I’m all for fiddling to make improvements, to a point. But cutting a hole in your block to install a sight glass is just nuts. Move on, or buy a bike with one. Granted, they’re very convenient. But stick to your stick.
Wouldn't Moto Guzzi say to check the oil with the bike upright and level?
I recommend filling your bike to the level you want to run. then let it sit on the side stand overnight. In the morning pull the dipstick and mark the oil level with a band of white paint.Now the bike oil level is inspect able while on the side stand, requiring no assistance or leveling...
On what model did they NOT say that?!?(They say that on all the smallblock manuals I've read, and I thought there was true on my big blocks but it's been a decade or so ...)
I can't find any mention on the California's in the owners manual.-AJ
ENGINE MUST BE WARM TO CHECK ENGINE OIL LEVEL.NOTEDO NOT LET THE ENGINE IDLE WITH THE VEHICLE AT STANDSTILL TO WARM UP THE ENGINEOIL AND REACH THE OPERATING TEMPERATURE OF ENGINE OIL. OIL IS BEST CHECKEDAFTER RUNNING FOR ABOUT 15 KM (10 miles).• Shut off the engine.• Keep the vehicle upright with bothwheels on the ground.• Unscrew and remove the cap with dip-stick.• Clean dipstick.• Refit the cap with dipstick into its holewithout tightening.• Remove the cap with dipstick.
Engine oilCheckCAUTIONENGINE MUST BE WARM TO CHECK ENGINE OIL LEVEL.NOTEDO NOT LET THE ENGINE IDLE WITH THE VEHICLE AT STANDSTILL TO WARM UP THE ENGINEOIL AND REACH THE OPERATING TEMPERATURE OF ENGINE OIL. OIL IS BEST CHECKEDAFTER RUNNING FOR ABOUT 15 KM (10 miles).• Shut off the engine.• Keep the vehicle upright with bothwheels on the ground.• Unscrew the filler plug / oil dipstick.• Remove and clean the oil dipstick.• Re-insert the oil dipstick without tight-ening it.• Remove the oil dipstick again andcheck the oil level.'MAX' = maximum level.'MIN' = minimum level.• The oil level is correct when it is closeto the 'MAX' mark. Otherwise, top-upwith engine oil.
I guess it depends on where you download your manual from. I don't see any of that in the owners manual for the California EV on ThisOldTractor. Example, 2002 manual.-AJ
LUBRICATIONEngine lubricationChecking the oil level (fig. 23)Check the crankcase oil level every 500 km; the oilshould reach the «Max» mark on the dipstick «A». If theoil is below this level, top up with the recommended typeand grade of oil.N.B. - The oil level check should be carried outafter the engine has run for a few minutes: thedipstick plug «A» should be screwed up completely.
I find the “upright and both wheels on the ground” a bit confusing. Since most bikes don’t come with a stock center stand where the rear wheel would be lifted, are they saying I shouldn’t check my oil while popping a wheelie?
It could get complex…If you have the whole hole in the sump it will be to low ……Of course with the whole hole in the crankcase it’ll be to high.
Leaning on a center stand, the surface of the oil will be low on the right, and high on the left.
But won’t the bike be level laterally on the centrestand, therefore giving a level surface ?
…You’d most likely have to read the oil level at an angle, and either raise the sight glass on the left, or lower it farther into the sump on the right, like in that Le Mans photo.
I think I’ve come to the realisation that I’m more of a dipstick type of guy.. Remember Enos from the “Dukes of Hazzard…”
Better to be a dipstick than a dip$hit.
