Author Topic: 2007 Norge high beam relay buzzing  (Read 1077 times)
Offline Kaladin
« on: September 02, 2023, 04:29:38 PM »
My high beam has been non-functional.  After trouble shooting for some weeks I dug out the relay and replaced it.
This causes the high beam to work, but the dang relay is buzzing when the light is turned on.  Might be why
the old relay passed away.
Any ideas?
mark
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be.  And when you find it you discover "that's where it should have been."
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Re: 2007 Norge high beam relay buzzing
« Reply #1 on: September 02, 2023, 07:57:25 PM »
You might want to pull your dash and check the bulb wiring, There was an update for wiring sleeves like protection on the wires. Was done at dealerships when bike was new. We were to fix them when bikes came in for a service.
Offline Kaladin
« Reply #2 on: September 04, 2023, 12:15:56 PM »
So I swapped out the relay and it started buzzing when the high beam was on.  It stopped buzzing, but now the disconnected ECU symbol is showing and the red triangle of pain.  What wiring to the bulbs needs to be checked?  Could there be a possibility of a short?
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
« Reply #3 on: September 04, 2023, 12:58:36 PM »
From memory  :rolleyes: when it blew fuses, you could turn on the high beams and continue on until you could replace the wiring. There were shielded pigtails that needed to be installed on the low beams.
That doesn't sound like your problem, though. Someone with more experience than me should be along shortly..
« Reply #4 on: September 04, 2023, 01:56:44 PM »
ECU disconnect is what you get when loosing ground.
Got software? Might show a code.
« Last Edit: September 04, 2023, 02:08:17 PM by guzzisteve »
Offline Kaladin
« Reply #5 on: September 04, 2023, 02:17:18 PM »
That makes sense.  Where are the opportunities to lose ground?
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Offline Kaladin
« Reply #6 on: September 04, 2023, 02:33:44 PM »
I found that Fuse D was blown.  Replaced it and now everything seems to be working properly.   It doesn't satisfy my physicist's need to find cause and effect, but I am open to miracles.
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
« Reply #7 on: September 04, 2023, 03:18:10 PM »
Don't entertain idea of why fuse blew. You fixed it, that's enough. May have been just bad fuse.
« Reply #8 on: September 04, 2023, 04:51:55 PM »
I *hate* that, too. I'd carry a spare.
and
go through the complete electrical system with Caig DeOxit. You'll be glad you did.  :smiley:
Offline Kaladin
« Reply #9 on: September 05, 2023, 11:35:16 AM »
Great idea, I was using butane yesterday, and I need something with more oomph.
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
