Author Topic: Generac oil  (Read 4636 times)
Offline slowmover
Generac oil
« on: May 07, 2023, 05:26:35 PM »
I have an old Generac natural gas standby whole house generator and always used automotive oil in it. I noticed my can of Valvoline 5w-30 synthetic oil says for Gasoline engines. I know Generac wants me to use their oil. What would be the difference?
Offline Vagrant
Re: Generac oil
« Reply #1 on: May 07, 2023, 05:28:47 PM »
They put 10/30 car oil in mine.
Re: Generac oil
« Reply #2 on: May 07, 2023, 06:42:06 PM »
I've been using Mobil 1 5-30 in my Generac for 20 years or so. I'll let you know if I have an issue.. :evil:  :smiley:
Offline Perazzimx14
Re: Generac oil
« Reply #3 on: May 07, 2023, 06:55:02 PM »
Like with motorcycles you have to use oil specific to the motor. You must follow the buzz words on the front of the container and disregard the ratings/specs on the back of the container.
Motorcycle oil single/twin/triple 4 and 6 cyl. They there are the subcategories like V/L or parallel twin, inline or V-4,
Trike oil
Car oil
Truck oil
Tractor oil
Go cart oil
Mini bike oil
Push Lawnmower oil
Riding lawnmower oil
Zero turn mower oil
Generator oil
Front tine Rototiller oil
Rear tine Rototiller oil
Post hole digger oil
Backhoe oil
Boat oil
Is you generator a single or multi cylinder. That'll make a difference too.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline slowmover
Re: Generac oil
« Reply #4 on: May 07, 2023, 07:36:25 PM »
From the interweb:
Can Car Engine Oil Be Used In LP Or Natural Gas Generator Engines?
Automotive motor oils are not suitable for liquid propane or natural gas-powered generators. Car motor oil would tend to break down relatively quickly and be prone to oil consumption. Passenger car motor oils are simply not designed to work with LP or natural gas fuels.
Online Moparnut72
Re: Generac oil
« Reply #5 on: May 07, 2023, 08:46:33 PM »
I don't understand what the reason for this would be. I had a propane powered pickup years ago when propane motor fuel was 85 cents a gallon. Engines fueled by propane run very clean and run cool. Why would they require a different grade of oil? If anything a lower grade oil would be perfectly fine.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Online Tom H
Re: Generac oil
« Reply #6 on: May 07, 2023, 10:15:29 PM »
Now those were 2 posts in a row that made me go Hmmm???
Didn't think you had to use different oil for a propane car?
Maybe a Gen Set is different because it's not run everyday??
Offline slowmover
Re: Generac oil
« Reply #7 on: May 07, 2023, 10:23:11 PM »
Amsoil website has a lengthy explanation under the heading Synthetic Stationary Natural Gas Engine Oil.
Online aklawok
Re: Generac oil
« Reply #8 on: May 08, 2023, 12:33:26 AM »
 You forgot the metric, whitworth , and left-hand threaded oil categories
 To the OP: use any (any?) ANY! "Any" N-E, 30w oil at all!!! ( Given proper change intervals that may vary depending on the oil you use and load) you want and you will be fine.
Ps: avoid whale blubber or seal oil if you can ( but they will work in a pinch)
« Last Edit: May 08, 2023, 04:52:22 PM by aklawok »
2007 california vintage
Offline jkguzzi
    • JKnorth
Re: Generac oil
« Reply #9 on: May 08, 2023, 06:09:06 AM »
This post got my interest as I use full synthetic in my Generac, probably Mobile One, I'll have to look. Generac's website shows numerous maintenance kits available with full synthetic.
Online blackcat
Re: Generac oil
« Reply #10 on: May 08, 2023, 07:40:51 AM »
I would ask this question on this forum:  https://gentekpower.com/forums/
This is not an easily rebuildable engine as I found out with my Generac. Even buying a replaceable engine wasn’t a realistic option so I ended up buying a new model.
Offline n3303j
  • Ron Cichowski
Re: Generac oil
« Reply #11 on: May 08, 2023, 08:30:34 AM »
Generator runs 75% power steadily. Car runs constantly varying loads. Seldom at full power. I'd be tempted to run aviation oil in an air cooled generator just to match the load duty cycle of the application.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline PeteS
Re: Generac oil
« Reply #12 on: May 08, 2023, 08:37:32 AM »
My portable 15 year old gas powered 5.5KW Generac runs constant RPMs. Nothing about special oil in the owners manual.
