Author Topic: Broken Griso battery connector  (Read 1755 times)
Offline triman023
« on: April 09, 2023, 04:00:34 PM »
My negative battery cable lug just broke from metal fatigue. The good news is that it broke in my garage not in some God forsaken place!
Does anyone know where I can get just the connector? I have removed the old one but have no idea what the availability is.
I would prefer not to replace the cable as it looks difficult to remove. And will take forever to get...
Any help appreciated.
I guess it was sturdy, it lasted 10 years.
Offline Huzo
Re: Broken Griso battery connector
« Reply #1 on: April 09, 2023, 04:08:33 PM »
It won’t be too hard to remove surely.
You can get copper cable like what arc welders use and terminals that can be soldered on.
Then there are those woven copper straps about 3/4” wide that have the terminals already fitted. Why do you think it’ll be difficult to remove the old one ?
Offline Huzo
« Reply #3 on: April 09, 2023, 04:12:48 PM »
Dime a dozen on Amazon etc..
« Last Edit: April 10, 2023, 12:22:32 AM by Huzo »
Online Vagrant
« Reply #4 on: April 09, 2023, 05:22:19 PM »
Or just walk into auto zone.
Offline triman023
« Reply #5 on: April 10, 2023, 02:20:56 PM »
Auto Zone had zip, as usual
Got 2 connectors from a car stereo installer, just the right size.
I can set up the new battery so I can connect from the front instead of the top.
Thanks!
Offline OldMojo
  • Career of Evil
« Reply #6 on: April 10, 2023, 02:25:49 PM »
I just dealt with this. Please post a pic of the end result.
'15 Griso 1200
'14 California Tour
'02 California EV
'80 CB 650C
Online Perazzimx14
« Reply #7 on: April 11, 2023, 10:48:30 AM »
Even better is go to the local weld shop or electrical supply house and get a few feet of #2 high strand copper weld cable then stop off at the local home center  and get a couple copper lugs and make your own hi-capacity cables and route them more conveniently.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline triman023
« Reply #8 on: April 11, 2023, 07:05:12 PM »
Here is the finished product. The stereo connectors have smaller holes to fit the battery better.
And if you are rich you can get gold plated ones! The took solder very well. I moved them the front of the battery rather than the top.
Offline Huzo
« Reply #9 on: April 11, 2023, 09:55:01 PM »
Fabulous…!
Offline OldMojo
  • Career of Evil
« Reply #10 on: April 12, 2023, 12:41:26 PM »
No issues with fitting the seat?
'15 Griso 1200
'14 California Tour
'02 California EV
'80 CB 650C
Offline triman023
« Reply #11 on: April 12, 2023, 10:26:04 PM »
No trouble with the seat touching. I also put some tape over the exposed bolts just to be safe.
The other thing I did was strap a large zip tie around the battery before installing. Now I can pull the battery out by pulling on the zip tie
Way easier.
