Author Topic: V85tt E5 Check engine light after mods?  (Read 2627 times)
Offline fastlaners
« on: July 12, 2023, 10:50:10 AM »
Hello All; I recently did the SAS delete kit and tip over valve, evap tank modifications;
-2022 V85 E5 Travel
-SAS delete kit installed; ( Yes; one bolt on right side plate was a challenge ) installed plug that came with kit on air box ; capped all other connected hoses and left unit plugged in.
-Tip valve and evap mods; gutted tip valve and left hose going to evap canister; cut other hose off top of canister and plugged all other hoses including one that goes to manifold also left unit plugged in.
-installed Mistral big bore header kit and y-pipe without catalyst, MassMoto carbon slipon with db killer, K&N air filter
-Then performed Upmap download; once complete; I took bike for a ride; smoother throughout the rpm range in all gears; much more lively feeling; seemed like less heat off cylinders; The only negative drawback is I have a flashing yellow check engine light; Upmap app. shows P1309 error code; any input or help on this issue would be appreciated. Thank you, John.
Re: V85tt E5 Check engine light after mods?
« Reply #1 on: July 12, 2023, 12:28:50 PM »
I guess non else has done what you did to the bike.  Mine is still 100 percent stock.
Offline RinkRat II
  • Lake Powell AZ
« Reply #2 on: July 12, 2023, 01:04:37 PM »
    Code relates to crankshaft position sensor. Possible remap has an unknown or bad value.
    Paul B :boozing:
Offline Ed / AF1 Racing
« Reply #3 on: July 12, 2023, 05:42:09 PM »
needs the tone wheel learning done.
There is a hack that works on the same 11MP ECU in the Aprilias, RS660 / V4.   Probably will also work on the V85
https://www.apriliaforum.com/forums/showthread.php?375470-Euro5-bikes-P1309-error-flywheel-learning-sync-misfire-detection&p=4909355&viewfull=1#post4909355
Gabro posting is the one who does all the UPMAPs for aprilia
Offline egschade
« Reply #4 on: July 12, 2023, 06:35:06 PM »
Will messing with the ECU void the warranty?
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline tris
« Reply #5 on: July 12, 2023, 11:43:49 PM »
I'd have thought everything else you have done would have already voided the warranty.
Why worry now?
1993 TW125 "POS" - Resting
« Reply #6 on: July 13, 2023, 01:05:02 AM »
Why worry now?
Yeah.
My V85 warranty was voided before I got home.
I don’t know why though, I only removed the ugly bits… :wink:
