Author Topic: New Lemans 2 - brake upgrade?  (Read 1561 times)
Offline lazlokovacs
« on: May 16, 2023, 01:53:13 PM »
scored a LM2 partly disassembled for a good price last week. Went back together super easy. Bike was once known to me and has the sweetest guzzi engine I've ever encountered. Perfect little hot-rodded 850 nut.
Anyway, brakes are all shot.
Can bleed the linked system to get a pretty good pressure, but all the pressure disappears about half an hour later... any ideas where to start? (reverse bled with a syringe including bleeding master cylinder and proportioning valve)
Also, pretty much the same with the front, but slightly better.
And is there a modern caliper bolt-on replacement out there?
thanks as ever
Re: New Lemans 2 - brake upgrade?
« Reply #1 on: May 16, 2023, 02:02:24 PM »
Master kits work wonders.  Nice bike.
 One nice thing about the Cal Vin is the bleeder on top of the linked brake splitter. If you look to replace it look for a Cal Vin unit.
« Last Edit: May 16, 2023, 02:04:36 PM by guzzisteve »
Offline Turin
« Reply #2 on: May 16, 2023, 07:33:00 PM »
I was not a big lover of the linked brake system until I bought one of the speigler stainless braided kits from Harpers for my lemans III. ( I went with the rubberized black coating, stealthy) you could always fit a single Brembo P34 to the front.
1985 Sidlow Guzzi
