Unfortunately not, I'll try to register now
Sounds like you are using the IAW reader/writer so you need to use Tuner pro to change, then reader /writer to put in tune(map) Want to Contact Beetle at the Ghetto, he makes maps. He is in Australia. Good Luck! Where are you located?
no, I have flash with maps loaded, but since I have a control unit from ducati, I need an eeprom from griso v8 to make it virgin in the future and the dashboard accepted this unit as new. at the moment I have a start is prohibited, I can’t make the ECU virgin, since there is an eeprom from ducati and not from moto guzzi
