Author Topic: Do you carry tools?  (Read 5017 times)
Online PeteS
Re: Do you carry tools?
« Reply #30 on: January 17, 2023, 08:54:00 AM »
BMW tool kit covers the 4 metric bikes. My first cross country trip on my ‘71 Norton, the clutch came off. Now I carry a homemade clutch tool. Probably not needed as it now has the locking washer in the nut which the ‘71s didn’t come with.
Offline Zenermaniac
« Reply #31 on: January 17, 2023, 09:41:17 AM »
Google Slime compressor, I have one but I went to the even more compact C02 cannister and aluminum fitting
I have the Slime compressor but it’s too big for my liking. How many CO2 canisters does it take to fill a tire?
Offline Roebling3
« Reply #32 on: January 17, 2023, 10:44:46 AM »
I retired 2/2009. 72 years on the road and still counting. 8.37 million miles in North America, Canada, Switzerland, France, Belgium, Netherlands et. al. I never bothered about how many miles were ridden on MC's. The logged miles were betwixt big trucks and cars.
I have done 11 Bunn Burner Gold's, + 100 miles added to each. (add 100 to 1500 in 24hrs. and you can get very cool 'Grosjean numbers). I rode MC's whenever and wherever I could. I had a 'Just show up and take one' in France, Belgium & Switzerland.
Except for 3X I never needed any of the large number of tools I carried for work related reasons. I used to fly commercially for repairs, installs, sales and trade shows.
At some very late way point I realized there was seldom a need for 3 types of Freon, vacuum pump, welding equip. bearings, etc. I nearly emptied the trunk.
Clients in Europe always had what I needed - regardless. I've had one flat on a motorcycle - in my garage! Lost a clutch within a block of home.
I've not carried any tools for more than 30 years. In most ways I'm the luckiest guy I know.
You can plan - of course. Save yourself real grief! Don't ride motorcycles with 2 sided shaft drives. Don't ride on wire wheels - unless you have those hi-zoot rims, w/no tubes. Don't ride with plastic parts in your fuel line. i.e. pumps - filters.  Good fortune,  R3~
« Reply #33 on: January 17, 2023, 11:51:39 AM »
Yes.  And a tire plug kit with mini air compressor.
I've needed the tire plug kit more often than the tools.
I keep all that in my tank bag, move it from bike to bike.  But my Ducati, it has special sockets for each wheel as well as well as needing 1/2 ratchet drive for Torx & C-wrench to adjust the chain.  it's easy, so long as you have the peculiar tools.
Offline ScepticalScotty
    • South East Massive
« Reply #34 on: January 17, 2023, 12:16:00 PM »
All the time - the standard kit that came with the Breva 750 plus what I have added to it. Of course, now it doesn't fit under the seat and I have to fit the panniers, but thats no bother. Or if you are Scottish, nae bother ava!
Scotty
Thomas Paine
Online Dr. Enzo Toma
« Reply #35 on: January 17, 2023, 01:34:24 PM »
This is my V7 Stone e5 kit:
I have a similar kit pieced together for each one of my motorcycles that see more use than just around town. I use the travel toolkit to do most of the work and maintenance on the bike, to make sure the tools are useful should they be needed. They are mostly things I purchased a la carte from Tekton on a few other tool makers. The DynaPlug micro inflator and plug kit gets moved between bikes so I don't need to own so many of them. This whole kit fits quite nicely in the bottom layer of one of my panniers for travel.
I replaced the brake and clutch lever with adjustable ones, so I also carry the OEM levers when touring so I have them as spares.
« Last Edit: January 17, 2023, 01:35:06 PM by Enzo Toma »
2027 Moto Guzzi V7 Sport
MGNOC Member
Offline Perazzimx14
« Reply #36 on: January 17, 2023, 03:13:06 PM »
In the motorcycle world the tool roll is a badge of honor. You're not a serious biker until you have a least a 35lb tool roll with enough different tools, tie wire, epoxy, tape and zip ties in it to rebuild at least 9 different motorcycles. It really doesn't matter if you know how to use any of these things as long as you have them, you'll be fine if there is a failure along the road.
