Author Topic: Horn Improvement: V85 TT  (Read 7391 times)
Offline SLDMRossi
« on: April 05, 2023, 06:39:45 PM »
If you own a V85 TT, you're no doubt aware that the single, factory horn is simply anemic. But there's nowhere to mount a high-octane, aftermarket Blaster-type horn unless you have Crash Bars to hang it off of. Which I don't...
So a solution is: a Hella 012588011 Dual Disc-Horn Kit. I got mine off of Amazon.
Used the original, vertical horn bracket...and then I made a secondary horizontal bracket that runs at 90-degrees to the bottom of that. It looks like a "W" with ears extending out on each end to mount the horns to. The shape allows it to straddle the downtube frame rails and places the horns outboard of those...which is OK because they're "Water Spray Proof." It also makes sure that when you turn the front wheel full lock there's no interference.
Painted it black. Made a wiring harness to go from 1 horn-to-2 using the existing connectors as a starting point. No Relay required.
The end result? A HUGE improvement! For little money...
Steven Rossi
Re: Horn Improvement: V85 TT
« Reply #1 on: April 06, 2023, 07:22:04 AM »
I'm not sure if I have ever hit the horn button.
Offline mechanicsavant
« Reply #2 on: April 06, 2023, 07:23:46 AM »
I hear ya . No pun intended . How do you justify a top tier bike & scrimp on what is a major safety feature ? I was recently drooling @ the new V1000 & was dumbfounded by the flaccid honker it came with . Having something that  will wake up the cage driver should be mandatory IMHO ! Loud horns save lives !
Offline rtbickel
« Reply #3 on: April 06, 2023, 10:41:10 AM »
About the horn on the new Mandello - I was at the dealership last week and watched the salesman demo the bike in the showroom for its new owner.  Hit the horn button and that thing would wake the dead!  Maybe there was an aftermarket horn that I didn't see, but all I saw was the small horn down on the front of the cases.
2020 V85TT
Offline egschade
« Reply #4 on: April 06, 2023, 12:58:49 PM »
I used the factory horn circuit to trigger a relay for the dual horns I added. There was space to tuck it in behind the right side frame cover. Don't trust the wiring is enough to carry the load of two horns and don't want to fry something.
« Last Edit: April 06, 2023, 01:23:58 PM by egschade »
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline SLDMRossi
« Reply #5 on: April 06, 2023, 06:06:29 PM »
Offline SLDMRossi
« Reply #6 on: April 06, 2023, 06:34:03 PM »
P.S. -- and now I can actually hear it at 60mph with my Helmet on and Ear Plugs in!
SR
Offline tris
« Reply #7 on: April 07, 2023, 03:09:00 AM »
I tend to agree
However, my old man taught me to find a quiet spot on the road and give the horn a good long blast
Just to make sure that it works on the off chance that you need it :cool:
1993 TW125 "POS" - Resting
« Reply #8 on: April 07, 2023, 06:05:53 AM »
Prior to picking up my v85 I asked Hamlin to wire in an air horn.  It's tucked away under my right leg mounted to the rear portion of the engine guards.  You can't see it unless you look but you sure can hear it.  Needed it today as some a**clown got it ALL wrong in a traffic circle.
Offline Sykestone8886
« Reply #9 on: April 07, 2023, 08:09:06 AM »
Hey K O F I see your in the valley of the sun, after living there and visiting friends many times that is one #1 place I’ve rode motorcycles that I was almost in an accident every time I was out, I never saw so many crazy drivers, get out of the valley and everything was good. Be careful out there !!!
Online Vagrant
« Reply #10 on: April 07, 2023, 08:15:06 AM »
I spend three months a year in a 55+ community. You had better have a serious horn there!
KOF, pics, brand?
Offline Moparnut72
« Reply #11 on: April 07, 2023, 08:48:53 AM »
The only time I have used the horn on either my V7 or Triumph was to beep at a friend. The they are both so pathetic to be embarrassing so that I haven't used either since. I had an old lady change lanes a couple days coming right at me. Horn? No just got the hell outta the way.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #12 on: April 07, 2023, 10:07:01 AM »
P.S. In the town I reside in there are 2 folks who are legally blind that drive almost daily to get their scratch tickets & mail !!!  Loving my HORNS ,can ya see me now !
« Reply #13 on: April 07, 2023, 05:19:42 PM »
I NEVER ride into Phoenix.  Where I am it's a hop, skip, and jump to the Bee-Line Hwy and fun fun fun.
This place makes NYC drivers look like F1 pilots!  NOBODY is paying attention-but outside of the city it's wonderful.
« Reply #14 on: April 07, 2023, 05:24:42 PM »
Pic is a bit blurry but you get the idea.  A Denali branded horn.
Notice it's deployed so as to avoid water being force fed into the throat.
« Last Edit: April 09, 2023, 09:42:36 AM by kingoffleece »
Offline JHBettsSr
« Reply #15 on: May 28, 2026, 03:34:58 PM »
I used the Hella dual disk Hi-Lo tone horn kit #011225802 just because this is the same kit I used on my Triumph Bonneville T120 and it sounds very good.
Attached is a pic. I replaced the OE horn with one of the Hella's and added the second Hella to the bottom mounting screw of the rectifier. Both horns work perfectly using the OE horn circuit (no relay required).
'17 Triumph Bonneville T120
'13 BMW K1600GT
'25 Moto Guzzi V85TT
Offline DenverSteve
« Reply #16 on: May 28, 2026, 05:17:37 PM »
That's exactly how my '23 V85TT Adventure horn is.  It's probably the best sounding motorcycle horn I've ever heard.
Steve
2023 MG V85TT Adventure
Offline guzziart
« Reply #17 on: May 29, 2026, 06:49:03 AM »
I bought the Hella horn set, hope to get them installed in the Fall. :laugh:
Offline bronzestar1
« Reply #18 on: May 29, 2026, 11:16:04 AM »
I replaced the single OEM horn on the V100 Mandello and V7 Stone that I used to own, with a pair of Hella disc horns.  I spliced into the OEM horn wire, no relay needed, because the amp draw on the Hellas was nominal.  Were they louder than the single OEM horn?  Yes, but marginally.  If you want LOUD, you need to go with either a pair of snail horns like Fiamm Freeway Blasters, or a compact air horn.  Either setup will require a relay though.
Offline Kildareman
« Reply #19 on: May 30, 2026, 07:50:50 AM »
Go loud, be proud. Sound like a (large) truck.
Denalli Sound Bomb/
V85 Strada
Online Bulldog9
« Reply #20 on: May 30, 2026, 08:22:28 AM »
I have a Denali Sound Bomb on the Norge. It was on the bike when I got it. Crazy loud and scared me the first time I tested it before riding.
I have one to mount on the V85, but havent decided on location yet.  I like the sound so much I have 2 mounted in my truck for crowd control and potential protestor dispersion device along with the stock horns and a train air horn.  :evil:
MGNOC#23231
« Reply #21 on: May 30, 2026, 08:29:38 AM »
Steve,
If you have engine guards the spot I used works well.  I NEVER even know it's there until I use it.
