Author Topic: Europe trip trouble  (Read 18726 times)
Europe trip trouble
« on: October 07, 2022, 10:40:10 AM »
Short and sweet.
Norge refused to start in Millau Camping ground.
The yellow fuse blows when key is on.
Bike cranks, red triangle and SERVICE light on.
Anyone know what fuse this covers ?
I’ll look in the on line manual .
Re: Europe trip trouble
« Reply #1 on: October 07, 2022, 10:50:13 AM »
Ok.
Fuel pump/coils/injectors
Because it’s blowing the fuse, I can’t even crank it and check for spark, fuel swirl or injector delivery.
Online PJPR01
« Reply #2 on: October 07, 2022, 11:11:07 AM »
Have you tried swapping the 20 with a 30 and see if it does the same thing?  I presume you have some spare fuses?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline berniebee
« Reply #3 on: October 07, 2022, 11:26:04 AM »
Crap, my sympathies on this happening.
I don't know if this is possible or easy on a Norge or what tools you have, but:  If a visual check for burnt or melted connectors and components (or bare wire touching frame.) doesn't point to a suspect,  I would disconnect all systems associated with that fuse, then turn on the ignition and connect one at a time until a new fuse blows. You might need a few spare fuses to narrow it down.  My guess of what's most likely: fuel pump. Pump motor failure or blockage causing abnormally high current draw. If it's the pump, it might run for a while with a new fuse. Or not.
Long shot: Maybe vent on gas cap not working, causing a vacuum to form in gas tank? Remove it while listening for the whoosh of air.
« Reply #4 on: October 07, 2022, 11:50:08 AM »
Disconnect the battery for a few minutes then try?
« Reply #5 on: October 07, 2022, 12:21:18 PM »
I would do that, but even if it doesn’t blow the 30, it still doesn’t point to the issue.
« Reply #6 on: October 07, 2022, 12:22:13 PM »
That might be a good place to start.
There’s a bike shop in town, I’ll see if I can get it into there.
Offline bobrebos1
« Reply #7 on: October 07, 2022, 12:34:27 PM »
Best of luck to you.  It stinks breaking down!
Sober, Retired Air Force!
« Reply #8 on: October 07, 2022, 01:18:29 PM »
Yes.
It could have been in a better place, but also could have been a HELL OF A LOT WORSE….!
Still a bugger though.
Online PJPR01
« Reply #9 on: October 07, 2022, 01:27:32 PM »
I'm working up to a more complicated solution...was starting with a simple first step to see if that would at least allow you to start the bike, and then possibly ride it to a shop.
Did you buy any chance bring your laptop and Lonelec cables with you to plug in Guzzidiag?
Paul R
2008 Silver Norge
2002 V11 Scura
« Reply #10 on: October 07, 2022, 01:32:33 PM »
Even if I managed to start it, if it stopped half way to the shop, then I’d be stuck in the city on a Saturday afternoon.
At the moment I’m in a camping park.
Offline lucian
« Reply #11 on: October 07, 2022, 03:21:55 PM »
Try  unplugging the fuel pump elec. connector , if fuse holds when key goes on you've found the short. Sound like a possible fuel pump problem. Maybe just a shorted wire and not a bad pump.  :popcorn:
Offline Frenchfrog
« Reply #12 on: October 07, 2022, 03:46:26 PM »
Just sent you a PM. I know just the man who would be delighted to help if he's not on the golf course :grin:
You will be in the best hands this side of Bungadore
« Reply #13 on: October 07, 2022, 03:51:31 PM »
I’ll call in the morning Chris.
« Reply #14 on: October 07, 2022, 03:57:38 PM »
Berniebee is on the same track Lucian. That’s the route I’ll go, but thanks to all that have taken an interest.
« Reply #15 on: October 07, 2022, 06:54:59 PM »
Nah mate…
Offline SemperVee
  • USMC Retired
« Reply #16 on: October 07, 2022, 07:17:32 PM »
 Huzo,  You have the good Karma force working for you.....
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #17 on: October 07, 2022, 09:21:23 PM »
Similar thing with my Greenie, fuel pump. Kept blowing bigger fuses and would go a few miles.  I thought a new filter might fix it, didn't... needed a fuel pump.  I'm not the mechanical person here as you know.  Good luck.
