Author Topic: Eldo 4LS  (Read 2581 times)
Offline steven c
Eldo 4LS
« on: April 30, 2023, 12:39:24 PM »
 This could explain my lack of stopping power.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline chuck peterson
Re: Eldo 4LS
« Reply #1 on: April 30, 2023, 01:59:26 PM »
I used to visit a machine shop at the bottom on Dixwell in New Haven established 1929. 8 stations in rebuilding and fitting drum brakes, everything in cobwebs today …
What’s it called when you mate a drum to the brakes?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Don G
Re: Eldo 4LS
« Reply #2 on: April 30, 2023, 02:02:17 PM »
I believe the term is radius.  DonG
Online Moparnut72
Re: Eldo 4LS
« Reply #3 on: April 30, 2023, 02:14:53 PM »
Arcing. Probably can't find anyone who does it anymore or the equipment to do it.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline guzziart
Re: Eldo 4LS
« Reply #4 on: April 30, 2023, 03:09:02 PM »
Re: Eldo 4LS
« Reply #5 on: April 30, 2023, 03:31:21 PM »
I arc shoes to match the drums on a regular basis, it's about the only thing I use my "big" lathe for any more.
If you're buying new brakes shoes, I would recommend these:
Ferodo FSB796          220x25           Moto Guzzi  4LS front (1462 0805) (2 required)
https://www.vintagebrake.com/shoes.htm
You could also have them relined.
Offline 73 sport
Re: Eldo 4LS
« Reply #6 on: April 30, 2023, 04:02:13 PM »
      If the drums are't out of round or bell mouthed, the shoes can be hand filed to fit.
Offline huub
Re: Eldo 4LS
« Reply #7 on: May 01, 2023, 05:46:49 AM »
just be sure what linings you are working with.
the older ferodo green and brown lining is asbestos based.
Offline leafman60
Re: Eldo 4LS
« Reply #8 on: May 01, 2023, 08:02:43 AM »
I had the awesome-looking 4LS brakes on my 850GT. The shoes were properly radiused and I spent quite a while meticulously adjusting the shoe linkages.  They became some of the most powerful brakes I've  ever had (even compared to some discs).  The self-servo effect of the shoes create a sensation similar to power brakes.  In fact, I learned to be a little careful with them so as not to be thrown over the handlebars. :wink:
I have a friend in the tire/brake business with a automobile machine shop that he inherited years ago from his father.  His often tells the story that in all of his "old" equipment was a special lathe just for radiusing drum brake shoes and drums. With the predominance of disc brakes in the last 30 years, the machine sat idle and only collected dust until he and his son lugged it out to their dumpster and threw it away. He now wishes he had saved it.
I haven't dealt with them in years but Vintage Brake used to offer custom shoe and drum fittings for motorcycle drum brakes.
http://www.vintagebrake.com/
« Last Edit: May 01, 2023, 08:04:32 AM by leafman60 »
Offline steven c
Re: Eldo 4LS
« Reply #9 on: May 05, 2023, 11:29:26 AM »
Putting the old shoes back on.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline TOMB
Re: Eldo 4LS
« Reply #10 on: May 05, 2023, 03:50:27 PM »
Great job using a vice to expand the shoes I'll file that in the memory bank.
TOMB
« Last Edit: May 06, 2023, 01:14:48 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Re: Eldo 4LS
« Reply #11 on: May 05, 2023, 10:42:22 PM »
Check if you have a brake shoe relining shop in your area. Big rig truck specialty brake and clutch shops should be able to size and arc shoes to match your hub. A local specialty shop makes custom shoes and clutch reclining for most everything including trucks, cars, even elevator brake shoes.
I take the whole wheel in (after checking the rim is true) and the whole wheel is put on their big lathe, the drum is skimmed and the shoes sized to fit.
My V7 Sport 4Ls was a great stopper, not as good as a dual disc but pretty good.
Getting the hub skimmed goes a long way to good brake performance.
Offline Mike Tashjian
Re: Eldo 4LS
« Reply #12 on: May 07, 2023, 04:41:38 PM »
Ok, us old guys will have to explain what brake shoe grinding is when properly done.  This is from a book I learned from way back in my college days.   It will avoid possible drag on the shoes, eliminate lining high spots, assure better adjustments, and reduce the break in period. The grinding process places an eccentric grind on the brake shoes.  This results in the ling being thinner at both ends, but leaves the full thickness in the middle, the point of greatest wear.  The clearance at both ends also provides for flexing of the brake shoes.  To check for proper shoe to drum fit, place the shoe inside the machined drum with the center of the shoe contacting the drum. A minimum of .010 clearance should be at the toe and heel of the shoe.  Service manuals will usually give proper clearances if they need to be greater.  Replacement shoes should be checked for proper fit as some manufacturers pre grind them.  I haven't touched many in the last few years but they can work pretty well when done right.
czakky82
Re: Eldo 4LS
« Reply #13 on: May 07, 2023, 05:37:10 PM »
Thanks Mike!
