Author Topic: Exhaust Gasket, 2013 Stelvio??  (Read 3275 times)
Offline bobrebos1
« on: June 17, 2023, 01:01:39 PM »
I was going to have an interested party look at my 2013 Guzzi Stelvio next week, and today while it was idling in my garage, when i reved it up a little pieces of exhaust gasket came out by where muffler meets exhaust on left side in area of foot peg kind of.  Is it a big job to replace this gasket??  Dealer charge maybe $500 or more?  Anybody know?
« Last Edit: June 17, 2023, 01:32:42 PM by bobrebos1 »
Sober, Retired Air Force!
Re: Exhaust Gasket, 2013 Stelvio??
« Reply #1 on: June 17, 2023, 02:06:04 PM »
Unbolt the clamp, not unbolt but loose. Unbolt muffler on back under seat. Slide muffler & pipe back twisting fitting. Clean & put on new packing, replace pipe & muffler, tighten clamp.
Look at bike, look at bolts & clamp, now can you do it? $0
Bob, that would only be 1/2hr at a shop.
« Last Edit: June 17, 2023, 06:05:33 PM by guzzisteve »
Offline bobrebos1
« Reply #2 on: June 17, 2023, 06:52:08 PM »
OK I can do that then.  Thanks
« Reply #3 on: June 18, 2023, 08:05:52 AM »
The packing is same for Kawasaki at only a few bucks, do a search for it.
Online Wayne Orwig
« Reply #4 on: June 18, 2023, 08:57:50 AM »
I used the Kawasaki part, ordered on Amazon I think.
Not too bad a job.
Offline Ryan
« Reply #5 on: June 18, 2023, 02:26:14 PM »
I ordered two so I would have one on hand when the other side let go, then buggered one up when I got impatient. So more spare, but it is a relatively simple repair. I would like to make a new gasket out of a soft metal (lead?) next time to see if it outlast the stock one.
Offline bobrebos1
« Reply #6 on: June 18, 2023, 04:06:53 PM »
Which Kawasaki model?  Is it a gasket or some kind of other material or,?  I can’t tell until I pull the exhaust back I guess
Offline bobrebos1
« Reply #8 on: June 18, 2023, 06:47:28 PM »
Guzzi PT# GU05128230          Never bought the Kaw, only installed them.      Don't know what they are made of, silvery, flaky, slick , not good for environment stuff.
https://www.af1racing.com/GU05128230-OEM-Aprilia-MG-60mm-Exhaust-Gasket---GU05128230
Kawi is less than 1/2 of that, if I remember.
Your # is for header to collector, mine is for collector to muffler pipe.
« Last Edit: June 18, 2023, 06:55:13 PM by guzzisteve »