« Reply #18 on: October 07, 2022, 10:52:40 PM »
Trouble with the fuel pump theory, is that the fuse doesn’t blow until you touch the starter..(I think)
The pump is swirling from when you turn the key on…(supposedly).
But I’ll check that when I get up. I have to get a collection of 20 A ones first.
Offline auzziguzzi
  • This ain't no dress rehersal
« Reply #19 on: October 07, 2022, 11:53:12 PM »
For what it’s worrh, my 2006 red Norge exhibited the same symptoms but intermittently.
Turned out to be an uninsulated spade terminal feeding one of the four headlight bulbs.  The terminal floated around, occasionally touching the earthed headlight shell thus blowing the main fuse.
The Norge headlight only comes on as the engine starts.  That may explain why the fuse blows as you touch the starter.
If your Norge has the same fault as mine, it will blow the fuse on high beam but not low beam.  Or vice versa.
'96 Sport 1100c (67,084 km)
'83 V50 III (80,000 km)
'06 Norge (169,000 km)
'90 NTX 650 (66,911 km)        SOLD 21/08/2025
'06 Breva 1100 (84,505 miles) SOLD 03/03/2022
Offline tris
« Reply #20 on: October 07, 2022, 11:57:56 PM »
If that's correct,  will it bump start  ie leave the starter alone
1993 TW125 "POS" - Resting
Online John A
« Reply #21 on: October 08, 2022, 12:05:54 AM »
^^^^ this, check for a melted ground on the taililte socket as well.
« Reply #22 on: October 08, 2022, 12:21:46 AM »
The fuse that blows only protects the coils, injectors and fuel pump.
Offline reidy
« Reply #23 on: October 08, 2022, 12:22:13 AM »
Huzo
I had a look at the circuit diagram. As you have discovered it appears that fuse supplies power to the fuel pump, injectors and coils (5 plugs).
As it does not blow immediately and only when you touch the starter it is unlikely to be the fuel pump as it normally pressurizes when you first turn on the key.
The logic I am using is either an injector or coil is drawing two much current. The circuit appears to work by that fuse supplying 12 volts and the ECU providing the earth as required.
Provided you have some spare fuses I would put in a fuse and disconnect the injector and coil plugs. The bike should then crank over but not start and not blow the fuse. If it does the fuel pump is looking likely.
I would then connect the Left or Right injector and Coil plug. The bike should then crank over and hopefully start on one cylinder. If it blows the fuse try the other side. If you can isolate a side then plug in either the injector or coil for the faulty side.
Once you have found the component it is a replace job I would expect.
This is a start
Steve
« Last Edit: October 08, 2022, 12:22:56 AM by reidy »
« Reply #24 on: October 08, 2022, 12:22:53 AM »
Just for information’s sake…
« Reply #25 on: October 08, 2022, 12:25:22 AM »
#27 & #31 point to injector circuit issue.
Is the “A” column for active and the “O” for stored faults ?
Offline reidy
« Reply #26 on: October 08, 2022, 12:41:19 AM »
Looking at the fault codes and wire diagram it would appear that the injectors are the last connection on the power wire.
All of the fault codes show you are on the right track.
A quick google search shows the x as no or incorrect signal.
A broken wire either from pin 37 or 28 of the black ecu connector that is now shorted to ground would most likely show up this fault.
Now I am going to take a stab here, as far as I can tell the ECU is located under the front of the tank. Have you got a tank bag on the bike?
Have you moved anything near the front of the tank since you pulled into the camp ground?
If you have it may have interfered with the ecu plug/wires. Faults often don't happen without a cause.
Steve
« Reply #27 on: October 08, 2022, 01:53:17 AM »
That’s true Tris, but I can’t test that theory because I might end up at the bottom of a hill..!
« Reply #28 on: October 08, 2022, 01:55:33 AM »
Steve
The bike was perfect.
I turned it off to answer a question and from then on it did this.
« Reply #29 on: October 08, 2022, 02:57:02 AM »
Did a couple of things and this happened… https://youtu.be/ijK8IAQgvIc
I’ll elaborate later, thanks to one and all.
Peter.