Offline Madtownguzzi
Re: Generac oil
« Reply #13 on: May 08, 2023, 10:48:24 AM »
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Online Moparnut72
Re: Generac oil
« Reply #14 on: May 08, 2023, 10:56:41 AM »
Unless something has changed I wouldn't run aviation oil in anything. AeroShell is a non-detergent oil. When I tore down radials as one of my tasks in the airplane shop the insides of those those things were as dark as a black hole. I was told that the FAA hadn't approved detergent oils for aviation use in piston engines. Cleaning those up was a major undertaking until we found a product that did it quite well. The FAA is a very archaic organization. Again I may be wrong as usual.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline AJ Huff
Re: Generac oil
« Reply #15 on: May 08, 2023, 12:49:01 PM »
What type of oil should I use in my home backup generator?–
An SAE rated high detergent oil that meets API Service Class SF requirements for gasoline engines, similar to your car. In general, when the temperature is over 40 degrees F, the most recommended oil is a 30-weight detergent product.  When the temperature drops below 40 degrees F, you should use 10W-30.  Refer to your owner’s manual for details. To find your owner's manual online, visit our Product Support page and enter your serial number or model number.
https://www.generac.com/service-support/faqs/home-backup-faqs
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline Don G
Re: Generac oil
« Reply #16 on: May 08, 2023, 02:56:55 PM »
I worked for a major player in the oil industry for 19 years in the maintenance department. In all of our natural gas and propane fuelled prime movers we used Chevron Supreme 5-30, these engines ran constantly until failure. No special wierdo crap oil required, just change at required intervals.  DonG
Offline kballowe
  • - Kevin the Great -
Re: Generac oil
« Reply #17 on: May 09, 2023, 08:43:37 AM »
 :boozing: :boozing: :boozing:
Offline Stretch
Re: Generac oil
« Reply #18 on: May 09, 2023, 09:13:50 AM »
FWIW, I've used cheap 10W-30 or 5W-30 conventional oil in all of the lawn equipment/generators for decades.
I change it in a new engine after the 1st hour, then 2 hours later, then 5 hours later and consider the
engine broken in at that point. Most of these engines take a quart or less of oil, and it's not filtered.
Be generous with oil changes after that. It's amazing the amount of "glitter" that comes out in that first
oil change!
For example, I have an old 8HP chipper I bought in 1999, and it's stored in a leaky shed. I've beaten the everlasting
pooh out of it, and it still runs fine. It gets oil changes as soon as the stuff looks dirty.
YMMV.
        -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Online Moparnut72
Re: Generac oil
« Reply #19 on: May 09, 2023, 09:40:28 AM »
My lawn mower doesn't have a drain plug. The manual says to add oil as needed, no changes necessary. I changed it anyway after the first few hours. I just tipped it upside down. Now I use a turkey baster with a hose attached.   :azn:
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline knockerjoe
Re: Generac oil
« Reply #20 on: May 09, 2023, 09:55:19 PM »
Been using Mobil 1 5W30 in my Generac for 8 years now no problems.
Offline n3303j
  • Ron Cichowski
Re: Generac oil
« Reply #21 on: May 09, 2023, 10:11:10 PM »
I use Honda Goldwing oil in my Honda Inverter because the service letters on the bottle match those specified in the owners manual.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Moparnut72
Re: Generac oil
« Reply #22 on: May 10, 2023, 10:12:48 AM »
An owner of a  Honda/BMW dealership I knew always said I've seen more damage from lack of rather than the type of oil.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline berniebee
Re: Generac oil
« Reply #23 on: May 10, 2023, 12:57:32 PM »
From the interweb:
No. You looked at the first hit, which is from a oil marketer. They want to sell you overpriced "specific" Amsoil.
Offline berniebee
Re: Generac oil
« Reply #24 on: May 10, 2023, 01:19:57 PM »
OF COURSE Generac wants you to use their oil. The difference is that it's easy money for them, as they slap their label on a bottle of generic oil and then mark it up 100%.
My first point is that dual fuel generators don't recommend a change of oil when you swap fuels. Secondly, the engines used in these generators are low compression, low stress units that don't much care which oil you throw in. Thirdly, propane burns much cleaner than gasoline and is less hard on engine oil. Use automotive oil.  5W30 synthetic is nice in that it's easier to crank when temperatures fall way below freezing. But synthetic is absolutely not necessary.
Online Moparnut72
Re: Generac oil
« Reply #25 on: May 10, 2023, 01:50:26 PM »
I was once on a camping trip. My Honda generator quit running due to the lack of oil, they automatically shut down when the oil level gets low. All I had with me was 2 stroke oil. Run just fine the rest of the weekend and I don't think I changed it for awhile afterwards.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
