Author Topic: Wheel Hub Spline Grease ?  (Read 2839 times)
Online kballowe
  • - Kevin the Great -
« on: April 05, 2023, 05:25:11 AM »
Why do we grease the wheel hub splines on shaft drive motorcycles?  Once reassembled, they're not moving parts.  So, is the grease simply to prevent corrosion?
Mother Moto Guzzi didn't grease the hub splines on my 1400 Tour
Just this spring, I've seen some never-greased examples on other bikes, when dissembled for tire changes.  One of these had 88,000 miles showing.
Reading  threads elsewhere on the web, some even believe that "your wheel will lock up if you don't grease those splines", and you must use special unobtainium grease.
What say you ?
Offline lucian
Re: Wheel Hub Spline Grease ?
« Reply #1 on: April 05, 2023, 05:58:51 AM »
Mercury special 101 , marine w teflon.  great for propeller shafts and outdrive splines in marine use. does not wash or fling off . Most all outboard boat motor manufacturers have a similar product.
Offline Scout63
« Reply #2 on: April 05, 2023, 07:17:35 AM »
I still lightly brush on a 50/50 mix of Honda Moly paste and high temp grease. Holdover from my airhead days.  I also grease the driveshaft splines. It just seems right.
Ben Zehnder - Orleans, MA USA
Online kballowe
« Reply #3 on: April 05, 2023, 07:24:47 AM »
OK, so I can see the necessity of grease on this part
Offline Stretch
« Reply #4 on: April 05, 2023, 07:28:27 AM »
I noted that on my 1400 when I pulled the rear wheel, too - no lube.
I put a little bit on just to inhibit corrosion, which will make things harder to disassemble.
Some joints - some interference fits for example - SPECIFY no lube. This one doesn't, so I
don't think it will do any harm. It's not a sliding joint, although there is some tiny amount
of play.
                                                              -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Online Moparnut72
« Reply #5 on: April 05, 2023, 07:42:21 AM »
I greased the splines on my 1400 when I had it. However comparing to outboard motors is apples to oranges. The splines live in an environment of hot exhaust and coolant water, a lot of times salt water. Driveshafts rusted to cranks is not uncommon. BMW Airhead driveshaft housings contained lubricant, I don't remember what grade probably called for 90wt. Before 80w90.
I would personally grease them, nothing lost and all to gain. Likely location for fretting.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online Wayne Orwig
« Reply #6 on: April 05, 2023, 08:17:37 AM »
I would put something on it just to stop it from rusting if nothing else. I have even used anti-seize.
And don't forget to wipe a bit of grease on the axle. I have had axles rust in place, and that is no fun to try to get free.
Online acogoff
« Reply #7 on: April 05, 2023, 08:29:54 AM »
     If you ever see one that had no grease on it for lots of miles, I would say that it gets your attention to the point that you will always! put something on the splines.
Marshall County Minnesota USA
Online kballowe
« Reply #8 on: April 05, 2023, 08:32:53 AM »
I have a Honda motorcycle owners manual that recommends this stuff
Offline Perazzimx14
« Reply #9 on: April 05, 2023, 10:23:16 AM »
Honda Moly Paste 60 is NLA or has been for a few years. Some swore by it other swore at it. When i ran out of MP60 I bought what equates to about 7 lifetimes worth of SIG 3000 from MG Cycles for under $30.
I have several small tubes of spline lube Ted Porter hocks. If you want one of them I'll send it to you. It's supposed to be good stuff and Ted priced this stuff like it is saffron. I prefer the SIG3000 as it sticks like dog shit in a vibram boot sole, doesn't pound out and can take far more abuse that a set of spline can ever dish out.
« Last Edit: April 05, 2023, 10:24:45 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
« Reply #10 on: April 05, 2023, 11:53:39 AM »
It depends on how long you want your splines to last. I decreased the wear and fretting by cleaning and degreasing the splines , spraying on dry film moly, cured with heat then using the Wurth grease over that. Overkill ? Perhaps but the splines sure last longer. I do the same on the shaft splines.
Online mechanicsavant
« Reply #11 on: April 05, 2023, 12:37:03 PM »
BMW recommended grease interchangeable w/grease used in FW/190 prop shaft
Online kballowe
« Reply #12 on: April 06, 2023, 07:37:20 AM »
Offline flower_king001
« Reply #13 on: April 06, 2023, 10:40:55 AM »
Honda Moly Paste 60
Bought enough back in the day to last my lifetime
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline pressureangle
« Reply #14 on: April 06, 2023, 03:47:52 PM »
I use industrial open gear and cable lube. It's sticky as heck, has lots of moly in it. Made to stop corrosion, not to fling off, stay put and do it's job.
« Reply #15 on: April 06, 2023, 08:41:14 PM »
That sounds attractive, where do you get that?
Online Moparnut72
« Reply #17 on: April 07, 2023, 09:13:50 AM »
I use Lucas Red Grease, Sticky and Tacky. Change it with tire changes. Works for me.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online kballowe
« Reply #18 on: April 09, 2023, 08:49:32 AM »
We see a lot of "red grease" when disassembling 'other' bikes.  It appears to be popular.
I also use the Lucas red & tacky in my general purpose grease gun and keep a tub in the cabinet.
LOL - there's a 1984 tub of "wheel bearing grease, fortified with moly" on the garage shelf.  It's great for battery posts and such.  It's getting to the bottom, but I think it'll last as long as I do.
« Reply #19 on: April 09, 2023, 01:26:12 PM »
This.
Offline aklawok
« Reply #20 on: April 09, 2023, 04:15:36 PM »
For those applications that need more than plain axle grease, I use either a waterproof boat trailer bearing grease or a low temp waterproof snowmachine grease by bombardier.
On the subject of stuck axles, the trick I use is to put the castle nut on backwards and then beat on it with wood, this protects the threads and if you damage the nut it is easily replaced.
2007 california vintage
Online kballowe
« Reply #21 on: April 10, 2023, 07:11:36 AM »
Offline Perazzimx14
« Reply #22 on: April 10, 2023, 08:18:34 AM »
Turns out spline lube threads are much like oil threads.
Online kballowe
« Reply #23 on: April 11, 2023, 05:57:45 AM »
Whatever happened to the days when we had that five gallon metal bucket of "grease" in the machine shed?
There was a stick in there that we used to "slather" grease onto assorted items, and to make a total mess while trying to fill a grease gun.  No matter how hard you tried to be careful, ya got grease everywhere.  And, we used it for everything that needed grease.
Nobody ever asked "what kind of grease it that" ?  The standard answer would have been "it's grease".     :boozing:
Offline Perazzimx14
« Reply #24 on: April 11, 2023, 06:57:41 AM »
Marketing :thumb:
