Author Topic: SPII Front Master  (Read 1430 times)
Offline pehayes
SPII Front Master
« on: May 01, 2023, 02:17:04 PM »
Started a leak from the front master cylinder on my '87 SPII.  Has the older version integral with perch, throttle, and switchgear.
Seems that replacement or rebuild are each no longer available.
Has anyone come up with a quick solution?
« Last Edit: May 01, 2023, 02:17:35 PM by pehayes »
Offline guzziart
Re: SPII Front Master
« Reply #1 on: May 02, 2023, 06:22:17 AM »
I assume you're taking about the trapezoidal shaped reservoir setup like what was on the LMIV's.  No, I haven't had any luck in finding nos pump rebuild kit, reservoir diaphragm & oring....maybe check out this thread.
https://wildguzzi.com/forum/index.php?topic=115736.0
Art
Offline Mike Craven
« Reply #2 on: May 02, 2023, 06:50:45 PM »
Should you consider that route... I had good work done and experience with Apple on some oddball Girling stuff.  But it may take a phone call.
-Mike-
Mike  L-715, Atlanta GA
1983 Cali II
Offline Bob Mehmen
« Reply #3 on: May 02, 2023, 09:24:51 PM »
I have a used one off my SPII when I changed to BMW switchgear if you want it. Lately I have been sending them to White Post Restorations and have them brass sleeved.
Offline pehayes
« Reply #4 on: May 03, 2023, 12:20:16 AM »
Bob:  See your PM.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #5 on: May 03, 2023, 07:41:28 PM »
Motogiovane.it has the rebuild kit... comprising just the seals, not the piston. You'd need to fashion some kind of cone-shaped "ramp" to get the seal onto the piston without damage... one per seal, one per end of the piston, seems to me...
https://www.retzmoto.com/partiecycle/pneumatiques/169082_brembo-m-c_kit-reparation-maitre-cylindre-av-ps12-moto-guzzi-v35-v50-v65-t5-10409020.html
Price has gone up by 5 Euro's... Now 45 Euro's...
Strange: I pasted-in the motogiovane link, and a retzmoto link appeared...? And the pix shows the piston, complete, but it also shows "out of stock"...???
???? https://www.motogiovane.com/mobile_products.php?cPath=67&page=6
« Last Edit: May 03, 2023, 07:58:45 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #6 on: May 04, 2023, 11:22:35 AM »
This is only a bit peripheral, but can folks weigh-in re the notion of sleeving to brass versus sleeving to stainless steel? Seems to me brass is softer, of course. Would it not be prone to wear issues? Also, brass is more corrosion prone, duh, than stainless steel. Having said the above, some companies that restore bores for brake system hydraulics swear by brass as being superior...
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #7 on: May 06, 2023, 03:13:33 PM »
Bump... Anyone? re the brass versus SS tubing question?
