Author Topic: 850T won’t run on left side  (Read 1656 times)
Offline NCAmother
« on: September 06, 2023, 06:57:16 PM »
Hi all, I just rebuilt the engine for my 850T. LeMans pistons and heads in new gilardino 950cc cylinders. The bike had been in a shed for 30 years.  I’m running a new Sachse ignition, and new keihin 39mm carbs.  I also get 155 psi compression.  The bike will start, on the first try, and runs strong only on the right side.  The left cylinder runs cool to the touch.  Tested the bike, and there is spark in the left cylinder with the bike running.  The compression is good, and the carb seems to be working fine.
I swapped the coils and no difference.  I tried starting the bike on the left cylinder, didn’t start but there was one backfire.   What should I be looking for?  🙏
Howdy
Offline Offcamber1
Re: 850T won’t run on left side
« Reply #1 on: September 06, 2023, 07:20:57 PM »
Since you obviously have both spark and fuel on left side, I would say your right cylinder is firing on the left cylinder's timing, leaving the left side with a wasted spark at the wrong point in the cycle.
Just guessing...
Offline nc43bsa
« Reply #2 on: September 06, 2023, 10:39:12 PM »
^^^^  I ran into the same problem on a Harley Sportster race bike at Roebling Road.
1990 MilleGT
Offline matt franklin
« Reply #3 on: September 07, 2023, 12:14:53 AM »
Did you static time the engine?  After the rebuild, I would be concerned that the timing marks are correctly positioned.
Offline egschade
« Reply #4 on: September 07, 2023, 05:47:10 AM »
Try changing the plug. I've had seemingly good ones that spark outside the engine not work when installed. Check the plug wire too.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #5 on: September 07, 2023, 08:14:28 AM »
me too. Easy to change to new plug. Also, is the lead seated into the coil? And the plug end screwed into the lead Nice and tight? Maybe trim back the lead for a fresh connection.
Offline NCAmother
« Reply #6 on: September 10, 2023, 12:19:38 PM »
Just guessing...
Right on the money, I adjusted the rotor and now it fires on both.  Thanks
Howdy
