Tom, Not sure I would pick a tall GS as a sidecar bike...connected to a sidecar you'll end up with a higher center of gravity. I know they have been successfully mated by people, but in my experience, I think lower is better. A standard airhead should be a better outfit. Sorry the Bonneville didn't work out, but guess it needed more work than it was worth in the end. My friend has a '91 GS which is a very nice solo machine...some of the points mentioned before about airheads are relevant, but I don't think there is much of anything that couldn't be remedied or upgraded on these machines, whenever they need it, not before they need it though.Good luck with the hunt.Tom
2 things to watch for- The paralever driveshaft U-Joints tend to go between 30k and 60k miles and from around 1985 to 1995 BMW omitted a thrust washer in the transmission and that caused early bearing failure.
You can still buy basically that same motorcycle new, only improved in every way, a V85TT.
As an owner of both, I would dispute that it’s improved in every way despite buying the V85TT for exactly that reason. After some experience in owning both as a 35 year Guzzi owner I think I prefer the R100GS for its simplicity, rugged and durable construction, light weight and better balance. The V85TT has more modern equipment (with little practical benefit and some downsides), more power (but less bottom end torque), and much better OEM brakes.
Maybe not "in every way", but most IMO. 19" or 21", I'm fine with either on bikes like this. I believe the 1991 on R100GS was about the same 500# as the V85. As mentioned the V85 has much nicer brakes, similar egos, slightly more powerful, better lights, cruise, FI and better mpg, 6-speed vs 5, and overall more reliable (especially drive shaft and transmission). I loved my R100GS and two years ago when looking back at all the bikes I've owned it was maybe my favorite, which is what got me interested in the V85TT.
...I think the TT is a good bike, I like mine, but it’s not a R100GS....
