Did you guys watch the same video as me?? I'll give you that this test wasn't exactly perfect, but going by it, opening the shield and or vent made things no better. Contrary to what might be expected, just opening the helmet up to the atmosphere, as you are describing did not help.
So if I am understanding the video correctly, when you are moving, everything is fine. When stopped, if you have a chin curtain, keep your visor closed, and lack chin vents - like in the video - the CO2 level can reach a level that is unhealthy. At least unhealthy if you are exposed to it for an extended period of time. Conclusion: Buy a helmet with chin vents and open your visor when stopped.
It’s the decline of cognitive function that comes with hypoxia that is the most concerning for me.
Hmmm, I had one on my last helmet. That explains a lot..
Makes the 3/4 helmet look good??????>
Good grief....does anyone actually worry about this "issue"?
I'd be more interested if he had measured blood oxygen levels.-AJ
Yep, he should include a pulse oximeter in his test.
Assuming you have a pulse oximeter, it would be simple to look for an effect on your own. That is, unless you pass out!
