2007 Norge tilt sensor
Topic: 2007 Norge tilt sensor (Read 1063 times)
Kaladin
Gosling
August 21, 2023, 12:58:18 PM »
Saturday I was digging around the relay block trying to figure out why my high beams don't come on. I came across this weird component with two wires going into it. I took off the rubber mounting flange to try to figure out what it was. When I put it back on I notice that it had a "this end up" kind of label on the rubber. But I don't know which way is up on the sensor. Could this be why I can't start the bike?
thanks
kaladin
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be. And when you find it you discover "that's where it should have been."
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
guzzisteve
"Just Ride It"
Re: 2007 Norge tilt sensor
Reply #1 on:
August 21, 2023, 01:23:34 PM »
That is the tip over sensor, a ball sits in a V shape resting spot. Shake it you'll hear the ball. Flip it over, bike should start.
Gliderjohn
Reply #2 on:
August 22, 2023, 07:09:37 AM »
A few years ago foolishly dumped my Norge 8V trying a U-turn on a very sandy road. After dumping it, it just kept running with the left header burning nicely through the plastic until I hit the kill switch. Idles well at about 110 degree down angle in a ditch.
Back in central KS
Kaladin
Gosling
Reply #3 on:
August 22, 2023, 09:07:43 AM »
I flipped the sensor and the bike starts fine. Thanks
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
