Author Topic: Guzzi Electric Mystery  (Read 2195 times)
Offline Rebochi
« on: September 07, 2023, 11:14:45 AM »
     My 1200S/Griso bike has developed a electrical problem. Stater doesn't engage when the button is pushed and I get a pair of error codes, ECU error and Dash error. No obvious damage to the wiring harness, horn, signals , brake lights work, dash powers up and seems to go through the functions. My SWAG is wiring harness, any ideas?
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
Offline RinkRat II
  • Lake Powell AZ
Re: Guzzi Electric Mystery
« Reply #1 on: September 07, 2023, 11:23:38 AM »
     There is no magic answer. Start at the battery, check voltage. Move to the fuses and relays and check the connections there, move to the wiring harness and check for loose or corroded terminals. Kill switch and handlebar connections........ ...
     Paul B :boozing:
« Reply #2 on: September 07, 2023, 11:56:58 AM »
Do a search for StarterInteruptus
Online moto
  • Potrebbe andare peggio, potrebbe piovere!
« Reply #3 on: September 07, 2023, 08:03:40 PM »
Since the dash communicates to the ECU (over a Canbus connection), and since I remember some problems having to do with poor seating of the ECU connector, I'd look there first, carefully. The ECU also controls what happens when the starter button is pushed. The ECU is the common factor in your symptoms, but actual ECU failures are rare. Oh wait. You didn't say which ECU and dash errors you got. THAT could help.
850 T-3
Griso 1100 corretto
« Reply #4 on: September 07, 2023, 10:29:51 PM »
Try a different battery or some jumper cables. The ECU needs to see perfect voltage.
https://wildguzzi.com/forum/index.php?topic=117948.0
Offline MotoGuzzi750
« Reply #5 on: September 07, 2023, 10:42:36 PM »
How old is the battery ? Is it on battery tender when not in use ?
In my ( limited ) experience, fresh battery / properly charged battery solved a lot of pain/problems, so would highly recommend checking on battery age/recharge/replace first.
My Bikes:
2004 Breva 750 IE
2006 Kawasaki ZX12R
2012(?) Grisso 1200 SE <- (thinking of selling)
Offline Rebochi
« Reply #6 on: September 07, 2023, 11:21:42 PM »
   Defiantly not startus interuptus, Had that with the stock motor and wiring harness.  With startus interuptus the resistance through the safety switches and harness limits the current to less than is needed to pull in the starter solenoid, there is no voltage to the starter solenoid and the ignition . Plus this has a Griso wiring harness, not a candidate for startus interuptus.
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
Offline Rebochi
« Reply #7 on: September 07, 2023, 11:24:41 PM »
The battery is new and is on a battery tender. The voltage reading on the dash ranges from 12.00 V to 12.8 Volts just sitting there, seems to indicate a crappy connection
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
Offline chuck peterson
« Reply #8 on: September 09, 2023, 07:41:27 AM »
Needs a steady 12.6 volts or more without the key on. What’s it do with key on?
Something not right if your reading is fluctuating at the dash
Keep a voltmeter attached at the battery whilst (!?) cranking the motor. If the voltage drops off a cliff to below 8-9-10 it’s likely battery death
Clean both ends of the ground cable…load test the battery at an auto parts…connect a known good battery..
I had an AGM go to 500 millivolts overnight after 10 years of service, with no signs beforehand
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Rebochi
« Reply #9 on: September 30, 2023, 04:27:55 PM »
   Update on the Electrical problem. The wiring harness was replaced a now the bike starts and runs with the dash disconnected. With the dash hooked up it demands that I enter the code. The Griso service code is 12425 and the default user code is 00000, none of which works. Still getting incorrect code message. Any ideas on finding out how to extract the user code? My other Frankenstein CARC bike which was put together by the same shop  has a user code of other than 00000.
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
« Reply #10 on: September 30, 2023, 04:38:01 PM »
You can send it to the Netherlands and they have software to fix it to all 0's Place called Carmo or some such name.
You could buy a new dash.
Do a search this has been discussed extensively.
« Last Edit: September 30, 2023, 04:40:03 PM by guzzisteve »
Offline Rebochi
« Reply #11 on: November 20, 2023, 01:46:03 PM »
   Update on the everchanging problem. I had Carmo in Holland recover the User code, the bike is back together and running. It now requires that the user code be entered every start up. I attempted to initialize the keys and made it as far as inserting the first key. Now it is stuck on insert the first key. after disconnecting the battery it returns to the same screen. The resistance through the antennae is 14.7 ohms, battery voltage is 12.7 VDC any thoughts on this?
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
Offline Vagrant
« Reply #12 on: November 20, 2023, 01:49:49 PM »
FWIW, there was a massive write up on Guzzi tech about this a while back.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2023 V85 Guardian of the Oreo's
Online moto
« Reply #13 on: November 20, 2023, 01:53:35 PM »
... I attempted to initialize the keys and made it as far as inserting the first key. Now it is stuck on insert the first key....
Does it react at all to the key being inserted? Did you try the other key?
850 T-3
Griso 1100 corretto
Offline Rebochi
« Reply #14 on: November 20, 2023, 03:00:40 PM »
  It does not react, screen says Insert first Key
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
Online moto
« Reply #15 on: November 20, 2023, 09:02:52 PM »
I wonder if the antenna that detects and reads a code from the key has become disconnected. It forms a sort of semicircle around the lock, I recall, and you can look for it and try to plug it back in or improve its seating in the plug.
The fact that you get no reaction at all is a good clue, even if my offhand guess about the antenna is wrong. It might require more thinking than I can muster right now to figure the puzzle out.
850 T-3
Griso 1100 corretto
Offline Rebochi
« Reply #16 on: November 21, 2023, 01:11:06 PM »
Found the problem, I had swapped connector 12 with 14.  Works now
1200 GS
1200 Sport
1100 Griso
2003 Rosso Corsa
Ducati Multistrada
Indian FTR 1200
« Reply #17 on: November 21, 2023, 05:00:33 PM »
Congrats Good Find. Retrace what you did.
« Reply #18 on: November 22, 2023, 03:59:40 AM »
As soon as I saw "Guzzi Electric Mystery" I thought, what's new, here goes. It didn't disappoint. :grin:
Pleased you got it sorted.
