Author Topic: V7 III- 2 Different Crankshafts/Con Rods  (Read 1602 times)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: March 30, 2023, 06:17:28 PM »
I’ve already sent enquiries out to some dealers, but seeing how most of them prefer not to play around with small blocks, I thought I’d also ask here:
The early V7 III uses removable connecting rods. The later IIIs go to a pressed fit style crankshaft with a two-headed, non-removable connecting rod. Are these crankshafts and their related con rods interchangeable?
Offline Moparnut72
Re: V7 III- 2 Different Crankshafts/Con Rods
« Reply #1 on: March 31, 2023, 07:55:05 AM »
I hadn't heard this. I thought from what I have read here I thought the V7 850 was the first one with the pressed crank. If later lll's had a pressed crank do you know where the change over takes place VIN or date of manufacture wise?
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #2 on: March 31, 2023, 09:24:48 AM »
Look in parts books & match up part #'s, If they interchange it'll be same block 1/2's. Same w/cyl's & pistons.
