I checked the oil level today and it was bone dry. It seems i completely lost all the oil during the short test drive.I removed the oil pan and yes there was nearly nothing left. Luckily there was absolutely no metal in the oil pan.I refilled the engine with 2.5 liters of the same oil i was using during last season - Motul 20W-50 mineral classic oil - which ist enough for exactly half of the dip stick.Drove the same tour as the day before but stopping and checking the oil breather athmosphere hose every 3-5 minutes. At first everything was fine but after about 10 minutes the breather started pumping out the oil. Literally pumping like you cut an artery. Huge squirts every 2 seconds repeatedly.Headed home instantly using the side roads and when i came home I nearly lost 1.5 liters fresh oil!!!!!Its a new breather from Stein-Dinse https://www.stein-dinse.com/en/moto-guzzi-oil-condenser-v7-700-spezial-850-gt/item-2-1050679-12155701_.Z.htmlThe old breather worked fine with that oil.Is that now the second faulty SD part within days or ist the 20W-50 too thin for that after market breather?? Could it bei that it sucks my whole engine dry even in idle with 1200 rpm!?
Why did you replace the breather if the old one worked fine? Is there another check valve in the pipe coming from the engine to the breather, such as one like this?
One other way they can pump oil is when drain pipe banjo has been cut so is not under the oil level, it is then acting as another breather, not a drain. The crankcase pressure up the pipe forces the oil out.That one took a bit of working out , I made an external drain under oil level and routed hose to that. Fixed problem
John A, thanks for that explanation. So if his flapper is stuck shut, the oil would come up the line that should return the oil to the crankcase.Thank you,Tom
Check valve goes in the big hose, actually fits into the breather pipe. I see that you had the cylinder heads rebuilt, did you do anything with the cylinder bores and rings by any chance? DonG
