Author Topic: Front Turn Signal Gremlins  (Read 1475 times)
Offline tofervt
« on: June 08, 2023, 08:19:11 PM »
Hi all,
I have a bit of a turn signal gremlin going on with my 2003 California Titanium. My rear signals work fine, but my front signals work intermittently and I never know what to expect. Sometimes they both work and sometimes one will work and then the other will work. Any information or suggestions appreciated.
Thanks,
Christopher
Online Wayne Orwig
Re: Front Turn Signal Gremlins
« Reply #1 on: June 09, 2023, 11:10:31 AM »
IF the rear signals always work, and BOTH fronts are acting up, I would start by looking for a bad ground wire up there somewhere..
Offline glenm64
« Reply #2 on: June 12, 2023, 07:56:40 PM »
Ive found bad earths to be the main issue. Quickest checks are run an earth to bulb and test. Check continuity of + wire with multimeter if earth is not the problem.
