Author Topic: Bought an R80/7  (Read 7052 times)
Offline Perazzimx14
Re: Bought an R80/7
« Reply #30 on: March 28, 2023, 06:07:36 PM »
Nice part of the deal is you can pull the transmission without crabbing the frame.
Cribbing is using stacked dunnage to support a structure. Crabbing is a form of fishing.
Offline n3303j
  • Ron Cichowski
Re: Bought an R80/7
« Reply #31 on: March 28, 2023, 06:14:54 PM »
Never cribbed (sp?) or crabbed. I support the engine in a copy of the MG engine stand and lift the bike off the top with two hoists over the machine. I can precision lower the bike on the engine at reassembly.
I tried crabbing and did not feel confident in the procedure or the shaky result.
I probably did it wrong.
I'd probably try it if I had an on the road failure.
But not in my shop.
I think everyone here calls it "crabbing" the frame?
« Last Edit: March 28, 2023, 06:33:49 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online moto
  • Fear the deer!
Re: Bought an R80/7
« Reply #32 on: March 30, 2023, 03:21:24 PM »
From wordreference.com:
Collins Concise English Dictionary © HarperCollins Publishers::
crab /kræb/ n
    a mechanical lifting device, esp the travelling hoist of a gantry crane
This seems to be the meaning for "crabbing the frame." By contrast, the engine, left on the floor, supported by something, is cribbed.
Proper usage is everything on WildGuzzi.
850 T-3
Griso 1100 corretto
Offline n3303j
  • Ron Cichowski
Re: Bought an R80/7
« Reply #33 on: March 30, 2023, 03:38:56 PM »
Close but "No Cigar".
This is "cribbing". I do not do that when I lift the bike off the engine.
This is "cradling". It is how I support the engine  when I lift the bike off the engine.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Bought an R80/7
« Reply #34 on: April 02, 2023, 08:47:22 PM »
This weekend I installed the new battery. I heard those stock batteries require a heaping amount of snot and force to get them out, but jeez. I was yanking and pulling and trying to find any which angle I could. Finally got her out after removing the subframe bolts. I wonder if that battery might’ve actually been slightly off from the stock size.
Also changed the fluid—driveshaft was nearly dry. Final drive was dark. Transmission was darker, and the engine oil was…water, for about half a liter. Pulled  the spark plugs and peered inside with a flashlight—saw *some* spots of surface rust; didn’t look terrible, but I’m not sure what actually amounts to “terrible”. Squirted some WD40 into the holes and closed them back up.
Removed the airbox to reveal what we all might have expected, but nonetheless, it was a first for any of my previously owned 70s bikes:
Little stinkers had nearly the whole intake packed with insulation, cotton, and acorns. I imagine this is quite common on forgotten airheads. Thankfully the filter hadn’t been chewed through, so it didn’t appear that anything got down into the carbs. Good thing the seller gave me the wrong key, because I might’ve tried to start the bike up with all that junk stashed inside.
Next on the to-do list: drain that gas and drop those bowls. So far, it feels fun going back to an old, carbureted bike after 8 years of fuel injection. Any wagers how long that fun lasts?
« Last Edit: April 02, 2023, 09:52:55 PM by Dirk_S »
Offline Scout63
Re: Bought an R80/7
« Reply #35 on: April 02, 2023, 09:26:47 PM »
I think most every older bike I’ve gotten has had some level of nesting, but that one takes the cake.  Those fabric covered lines will probably leak badly and should be replaced. Green scotch-brite pads and WD-40, or better yet AC-50, will quickly bring the aluminum cases into nice shape. Usually, if you remove the 10mm bolts on the back sides. of the battery box, it will pivot to the rear and you can barely slide the battery out the top.
Ben Zehnder - Orleans, MA USA
Offline Stretch
Re: Bought an R80/7
« Reply #36 on: April 02, 2023, 09:32:35 PM »
Mouse nests in airhead air filters are quite common.
Legend has it that for airheads - particularly /5 airheads - a
battery was suspended in mid-air and the motorbike was built around it.
If you get a battery of SLIGHTLY different dimensions to the original Mareg,
it can be an absolute pig to install/remove. Battery maintenance with lead acid batteries
on these bikes is sometimes neglected as a result........
It really doesn't sound too awfully bad so far, Dirk. Of course, it's early days yet and you
haven't fired it up. But still -  things look encouraging!    :grin: :thumb:
        -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
