Author Topic: Metal Piece in Sump  (Read 2571 times)
Offline Jimbola
Metal Piece in Sump
« on: April 22, 2023, 10:32:55 AM »
Hi all,
New member from UK here with a V50 Monza purchased late last year and only just become roadworthy.
Many new parts fitted and now running well, however, removed the sump and found this is there  :cry: does anyone have an idea where it came from? Obviously not the heads as no way to get into the sump, I've searched the manual and can only think oil pump? pressure valve? any better ideas before I start to pull it apart?
Thanks in anticipation.
Offline guzziart
Re: Metal Piece in Sump
« Reply #1 on: April 22, 2023, 12:13:06 PM »
My wag here is a piece of lifter...that's all I got.  I'm sure somone that knows what they're talking about will be along shortly.  If you have the pan off, have you tried looking up into the bottom of the engine to see if anything looks suspicious?  I don't recall if the cam & lifters can be partially viewed from a look up.
Art
Offline pressureangle
« Reply #2 on: April 22, 2023, 01:30:14 PM »
Lifter was my guess, but I have no experience with smallblocks.
guido guzzi
« Reply #3 on: April 22, 2023, 02:50:51 PM »
Not sure if smallblock lifters can fall into the sump... If the bike runs well and idles I'd guess the debris was left over from a past failure.  :undecided:
« Last Edit: April 22, 2023, 02:52:31 PM by guido guzzi »
Offline Frenchfrog
« Reply #4 on: April 22, 2023, 02:53:35 PM »
maybe a valve keeper ?
« Reply #5 on: April 22, 2023, 03:50:39 PM »
So.. uh.. *why* did you pull the sump? Noise? Low oil pressure? Just to have a look up her skirt?
Offline Mr Revhead
« Reply #6 on: April 22, 2023, 04:29:52 PM »
Lifter piece. Can definitely fall into the sump.
Have you had the heads off and checked the valve gear? Cam?
They are known to drop valves due to valve train issues. Springs to stiff, wears the cam and followers.
This could be from a previous failure as well
Offline Moparnut72
« Reply #7 on: April 22, 2023, 07:27:37 PM »
Looks like a valve stem keeper. There may be a valve being held by only one. Easy to check. I would check those first thing.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
guido guzzi
« Reply #8 on: April 23, 2023, 07:35:16 AM »
kk
Way too big to be a valve keeper: 12-15 mm
Offline Moparnut72
« Reply #9 on: April 23, 2023, 08:28:13 AM »
Ok, not much on metric measurements.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #10 on: April 23, 2023, 08:39:03 AM »
Just a wild thought.
How about a broken of bit of the plunger on the oil pressure relief?
« Last Edit: April 23, 2023, 10:54:40 AM by Wayne Orwig »
Offline Stretch
« Reply #11 on: April 23, 2023, 09:15:23 AM »
I'm not an expert on the V50, but it looks like a piece of camshaft to me.
It looks too big to be something from the top end that could make it all the way down
to the sump.
The polished part looks like a wear item, and is roughly the right shape and size for part of
the camshaft. It doesn't look like part of a lifter.
No way to tell if it's from a previous blowup, or an imminent catastrophe without having a look
at the valve train I don't think.
        -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Online John A
« Reply #12 on: April 23, 2023, 10:01:37 AM »
I’d be concerned about an automatic rapid unscheduled engine disassembly until I found where it came from. Was it making noise?
« Last Edit: April 23, 2023, 10:04:11 AM by John A »
guido guzzi
« Reply #13 on: April 23, 2023, 10:17:56 AM »
to the sump.
        -Stretch
^ This. Lifters are not shiny on the sides...
Oh and I would definitely take it apart and have look see. :thumb:
« Last Edit: April 23, 2023, 10:23:25 AM by guido guzzi »
Offline Jimbola
« Reply #14 on: April 24, 2023, 04:52:59 PM »
Thanks for all the replies! a friend and I spent some time looking at the broken part and comparing it with anything that could drop into the sump, we excluded parts of the heads. Our conclusion is that it was part of a cam follower- lifter for you guys :wink: so stripped heads and barrels and with mirror and torch (not welding :wink:) flashlight that is! checked all followers and pleased to report all present and correct :thumb: Our conclusion is that it was from a previous episode as it was obvious the engine had been apart not long ago as very little carbon build up on heads and pistons added to which, some monkey has reassembled it without washers under two of the outer head nuts and copious amounts of gasket sealer.
The bike was running fine but I decided to remove the sump and clean the gauze strainer prior to an oil change.
Safe Guzziing guys.
Offline Frenchfrog
« Reply #15 on: April 24, 2023, 05:06:10 PM »
Wise thing and glad nothing was found
Offline Bulldog9
« Reply #16 on: April 24, 2023, 08:27:06 PM »
Safe Guzziing guys.
Good news, but it is a bit troubling that whoever did the work to repair the broken lifter/follower did not drop the sump in the process. I'm assuming they did a new cam, but you know what they say about those who assume  :evil:
MGNOC#23231
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #17 on: April 25, 2023, 05:50:38 AM »
While they had the bike aprart, the oil pan was probably used as a catch all for bolts, washers, broken engine bits that were removed, etc.  Good news is it appears they did not have any extra bolts left over after the repair.
2002 MZ Skorpion
1994 DR Skorpion
Offline Stretch
« Reply #18 on: April 25, 2023, 05:50:59 AM »
Glad you found everything intact!   :grin:
Those Previous Owners   :violent1:  - ALWAYS good for a surprise or two!
                                            -Stretch
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2015 Triumph Trophy
