8&keywords=kok+heated+grips+motorcycle&qid=1664221631&sprefix=kok+heated+grips+motorcycl%2Caps%2C184&sr=8-4&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
Offline Vagrant
Re: Grip size / heated grips
« Reply #1 on: September 26, 2022, 04:48:37 PM »
I just put Oxford touring grips on my v7 yesterday. About the tenth set I've used. Solid performance but yes the controller is hard to hide.
Offline analog kid
« Reply #2 on: September 26, 2022, 05:03:57 PM »
My riding buddy installed Koso brand heated grips on his Harley just last week. A different model than the one in your link, but the heat control is the same. He's had the chance to use them once, on heat level 3 of 5, and liked them.
I was present for the wire routing portion of the install, and IMO: for the fine wire gauge, the connectors seemed overly large & clunky. Also there's a large in-line control box which i assume (?) contains the control circuitry. Approx 1.5" x 3" (going by memory. Pic attached at bottom). It's fine if you have space under the tank in which to shove it, as he did.
The model you linked may have a different arrangement.
One wire pulled out of a connector (pictured), but I have no idea how hard he was yanking on it. The wire, I mean.
He emailed Koso for a replacement connector but got no reply. It's fixed now..
90 Mille GT
03 Aprilia Caponord
84 LeMans lll (project)
07 Breva 1100 (sold)
« Reply #3 on: September 26, 2022, 07:38:08 PM »
If the bars are 7/8" (they should be?), the ones in the link you posted should work. 1" is for the throttle tube, 7/8" is to fit the bare bar.
They look interesting. Hope they are easy to install and work well for you.
Offline n3303j
  • Ron Cichowski
« Reply #4 on: September 26, 2022, 08:14:47 PM »
https://smile.amazon.com/Heat-Demon-External-Motorcycle-210019RR/dp/B001AWRCJO/ref=mp_s_a_1_6?keywords=grip+heaters&qid=1664240795&sr=8-6&ufe=app_do%3Aamzn1.fos.304cacc1-b508-45fb-a37f-a2c47c48c32f
Always been happy with these. They were $37. They fit right under your regular grip.
Adhesive sticks to bar. You can point them "leads to outboard", file a notch in the bar end
and fold the leads back 180 degrees to pass them through the bar interior. Put a slot in the bottom of the bar between the risers and bring the leads out through that slot. I then run the leads into the headlight shell and terminate there.
Done it 5 bikes so far without any surprises.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline greer
« Reply #5 on: September 27, 2022, 06:25:02 AM »
I bought the BikeMaster grips someone here recommended, and now I'm a believer.
https://smile.amazon.com/gp/product/B009Z1KQ2M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Just like the Oxfords as far as the install and controller, but half the price.  I always used the Heat Demon under grip heaters too, but the overall package and ease of install make make the BikeMasters a bargain in my opinion.
Sarah
Offline Vagrant
« Reply #6 on: September 27, 2022, 07:06:28 AM »
That's a great price. Get them.
Offline jrt
« Reply #7 on: September 27, 2022, 08:30:06 AM »
I have always wondered about this style-  I would think that most of the heat would dissipate through the handlebars.  Is there any insulation between the heaters and the bars?
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline greer
« Reply #8 on: September 27, 2022, 09:31:19 AM »
The throttle tube serves as an insulator on the right, use a good thick piece of heat shrink on the left.  But at under $50, the BikeMaster grips are a bargain.  And the install is simple as can be.
Sarah
Offline n3303j
  • Ron Cichowski
« Reply #9 on: September 27, 2022, 10:50:51 AM »
Heat absorbed by the handlebars is still warming the hand wrapped around the grip.
At full power they will get too hot to he comfortable so heat loss isn’t a problem.
Outside of the original ($37, cheap) price my favorite feature of these was the relative ease in routing the power leads inside the bars. It's a clean and unobtrusive installation.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline jrt
« Reply #10 on: September 27, 2022, 01:54:18 PM »
Thanks,  y'all
L-720
1973 Eldorado
2020 R1250RS
