Author Topic: Leaking head gasket  (Read 685 times)
Offline Pescatore
Leaking head gasket
« on: February 08, 2023, 03:22:43 PM »
I am preparing to remove the left side head on a 1991 V65 with 21,000 miles.  It leaks oil and it's spreading all the way to the swing arm.
Compression is still 150psi on both sides when cold.
From the posts I have read, it seems a straight forward job.  I am armed with workshop manual and Guzziology.
I am expecting the head will not come off easily.  My question is about the cylinder base gasket.  It does not leak and I worry that prying the head off will compromise that joint.
What is the best way to remove the head without consequences?  Or is it a crapshoot?
The right side head is clean, so I don't plan on opening it.  However, I plan on taking the left head to a machine shop and have it taken apart, cleaned and checked out.
Does it make sense to remove the other head as well?  I guess I can do it at a later time, if I see differences in performance of the two sides.
2008 Norge 1200
1991 Sessantacinque GT
1980 CM400T
MGNOC Member
Offline cappisj1
Re: Leaking head gasket
« Reply #1 on: February 08, 2023, 03:47:51 PM »
Why you are at it… I would treat both sides to refurbished heads, head gaskets and base gaskets. You will be much happier in the end. The bike will be easier to tune and run much better in the end if you do both sides at once.
But if you only want to do one side you can probably not worry about the base gasket. But you’re only 15 minutes from pulling the jug, replacing the gasket and sliding the jug back on. Just need to collapse the rings when sliding it back on. If you don’t do it now it’s an afternoon worth of work to get back to the base gasket.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: February 08, 2023, 04:17:49 PM »
Mind you, I’m only speaking from limited experience with a much newer V7 II, but I would have an extra base gasket on hand as a backup, and have a second set of hands hold down the cylinder while you take a combination of dowel, mallet, and prying device to work at the head.
« Last Edit: February 08, 2023, 04:18:51 PM by Dirk_S »
Current: ‘16 Guzzi V7 II Stone, ‘78 BMW R80/7
Previous: ‘15 Ural Gear Up, ‘77 Kawasaki KZ400 Special, ‘78 Honda CX500S, ‘80 Honda CX500D, ‘11 Suzuki TU250X
Offline FarmallA
« Reply #3 on: February 08, 2023, 04:19:19 PM »
When I first got my V65 Mongrel LaMonza  (Monza frame, Lemans tank, V65motor), the PO pointed out a leak from the right side jug, he thought it was the head gasket.  Turns out it was only the rocker cover gasket folded over.
But I assume you've checked that.
FarmallA
Steve
« Reply #4 on: February 08, 2023, 05:12:45 PM »
FarmallA
Steve
Good comment….
Offline Scout63
« Reply #5 on: February 08, 2023, 09:19:23 PM »
Compared to that gearbox this is cake Maurilio. I wouldn’t freshen one head and not the other. Don’t forget that breather hoses come out of the back of the heads on the small blocks and into the air cleaner   Check to make sure that a hose isn’t cracked and blowing out oil by just removing the rocker cover. Also, gently tap the head with a hide or rubber mallet to loosen it. Don’t pry.
Ben Zehnder - Orleans, MA USA
‘46 Rapide ‘69 Ducati 450 Scrambler ‘71 R75/5 ‘72 Combat Commando ‘73 v7 Sport project
‘77 Laverda Jota project ‘77 Ducati 860GTS
‘78 Ducati 900SS ‘78 SR500 ‘82 Laverda Montjuic project ‘98 Ducati 916
 ‘02 MV Agusta F4 750 ‘19 Husky Vitpilen
Offline normzone
  • '72 Eldo - 1980 to 1990 - '99 Bassa 2014 - ?
« Reply #6 on: February 10, 2023, 08:59:57 AM »
Only commenting to say that also, breaking fins is unfortunately easy ...  :angry:
Offline nsmith
« Reply #7 on: February 10, 2023, 09:25:19 AM »
Never tried it but what would happen if after removing the push rods and of course the nuts and bolts you put the sparkplug in and crank the motor over? 150 psi should blow the head clean off as Dirty Harry would say.
Neil formally from South Dakota now living it up in Arkansas
Offline acguzzi
« Reply #8 on: February 10, 2023, 11:01:00 AM »
probably separate the assembly at the base gasket unfortunately since it's the smaller of the two, neat idea though!
Offline guido guzzi
  • No Ragrets
« Reply #9 on: February 10, 2023, 12:27:41 PM »
Hold my beer... :grin:
Ezek. 25:17
Offline n3303j
  • Ron Cichowski
« Reply #10 on: February 10, 2023, 01:30:16 PM »
Hold my beer!
