Author Topic: LONG New to me Old Eldorado  (Read 3150 times)
Re: LONG New to me Old Eldorado
« Reply #30 on: August 31, 2023, 07:07:32 PM »
Yes, Long was meant to warn you the post is not a quick and dirty read and a tip to anyone who doesn’t want to read a lot of blather. Maybe I should have put it after the new to me with a comma.
Offline matt franklin
« Reply #31 on: September 05, 2023, 12:10:07 AM »
Every seal on that bike will let go as soon as you start  running it.  Save yourself some grief and replace them while you have it apart.
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
« Reply #32 on: September 05, 2023, 04:21:39 AM »
Greg Bender full wiring harness https://www.thisoldtractor.com/for_sale_wiring_harness.html
You'll thank me!  Great fella and very high quuaility work,  One of the best things I did.
Cyclehoarders Garage
2021 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1986 Yanaha FZX700 Fazer
1981 Honda CX500 Deluxe
1973 Moto Guzzi Eldorado 850
1969 Yamaha YAS1C
LaGrange, KY
Offline nbags
« Reply #33 on: September 05, 2023, 04:38:42 AM »
pretty late built loop look at exhaust port has bosses for t/t3 pipes but not drill
Offline Luke
« Reply #34 on: September 05, 2023, 11:26:51 AM »
One more vote for mechanical refurbishment. Pull engine and transmission, touch up frame with POR15 as needed. Clean sludge trap, replace rod bearings, replace pistons and cylinders, replace chain tensioner and do a valve job. Do transmission seals, shim and inspect. Assess/replace wiring harness. Add another disc or replace master cylinder. Turn front fender stay right side up. Ride it.
