Author Topic: Calvin shorter clutch cable  (Read 2028 times)
Offline lazlokovacs
« on: February 07, 2023, 02:05:58 PM »
I know that they started to change the fittings on the end of that clutch cable that goes through the transmission boss at some point in the 90s.... anyone know of a shorter clutch cable that will fit a Calvin 2006
Long shot but someone might know!!!
Re: Calvin shorter clutch cable
« Reply #1 on: February 07, 2023, 03:35:32 PM »
I think yours threads in like my EVT. I needed a longer cable, used one for a Loop. The trans end does not need to be threaded in, the Loop one just slides in. I don't remember for sure, but I may have used a spacer to center the cable in the hand lever. The barrel fit the hand lever.
Hope this helps,
« Reply #2 on: February 07, 2023, 04:20:32 PM »
Try one from a Special Sport or Bassa, should work.
