Author Topic: Alternator belt replacement  (Read 1958 times)
Online Bigtime
« on: November 30, 2022, 09:04:18 AM »
  Hey everyone, getting ready to replace the alternator belt on my '09 Norge. Can I just unbolt the oil cooler and let it lay forward or does it have to be removed completely. Also any tips on the job is greatly appreciated.  JohnB
Re: Alternator belt replacement
« Reply #1 on: November 30, 2022, 09:11:54 AM »
I didn’t remove the oil cooler when I changed the belt. Not a difficult job, but I don’t remember the way to make sure the belt is properly adjusted. I’d do a search on here for that description.
Offline Huzo
« Reply #2 on: November 30, 2022, 09:48:17 AM »
I check mine every 20,000 km and replace it at each 90,000 km.
Mine is an easy job, because I have the forks out for the service so I have this view.
You won’t be in as far as this because that’s a cam chain replacement, but you get the idea. The front will be off when it gets home to fit the timing gears, so it will get it’s (slightly overdue) 3rd belt then.
I have always just used the method of twisting the belt 90 deg in situ. to check the adjustment. If you can comfortably do that with your fingers, I call it good.
A long Allen key is useful to reach the adjuster and I think the lock nut is 12 or 13 mm.
It seems easier with the tank off too.
Can’t think of anything else… :popcorn:
« Last Edit: November 30, 2022, 09:52:19 AM by Huzo »
Online Bigtime
« Reply #3 on: November 30, 2022, 11:14:13 AM »
  Thanks guys. Huzo, looking at your pic. makes me want a lift. I will have the wheel off for a tire change at the same time.
« Reply #4 on: November 30, 2022, 12:18:15 PM »
somewhere on here I posted about changing the belt on a Griso 1100, its a bit of a chore but can be done on the side of road if necessary no special tools required.
« Last Edit: November 30, 2022, 12:31:28 PM by Kiwi_Roy »
« Reply #5 on: November 30, 2022, 02:25:30 PM »
It’s not easy to get your tools in there. I can’t see it being done without the tank off. Getting to the locking bolt on the left side of generator is a pita but it must be loosened to get the tensioner bolt loose enough to get the belt on. Reaching that tensioner bolt is pretty tricky too. Plan on a couple hours and plenty of swear words to get it done.
Offline Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
« Reply #6 on: November 30, 2022, 02:30:02 PM »
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
Offline Nick
« Reply #7 on: November 30, 2022, 02:38:15 PM »
Check out these two posts:
https://wildguzzi.com/forum/index.php?topic=97424.0
https://wildguzzi.com/forum/index.php?topic=94469.0
They seem to address most of your questions.
Good luck, BTDT
Nick
Online Bigtime
« Reply #8 on: November 30, 2022, 04:41:00 PM »
  Thanks everyone. Everything was going well until I needed to get to the nut on the backside of the alternator to loosen it. I see no other way than to remove the tank and air box,a job I plan on doing later this winter. The belt looks good. Pretty amazing considering it's almost 14 years old. I guess today was a good practice run.  :grin:  Again thanks everyone.
Offline Scott of the Sahara
« Reply #9 on: November 30, 2022, 06:44:43 PM »
I bought a new alternator belt but never replaced it. The Norge had 46,000 miles on it when I crashed and totaled it. When I checked the belt before my last trip it was pristine.
