Author Topic: Convert gearbox clutch vent/drain question  (Read 1306 times)
Offline glenm64
« on: October 02, 2022, 03:19:02 AM »
Hi all
One of the reasons I love my Guzzi is whenever I work on it I am reminded of their simplistic but thoughtful design.
I have added a very tidy and complete Convert to my garage and am in the process of repairing a few leaks, and one is the gearbox. When I separated the front clutch housing section about 1/4 a cup of oil came out.
Now I am wondering why didn't the designer of this box did not put a small vent hole in the bottom of the area in question? Surely it would act as an indicator for leaks, and allow any oil to drain. I'm amazed the clutch wasn't slipping as it was coating the friction plates.
Is there any reason I couldn't put one in?
Cheers in advance
Glen
Offline ray bear
Re: Convert gearbox clutch vent/drain question
« Reply #1 on: October 02, 2022, 03:47:01 AM »
You can do what you want, when I first got my convert some 2 years ago the clutch plates were sticking together and had to rev engine with brake applied to separate, What Im going to tell you you must not tell any one else on this forum for fear of back lash  :grin:  I drilled a 6mm hole in the bottom of clutch housing and tapped it and put a grub screw in it , then added about a half a cup (no more theres a throw out bearing you dont want to flush) of white spirits through the timing plug and run the motor for two minutes operating the clutch and drained, clutch has been like new ever since.  so yes why didnt they. I keep mine plugged to keep dirt out.  Ray
« Last Edit: October 02, 2022, 03:51:35 AM by ray bear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline glenm64
« Reply #2 on: October 02, 2022, 05:40:03 PM »
The oil is definitely gear oil not ATF.
I'm doing a rebuild on the box so all the o rings and seals will be replaced.
My question was did the gearbox designer not put in a drain/vent simply because he forgot rather than based on reasoning?
« Reply #3 on: October 02, 2022, 07:20:36 PM »
I think they (wrongly) assumed there would never be a leak. I drilled a weep hole in mine.
Offline bigbikerrick
« Reply #4 on: October 03, 2022, 02:27:35 PM »
There was an article ,on one of the Guzzi sites, that showed you exactly where to drill a small"weep hole" in the bottom of the bellhousing. I looked for it but did not find it. I need to do that to my Convert, so if I find it, I will post a link.
Rick.
Offline glenm64
« Reply #5 on: October 03, 2022, 05:04:17 PM »
You can drill a hole anywhere next to the web on the bottom in the clutch basket housing, it's not that critical.
I drilled and tapped a 6mm hole in mine, not that it needs a thread to be honest.
« Reply #6 on: October 03, 2022, 05:10:51 PM »
Thanks for the photo. I guess the only other precaution would be to use some sort of depth stop on the drill bit so one does not drill too deep, and damage the clutch basket.   :grin:
Rick.
Offline chuck peterson
« Reply #7 on: October 04, 2022, 05:25:40 AM »
Dr dave richardson suggests that weep hole in Guzziology
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