While I do carry a few tools its nothing crazy. More important to carry is a tire repair kit and pump and most importantly know how to use it.
Follow up questions:
1. Out of those who carry tools how often do you used them when out riding your? Tire repair kits and tools to adjust a chain do not apply.
2. Out of all the tool you carry home many of them have never been used?
« Last Edit: January 18, 2023, 10:15:55 AM by Perazzimx14 »
Online AJ Huff
« Reply #37 on: January 17, 2023, 03:45:01 PM »
Nope.
I wouldn't know what to do with them if I had them with me, so what's the point. Phone and credit card.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
« Reply #38 on: January 18, 2023, 07:53:10 PM »
Things I carry that I have used:
Clutch cable (twice - 72 Eldorado and 2006 KLR 650)
Throttle cable(s) - once Eldorado
condenser - Twice Eldorado
Zip ties - many times, mostly holding broken plastic back on the KLR
JB Weld metal putty - once to repair cracked crankcase on a KLR
Electrical wire- a couple times to by patch up busted off tail light, handlebar switch etc.
booster cables, several times to boost a dead battery
Air compressor to bring tire pressure back up after leaving the sand trails - KLR
Brake lever - once KLR
Multimeter - a couple times to diagnose other dead bikes, two were Harleys.
Tire irons to remove a tire to patch a tube, several KLR
Tire patch kit, compressor several times.
Nuts and bolts, replacing missing fasteners after a couple thousand kilometres of rough gravel roads.
I wouldn’t be without a good Philips and flat head screwdriver and enough wrenches to remove a wheel, fuel tank and seat.
Offline MotoG5
« Reply #39 on: January 18, 2023, 08:37:58 PM »
Always,
Old tank bag with tire plug kit, air pump, tool kit (my own selection based on past experience), shop rag and what ever I think I may need at the time. Rain suit if it looks possible to need it. I only do day rides now so I wont go into what I used to carry on my previous road bikes for long hauls. I consider this stuff a good idea for now as even a good day ride can get me a couple of hundred miles from home round trip.
Nebraska MGNOC State Rep
Offline egschade
« Reply #40 on: January 19, 2023, 11:46:30 AM »
Many mentions of mini-compressors.
Just how small are these pumps?
I carry the Slime power sport pack which is roughly 6x6x2 and has room for plugs in the case. Used it one and it worked fine for a motorcycle tire. Pretty low volume so a car tire would take a long time.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Perazzimx14
« Reply #41 on: January 19, 2023, 12:59:26 PM »
I carry and use DynaPlug pumps on my motorcycles. Fit in the palm of your hand and work a treat. Most of the 12v mini tire inflators if you remove the plastic shell are very similar as far as pump and motor.
« Reply #42 on: January 19, 2023, 01:10:10 PM »
Might get one of them tool roll things - the bags from 2004 are looking a bit ratty.
Scotty
Thomas Paine
Offline ChrisG
« Reply #43 on: January 19, 2023, 03:11:34 PM »
This comes with a V7 Stone 850. What more could one possibly need?
Current: 2022 V7 Stone 850
Gone: 96 California 1100i, 2008 Breva 750, 06 Breva 1100, 2007 Sportster,1971 BMW 75/5, 1969 Triumph Trophy
Forgotten: A couple Hondas, a Yamamaha, ??
Offline bobrebos1
« Reply #44 on: January 19, 2023, 03:14:38 PM »
I have added carrying a can of electric contact spray cleaner with my 2021 V7 due to the crappy ignition switch!  Geez it’s always something!  Lol
Sober, Retired Air Force!
« Reply #45 on: January 19, 2023, 04:02:30 PM »
http://www.dynaplug.com/microproinflator.html
Offline DougG
« Reply #46 on: January 19, 2023, 04:18:49 PM »
Hi Scout,        1-19-23
Tool kit, puncture kit, water and first aid kit.  Luckily I've never had to use them but on two occasions I helped other riders.
