Author Topic: Redneck bike lift for the V9  (Read 2168 times)
Offline Zenermaniac
« on: February 22, 2023, 05:55:55 PM »
I’m a tightwad and I’ve never been accused of elegant handiwork so here is my quickly cobbled together bike lift made up of scrap I had laying around. It is similar to some of the YouTube vids for Harleys and other cruisers. The problem with those is since the V9 exhaust hangs below the frame, etc a variation has to be made. As I said this was just cobbled together with junk on hand so I know it doesn’t look as refined as some of you are capable of. I used a 4x4 post and cut a couple pieces about 6-1/4” off and stacked it with a couple brackets on top to hook on the crossmember of the frame that the accessory center stand pivots on. The scrape carpet on top protects the paint. All held together with long screws. The pictures should explain it all. The eyelets are for straps attached to the bike for safety.  You insert it under the bike with the base toward the rear wheel and make sure you hook the front side of the crossmember but avoid the cable bundle on the left side. Straighten the bike up and rotate the handle back. Voila! If you need the front wheel up just lift the front wheel and place a block under the engine.
I can’t say for sure it will work with the carbon canister in place as mine must have (cough, cough) fallen off somewhere. If you copy this you are responsible for your own craftsmanship and injuries. Click on the photos to expand the view - I don’t know why they were small.
Offline SIR REAL ED
  • uh.... it's personal....
Re: Redneck bike lift for the V9
« Reply #1 on: February 22, 2023, 06:20:41 PM »
Looks good.  I approve of your redneck credentials!!!
I've enjoyed all the redneck jokes and pictures of redneck solutions one sees on the internet.  but if you boil it all down, rednecks are natural born problems solvers.
Not only that, but they are also usually the first ones to help out in a pinch!!
2019 Beta EVO 250
Online bad Chad
« Reply #2 on: February 22, 2023, 07:14:52 PM »
I have to call you on that Sir Real Ed.  Many, many Red Necks are great folks, but I have met plenty who are not.
However, it just goes to show, don't pre judge people based on their appearance.
Offline Texas Turnip
« Reply #3 on: February 22, 2023, 07:23:53 PM »
Today here in Texas was a red neck weather day with the temp 80 degrees. My attire was bib overalls with the side buttons undone, a Guzzi t shirt and shoes.
Tex
« Reply #4 on: February 23, 2023, 06:58:17 AM »
‘Y’all are not from around here”  is when I walk away as it never ends well.
Offline guzziart
« Reply #5 on: February 23, 2023, 02:13:19 PM »
Hey Zenermaniac,
Nice job and the price is right, I like it!   :thumb:
Art
Offline SIR REAL ED
« Reply #6 on: February 24, 2023, 07:28:56 AM »
Agreed.
I was talking about a state of mind, not an appearance.
But it also helps to be able to speak the lingo.  Same as with the PhD. crowd!   :wink:
« Last Edit: February 24, 2023, 07:31:02 AM by SIR REAL ED »
2019 Beta EVO 250
Offline SIR REAL ED
« Reply #7 on: February 24, 2023, 07:30:06 AM »
Tex
A Guzzi t-shirt while also going commando, right?   :wink:
2019 Beta EVO 250
Offline SIR REAL ED
« Reply #8 on: February 24, 2023, 07:35:01 AM »
Not to be pedantic, but the above should read "Y'all ain't from round here!"
And remember: "Y'all" is singular.  "All Y'all" is plural.
2019 Beta EVO 250
Offline Navydad
« Reply #9 on: February 24, 2023, 12:05:37 PM »
Not just Redneck, but perhaps a farmer in a past life.  :thumb: I can think of a Kawasaki that could use something like that.