Was when you just loosen all the head nuts about 1 millimeter and crank it over live. Each cylinder fires once and the heads are free!
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Scout63
« Reply #11 on: February 10, 2023, 04:46:16 PM »
Ear muffs Pescatore.
Offline Murray
« Reply #12 on: February 10, 2023, 04:52:55 PM »
Hold my beer!
Well you could go a threaded compression tester and some compressed air, I'd leave the head bolts in a few threads. Not sure about the V65 but on the old square fin big blocks there is a blanking plug that allows access to a head bolt (I think) sealed with an o-rung. When that leaks it looks remarkably like a head gasket.
Online Frenchfrog
« Reply #13 on: February 11, 2023, 07:06:48 AM »
Nothing like that on the smallblocs
Offline Pescatore
« Reply #14 on: February 11, 2023, 01:42:49 PM »
This is getting very entertaining. I'm holding the beer, nsmith.  Did it work?
Compressed air from the spark plug is interesting too.
Thanks for the tips, folks. I was thinking about prying the head, so I won't push on the fins.  Holding the cylinder makes sense.  Compressed air should keep the cylinder down as well.
I have a whole gasket kit from Scout63 and the valve cover gasket is dry.
I'm overthinking it because I'm in the camp of not fixing what's not broken. And I've been tearing and rebuilding this bike for the past 4 winters.  Exactly one year ago, Scout63 helped me fix the gear box.
And there's more to do.  Front shocks seals and a leaky carburetor plug. No idea what to do on the latter.
Anyway, I have tools, manuals, parts, space, support, money and no flipping time to do it.
So it might take a while, but I'll git'er done.
2008 Norge 1200
1980 CM400T
MGNOC Member
« Reply #15 on: February 11, 2023, 03:09:17 PM »
Wouldn’t you need to leave the pushrods in or else there’ll be no mixture in there to compress, since the inlet valve won’t open.
While we’re having fun…
If your cylinder swept volume is 325 cc and compression ratio is 10:1, you would have 32 cc volume in the combustion chamber (give or take).
Just upend 50 cc of oil in the pot, remove the exhaust pushrod, remove the head retaining nuts, put the plug back in and fire it on the live one….!
The hydraulic lock should bash it free….. (what could possibly go wrong..?) :popcorn: :grin: :thumb:
« Last Edit: February 11, 2023, 03:40:10 PM by Huzo »
Offline Vagrant
« Reply #16 on: February 11, 2023, 04:24:55 PM »
Finger nail polish should stop the plug leak.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Offline sign216
« Reply #17 on: February 11, 2023, 04:48:09 PM »
I recall Richardson talked about smallblock head gasket leaks.  Here is my summary, from another website;
Head Gasket Leaks - The distance between the studs is long and the gasket web is thin, so leaks happen, especially on the outward side near the oil passage. I've solved leaks with Permatex Super 300, as recommended in Guzziology by Dave Richardson.
Take off the head, apply Super 300 to both sides of the head gasket with a little extra in the problematic bottom part, near the oil passage. Wait a short time for it get tacky, and bolt everything back up. I've had luck re-using the old gasket if it looks decent. Torque again.
Base Gasket Leak - Richardson reports that a during manufacturing a drilled stud hole can break into an oil passage, causing base gasket leaks. The fix is to clean the hole, seal stud with Loctite, and reassemble. I refer you to Guzziology for photos and details.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Pescatore
« Reply #18 on: February 11, 2023, 09:21:29 PM »
I was thinking I don't need ignition, just the piston compression. Your idea sounds more fun, Huzo.
That's one way of decorating the bike with oil and  shooting the head across the garage.
Thanks for the Guzziology reference.
I remember reading about the Permatex for valve covers as well.
Does Permatex harden and make it difficult to remove the gasket later?
2008 Norge 1200
1980 CM400T
MGNOC Member
Offline sign216
« Reply #19 on: February 12, 2023, 04:31:26 AM »
Reportedly Permatex does not harden, but nothing is eternal, right?  I used it years ago, and I would say it slooowly hardens, over years.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #20 on: February 12, 2023, 09:06:17 AM »
We used to use it on iron exhaust manifolds when they had a divot on the sealing flange or were warped and wouldn’t seal with a new gasket. In that application it got hard and generally worked well.
Harper's Moto Guzzi : Go Ride, Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
Quad Lock - The best phone mount system for your motorcycles!!
