Author Topic: 2001 Jackal Rear Drive Leak  (Read 1258 times)
Offline Rocket Rod
« on: June 22, 2023, 10:13:27 AM »
After some helpful advice from rodekyll last month I finally got around to removing the pumpkin.
A couple of questions:
How does this pumpkin look overall?
Is the driveshaft supposed to come out with the pumpkin?
« Last Edit: June 22, 2023, 01:50:06 PM by Rocket Rod »
Can't believe I bought a Guzzi.
Offline Rocket Rod
Re: 2001 Jackal Rear Drive Leak
« Reply #1 on: June 22, 2023, 10:14:19 AM »
Dang pics not posting.
Offline Rocket Rod
« Reply #2 on: June 22, 2023, 10:16:23 AM »
https://ibb.co/X7Dmw8C
Well that's cropped but not on propose.
« Last Edit: June 22, 2023, 10:18:21 AM by Rocket Rod »
Offline bigbikerrick
« Reply #3 on: June 22, 2023, 10:35:40 AM »
It looksl to me like the big seal is leaking. The blue one. I recommend replacing with a Viton seal, which is more heat resistant, those are usually brown in color. The replacement of this seal is very easy.
Rick.
« Reply #4 on: June 22, 2023, 01:12:14 PM »
Before you clean it, look past the big seal and you can see if the inner seal is leaking. A much bigger job than the larger outer seal because the box has to be disassembled. Thar be dragons in there…
Offline Rocket Rod
« Reply #5 on: June 22, 2023, 01:54:12 PM »
Images
Dagnabit, I can't post uncropped pics.
« Last Edit: June 22, 2023, 01:58:53 PM by Rocket Rod »
Offline Rocket Rod
« Reply #6 on: June 22, 2023, 02:00:55 PM »
Looks dry and shiny inside as far as I can see.
Offline Rocket Rod
« Reply #7 on: June 22, 2023, 02:03:12 PM »
Rick.
I agree, ordered the big viton seal from MGCycle just 30 minutes ago.
« Reply #8 on: June 23, 2023, 01:31:32 PM »
One way to tell if inside is leaking, there will be oil on the axle & coming out the hole for it. If that passage is dry it's good.
