Author Topic: alternative 98 EV turn signals  (Read 4275 times)
Offline flower_king001
« on: October 15, 2022, 06:06:30 AM »
OEM turn signals on 1998 replaced 2 X's in the past 10 or so years.
I'm now looking for folks who have actually replaced with an alternative source.
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Online fotoguzzi
Re: alternative 98 EV turn signals
« Reply #1 on: October 15, 2022, 07:55:50 AM »
Some Buells use a similar but more flexible stem.
Online Wayne Orwig
« Reply #2 on: October 15, 2022, 08:03:18 AM »
I'm looking into making replacements with my 3D printer.
Not sure it will work out.
Online Ncdan
« Reply #3 on: October 15, 2022, 09:02:33 AM »
This issue has been discussed number times in the past. Someone else suggested making the rubber part that always deteriorate, maybe out of a more durable material.
I’ve monkey rigged all four of mine on my 2002 Stone.
Please Wayne, by all means, if you have the capability to produce this part of the turn signal, make it happen!
Dan
Online Wayne Orwig
« Reply #4 on: October 15, 2022, 09:45:09 AM »
My plan is to make a fairly simple rigid internal metal piece, with a cheap cosmetic plastic cover.
But now that I am retired, I never have time to work on anything like this.  :rolleyes:
Offline bigbikerrick
« Reply #5 on: October 15, 2022, 03:02:50 PM »
I replaced the turn signal assemblies on a 2003 Cali Aluminum I used to own, with aftermarket ( Emgo, I think) turn signals meant for a Kawasaki Vulcan. The shape was very similar to the Oem Guzzi ones, and they mounted up with one bolt. I just had to make a small aluminum adapter plate with a hole in the center, to mount them up.
https://www.ebay.com/itm/314156317947?epid=171234366&hash=item49252cfcfb:g:MOIAAOSwsNhjKyiu&amdata=enc%3AAQAHAAAAsNj49z%2FfwxXv9fBDatKjUtndyPTmME6sInadZtsSEYQPMU%2B4GbRFsJ0kul5cQ%2BcMUsdZMGS2pNLGN%2BHZFJKkjGNTRpCfRqZu7GFmUnJGTxir5nmaflWeX3SGSq1SM%2BFlVnsMx48CRVcgR1EZJmWSf6sxrz319C%2Fbzrm7DAhPb14ioY8IpjjrDhUVaH0QJB59ql%2BTeQANrk2oIxcTjTv9P5TA1hfX3sP5MxG24Asy3lsq%7Ctkp%3ABk9SR5LVhdT7YA
Rick.
« Last Edit: October 15, 2022, 03:07:00 PM by bigbikerrick »
« Reply #6 on: October 16, 2022, 07:36:59 AM »
Dan
Yes, this issue has been discussed numerous times in the past and here we are again.
If anyone creates the STL files I have access to 100+ 3D printers that can produce parts in various materials including SLS/SLS/DLP and a few others....more than willing to help.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline kidsmoke
« Reply #7 on: October 17, 2022, 03:19:11 PM »
Jackal with 3D printed custom standoffs to blend the stalk radius. Metal housings on the directionals...
« Last Edit: October 17, 2022, 03:20:40 PM by kidsmoke »
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline Iron Cross Junction
  • Location: Just above Pott's Camp along Braddock's route, Va.
« Reply #8 on: October 17, 2022, 08:44:54 PM »
I do not understand the fuss about this.
My approach -- while admittedly a bit inelegant for the effete  :rolleyes: -- has worked just fine.
Soon, you’ll tell me that suspenders no longer meet the dress code at rallies.   :shocked:
Bill
P.S.  Not sure which pix, above, caused the lapover for this thread, but maybe the mods can reduce those.
Don't think it's from mine, but if so, let me know and I or mods can reduce those.
Bill Hagan
Proud Member of Moto Guzzi's Envy-of-the-Industry Post-Sale R&D Program!
1998 V11 EV [98 EV]
2004 V11 Ballabio, Sold; sigh
2007 Norge [NORJ], Sold; sigh
2010 Griso [GRISO], Sold; sigh
2016 Stornello [BEATA]
2017 V7 III [RADOŚĆ], Sold; sigh
2022 V85 Guardia
Offline Gusable
« Reply #9 on: October 17, 2022, 11:29:18 PM »
My 94 cali appears to have the same signals. They feel “loose” a little bit ( just like my 98ev) and I saw some tiny cracks. I coated the entire black stalk with 2 part clear epoxy to strengthen it and then shot it with a spritz of black rubber undercoating.  Looks great. Maybe it will give me some more time.
