Author Topic: V85TT info required?  (Read 9356 times)
Offline Bison
Re: V85TT info required?
« Reply #30 on: January 27, 2023, 09:53:07 AM »
Huzo, erudite and correct as ever, thanks.
I measured the stand by putting spacers underneath the foot, it's way too short, I measure 25cm from pivot bolt to foot, straight along the shaft of the stand, when I have it at what I deem to be a close to good angle, I measure 30cm, that's almost 2" it could do with being lengthened!. The pivot bolt has a little play in it, but I mean a little, could be it's going a bit too far forward, but not anywhere near that much. Does anyone know if the Stelvio stand is longer?.
I still have my LM111, so hopefully I will be allowed to stay within the fold?.
Alan.
Offline Vagrant
« Reply #31 on: January 27, 2023, 10:04:06 AM »
Drop the forks a 1/2" . Simpler!
Offline Bison
« Reply #32 on: January 27, 2023, 12:58:28 PM »
Because of the handlebar arrangement on the Norge I don't think it's possible to drop the forks.
Alan.
« Reply #33 on: January 27, 2023, 01:05:57 PM »
I’d try raising the forks…
« Reply #34 on: January 27, 2023, 01:23:34 PM »
Alan.
Okay..
Make sure that the plate that your sidestand is bolted to, is still firmly bolted to the engine crankcase.
Also it is prudent to check that your stand is not going too far past the point where the spring overcentres. If it is, it can be cured in the time honoured fashion, by removing the stand and applying a small dab of weld either on the stand or (preferably) on the mounting plate.
Ensure that the pivot bolt is greased and very well tightened, before nipping up the locknut, which seems to be perpetually loose…(I lockwired mine).
BTW.
I have lengthened my Norge sidestand by 30 mm. You COULD lengthen yours by 30 cm as you say, but that seems a touch excessive… :grin: :thumb:
But you’re right, length is important
You can see the extra length and steepened angle in this shot.
« Reply #35 on: January 27, 2023, 01:24:58 PM »
Alan.
Correct, unless you want to machine away the step in the top crown.
Offline Bison
« Reply #36 on: January 29, 2023, 04:45:23 PM »
Thanks all,
I'll double check all the stand fastenings tomorrow.
I've taken the plunge and bought a V85TT, looking forward to getting it.
I'll keep my Norge at the moment.
Alan.
« Reply #37 on: January 29, 2023, 05:27:31 PM »
Thanks all,
Alan.
« Reply #38 on: January 29, 2023, 08:16:40 PM »
Thanks all,
Alan.
Good for you Bison… :thumb:
Please ask a million questions, but start your own thread like “Bison’s Bike” or something and we’ll all know to look for you questions and impressions there.
Should be good.
Offline Bison
« Reply #39 on: February 02, 2023, 04:45:21 AM »
Will do Huzo, as soon as I have some input.
Alan.
