it doesn't appear that there is enough extension on the "plunger" part of the lever to push on the clutch - is that correct ?
You can't evaluate the throwout system if the transmission has been removed from the engine and then further disassembled. When fully assembled, I believe that the outer body face should be just about flush with the surrounding casting. I know that it correct for the 5 speed but perhaps not for the 4 speed. Your outer body shows recessed about 1/8". But that is meaningless if it is not currently pushing on the clutch pressure plate. You can disassemble the various throwout pieces but final evaluation against wear requires full assembly. Of course, disintegration of the throwout bearing can cause this same spacing and that would be obvious when the parts are disassembled.Charlie Mullendore will know and hopefully chime in.Patrick HayesFremont CA
thanks for all the responses everyone…in reference to comment about the dreaded chrome bores -- a long talk with Curtis Harper convinced me that the chrome bore issue is overblown as long as one has solid compression in both cylinders - I do so...
Charlie -Turns out I have early type 20mm bearing with 5 balls and no cage - but I also have a 228mm clutch rod which is from the later bikes as far as I know.Are you saying I can use the 22mm bearing? - what do you mean by modification?- Ray Q
The larger consensus regarding the stability of the chrome bores seems to be related to how active the bike has been- always ridden bikes seem to have better condition bores than bikes that weren’t. The unavoidable tangent to the “overblown” argument is that no one familiar with early Moto Guzzi V-twins & this specific issue will buy your bike for much more than parts/scrap price if the chrome bores & all related potential damage have been resolved. That’s because many of us have btdt and learned that wishful thinking didn’t avoid, pay for or fix the issues. Good luck.
Didnt mean to turn this into another thread about chrome bores -- (and if anyone has an idea on why my transmission is still hard to turn it would be appreciated)--but here are a pix of the chrome bores 1968 V700 7k miles - wear is apparent at the very top of stroke and some "sparkles" in the bores - tnx Charlie for the previous pixI suppose I have another winter project..perhaps there isn't enough wear to warrant a complete teardown and bottom end rebuild......?
There is enough chrome gone already that I would be concerned. More than enough to do expensive damage. There are no Gilardoni kits for V700s (last batch made was years ago), so the best bet is to have the original cylinders replated by Millennium Technologies.
Safe to say damage from chrome would be in the typical areas of a gas engine bottom end rebuild? - all main/rod bearings, oil pump, crankshaft - what else am I missing?Just trying to get a handle on what I am in for once I start down this road
Concerning the tight turning transmission , if you shimmed the shafts (etc) to the least suggestedend play , the gasket does become the allowable free play . Have fun ! Peter