1994 California 1100
Offline larrys
« Reply #10 on: October 19, 2022, 07:50:12 AM »
My Cal turn signals have started to degrade. I put the front stalks on the back to bring in the turn signals, and shortened the rear stalks to about an inch long and put them on the front. When they crap out completely(not if) I will be looking for an alternative.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Online pehayes
« Reply #11 on: October 19, 2022, 12:50:15 PM »
It is basically a faulty design.  Not up to the task.  The stalk, although it looks like rubber, is not flexible.  Instead of dampening vibration loads, it merely transfers those loads.
The stalk is held in place by a single Allen screw at one end and a 'hook' of metal at the other which is bent at a 90 degree or "L" angle.  When new, these two components held the stalk firmly in place on the bike.  Over time and road vibration, the 'hook' is not strong enough and gradually begins to bend open.  Thus, that side of the stalk is no longer secure and the full load is transferred to the Allen screw and its threaded receiver.
The cure is to remove the stalk and rap on the 'hook' with enough hammer force to bend it back to its original, 90 degree angle.
Over time it happens again.  Rinse and repeat.  YMMV.
Online Wayne Orwig
« Reply #12 on: October 20, 2022, 09:50:20 AM »
On my 94 California 1100, they rubber held up and the hook bent as you show,
On my 2004 EV, the rubber has turned to dust. Nearly. As in even JB Weld can't patch it up too well.
Online Ncdan
« Reply #13 on: October 20, 2022, 11:46:56 AM »
As mine did, the rubber compound turns to a crumbling solid.
If someone with the capability to use a 3D printer and duplicate the rubber part with a solid nylon material, I’m thinking that would be a permanent fix.
I definitely don’t know the facts about the printer thing, I’m just speculating as to an acceptable fix.
Offline kidsmoke
« Reply #14 on: October 20, 2022, 02:14:23 PM »
The Indiana contingent is taking a stab at this. Will update when/if successful
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Online pehayes
« Reply #15 on: October 20, 2022, 09:59:02 PM »
3D printing should work nicely.  However, that embedded 90 degree hook is a different story.  :-(  Kudos to anyone who solves both simultaneously.
Online Ncdan
« Reply #16 on: October 21, 2022, 07:42:32 AM »
I don’t think the hook is a must. I obtained one that didn’t have the hook.
I applied a little epoxy and snugged the Allen head bolt down good and it’s held fine for the past year👍
Offline LaMojo
« Reply #17 on: October 21, 2022, 08:29:45 PM »
Used those on my Quota. Wiring was a little different but I used the Old ones spliced in.
Online Wayne Orwig
« Reply #18 on: November 16, 2022, 05:18:53 PM »
First step to printed parts.
Online Ncdan
« Reply #19 on: November 16, 2022, 06:56:48 PM »
Nice! When you get ready to release them to the members for sale, just let us know and put them in the swap meet.
I’ll take two right as soon as they are ready for release.
« Reply #20 on: November 17, 2022, 05:26:40 PM »
I sent a PM...thanks
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline adaven
  • 2024 Board Donor
« Reply #21 on: November 19, 2022, 11:43:44 AM »
So will I
Offline Gusable
« Reply #22 on: November 19, 2022, 12:22:13 PM »
I’ll take a set as well!
Online Wayne Orwig
« Reply #23 on: November 21, 2022, 03:16:53 PM »
I think it needs a label.
If I knew how I would put on the eagle.
 :evil:
Online Ncdan
« Reply #24 on: November 22, 2022, 04:44:28 PM »
 :evil:
Is that the finished product Wayne?
If so will they be going in the Swap Meet Section available for members to purchase soon?
I’ll be willing to receive a free set for experimental evaluation purposes🤔😂😂😂
Just kidding Sir. 👍
Online Wayne Orwig
« Reply #25 on: November 22, 2022, 05:32:26 PM »
Just kidding Sir. 👍
I'm not sure how I will manage it. But I am not in the game to make a profit. But of course, beer money is always good.  :evil:  I'm looking into it.
I still have a few glitches to work out.
I think I got a good eagle logo too.
This is the latest version.
« Reply #26 on: November 22, 2022, 05:38:10 PM »
Online Ncdan
« Reply #27 on: November 22, 2022, 05:58:35 PM »
You’re the man Wayne👍
Offline adaven
  • 2024 Board Donor
« Reply #28 on: November 22, 2022, 07:13:59 PM »
The eagle is a great touch
Online Wayne Orwig
« Reply #29 on: November 23, 2022, 05:34:15 PM »
First prototype installed.
These have a modified base to let them clear the fairing, which I have wanted for years.