Be well, stay well,
DougG
Offline Perazzimx14
« Reply #47 on: January 19, 2023, 05:22:04 PM »
Honestly probably not a lot other than a credit card and a cell phone. If a component breaks/fails on the road unless you have a replacement with you and the ability to replace all the tools in the world are useless.
Offline s1120
« Reply #48 on: January 20, 2023, 04:10:32 AM »
Hi Scout,        1-19-23
Be well, stay well,
DougG
Really in my experience I would get far more use out of a first aid kit then the tool kit. Not for anything major, but I have got cuts, and scratches that just will not stop bleeding far more then I have needed any tools.
Paul B
Offline Perazzimx14
« Reply #49 on: January 20, 2023, 05:01:50 AM »
Shame is 3 or 4 years go Cycle Gear had them for $19.99 now they are $69.99. Glad I bought as many as I did when I did :thumb:
Online Bulldog9
« Reply #50 on: January 20, 2023, 06:42:10 AM »
Always. I used to plus up the 'oem' tool kit with the extras, but several years ago bought this https://www.rrrtoolsolutions.com/adventure-tools.php super compact and so far useful. I also carry a stopngo plug kit with pump.
I have both in a small carry bag that also contains extra bulbs, zip ties, electrical tape, crimp connectors, a small multimeter, specific tools to change a tire and spark plug and portable battery jumper pack thingy. Also carry a first aid kit with compression dressings with chitosan. This goes in a saddlebag and I will throw in the trunk of the Porsche or Mustang. I run rideon sealer in all my tires which has been helpful in several situations where I picked up a nail or screw. Not helpful in situations like I had on my Novi Scotia ride several years ago when I ran over something on a gravel road chasing lighthouses that tore a chunk out of the rear tire and sliced the front down to the chords.
The Griso is the only bike I have without a saddle bag, but I don't do more than day trip thugging around on it.
« Last Edit: January 20, 2023, 06:44:23 AM by Bulldog9 »
MGNOC#23231
Offline pebra
« Reply #51 on: January 20, 2023, 09:23:43 AM »
Nope.
-AJ
Yeah, I'm mostly there  :grin:
Those Guzzis are so reliable I've hardly ever missed tools.
At times, on long trips, I carry just a few screwdrivers, hex keys, pliers, zip ties, tape - - - -  Come to use just once.
A clutch wire if I have one.
2009 Griso 8V "Weißgerät"
Offline Steph
  • Cali Stone/ LM3
« Reply #52 on: January 20, 2023, 09:54:41 AM »
I carry a full set, under the seat, on the older bike and recently added a Knipex 150mm wrench pliers after seeing them in this video: https://youtu.be/T2D49jEVIrk
« Last Edit: January 20, 2023, 09:58:34 AM by Steph »
« Reply #53 on: January 20, 2023, 10:05:13 AM »
Don't even try to buy Plexis now... $30.  Even the Pink can is $14, double the last time I bought some.
Offline tommy2cyl
« Reply #54 on: January 20, 2023, 10:52:03 AM »
Bought new tubeless wheels for my 2020 V 85 so eliminated spare tubes & tools to change tubes.   Carry 2 sockets, ratchet and round metal tube (leverage bar) to be able to remove front and rear wheels.  A few other small sockets,  3 open wrenches, Phillips and flat screw drivers, air pump and tire plug kit.
Small roll of duct tape and a few zip ties.  Any repair requiring more than that it is pull out the credit card and make a phone call time.
When doing back country camping trips on the DR 350, tire irons and spare tubes are back on the list.
Offline tommy2cyl
« Reply #55 on: January 20, 2023, 10:56:30 AM »
...and a multi allen head tool.    ....oh, and Leatherman in my saddleback.   :thumb:
Offline Perazzimx14
« Reply #56 on: January 20, 2023, 11:09:34 AM »
Even when it was less expensive Plexus was too expensive.  I'm good with $4 a can Trueliving lemon furniture polish from Dollar General. Heck I don't even see the advantage of spending $5.75 a can for lemon Pledge.
