Author Topic: T3 final drive gear set options  (Read 2081 times)
Offline glenm64
« on: May 04, 2023, 04:47:16 PM »
Hi Folks
A bit of context. Ive had old faithful for around 40 years, she has a lot of mods and still pulls like a train. When I build her (1000cc, 40mm PHM, P3 cam, 38mm Marzocchi front + more) the final drive gear set wasnt a good match as it felt like I needed another gear. I fitted 8/33 and besides needing a bit more feathering of the clutch it suited my riding here in the wide open spaces of Western Australia. As time goes by my speed has come down a bit (age, speed cameras, morons on the road etc).
On a recent oil change there was a bit of metallics in the oil. I opened it up and there is pitting in the gear set, so I think sooner rather than later I will need to rebuild it.
I am thinking to increase the ratio a bit but dont want to go back to 7/33. Will the 8/35 from a V7 sport fit in the later T3 final drive. My initial enquiries say it will, but I would like confirmation from the brains trust here please.
Thanks in advance
Online BMCMOTO
Re: T3 final drive gear set options
« Reply #1 on: May 04, 2023, 08:55:11 PM »
I'm pretty sure that all the Tonti gear sets will fit any Tonti housing. The only caution is number of splines on pinion shaft. An expert will be along in a few moments to give correct information.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
guido guzzi
« Reply #2 on: May 05, 2023, 09:58:57 AM »
Beautiful bike!
If you want to use a drum brake final drive (complete unit) you will need something like this https://www.mgcycle.com/index.php?main_page=product_info&cPath=72&products_id=5249
because the drum brake final drive housings were shorter. Not sure what's needed if you want to transplant the gears from a drum brake model into your existing housing...  :undecided:
« Reply #3 on: May 05, 2023, 12:06:37 PM »
The reason for the difference in the length so a spacer is needed is they went to wider pinion support bearings on the bevel box. It’s about.040”, which I use when I make my own.
« Reply #4 on: May 05, 2023, 12:33:01 PM »
It's not the pinion bearings, it the thickness of the flange of the pinion carrier. It's 2 mm thicker.
guido guzzi
« Reply #5 on: May 05, 2023, 01:01:33 PM »
So can 'drum brake' gear sets be used in 'disc brake' housings?
« Reply #6 on: May 05, 2023, 03:04:21 PM »
Yes.
Offline glenm64
« Reply #7 on: May 05, 2023, 04:36:52 PM »
Thanks Gents
I dont want to fit an early style rear drive, only change the gear set. I think the 8/35 will be a perfect match for the old girl (and me).
« Reply #8 on: May 05, 2023, 08:58:16 PM »
I thought that with the larger ujoint, I think some later T’s had them but the pinion carrier bearings collectively were the .040 wider, starting about then.
Offline glenm64
« Reply #9 on: May 05, 2023, 10:11:56 PM »
Could someone confirm the number of splines on the earlier V7's pinion shaft versus the newer models please?
Again TIA
« Reply #10 on: May 06, 2023, 06:49:31 AM »
Again TIA
They're the same. The only ones that are different are Convert/Cal II Auto and some rare Californias (IIRC) which have 20 splines.
« Reply #11 on: May 06, 2023, 07:47:30 AM »
This am I remembered a conversation with Dave Hewitt ( tech rep) where he told me that they had done testing on that flange and had made it thicker after finding it did flex. I wonder if the thicker flange came with the wider bearings?
Offline glenm64
« Reply #12 on: May 06, 2023, 04:37:59 PM »
Excellent, thanks Gents.
Offline moto-uno
« Reply #13 on: May 10, 2023, 03:56:50 AM »
  Given any thought to a different wheel, tire combo ?
