Author Topic: Electric Start  (Read 4795 times)
Offline SmithSwede
  • I don't want a pickle
Re: Electric Start
« Reply #30 on: January 06, 2023, 09:45:32 PM »
I have a Luddite streak in me, and distinctly remember my various kick start bikes, including a Yamaha RD400 two stroke. Which was what, about a 6:1 compression ratio?
I used to think it was the manly cool thing to kick start.   Who needs all that extra weight of a starter motor, big battery, etc.?
Real motorsickles are kick start.  Cars are what have lectric starters.
Then I got a Honda CB550F with electric start.   Never really looked back.
My right ankle is suboptimal—not sure I could still do the kick start routine
« Last Edit: January 06, 2023, 09:46:37 PM by SmithSwede »
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline Petrus Rocks
Re: Electric Start
« Reply #31 on: January 07, 2023, 10:16:58 AM »
All my dirt bikes are kick (6)-Yammie TT500 and Husqvarna 410 were the worst.  I became proficient with the single lung four stroke drill.  Compression release in, wide open throttle, kill switch on, kick it through 6-10 times (Do ya feel lucky, punk?).  Close throttle, ignition on, kick firmly.  Usually worked...
On the street, My Velocette requires choke on (or a tickle of the previous Amal), Decompression lever in, ignition off, two kicks, ease kicker down 1/2 stroke past compression, ignition on, kick and Voila!  With a modern carb and electronic ignition almost always first kick.  Starts well when warm too.
My Triumph 750 gets the carbs tickled and 1 to 3 kicks cold and usually 1 kick warm.
My Maico 400 is the hardest bike I have to start.  I installed a primer because the original Bing had a tickler.  Big bore two strokes like a bit of raw fuel to start.  Compression release in, kick and kick and kick.  When you're wiped out from kicking get someone to push start you.
Online Moparnut72
Re: Electric Start
« Reply #32 on: January 08, 2023, 10:50:48 AM »
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
