Author Topic: Fork-Steering Stopper on Frame  (Read 1218 times)
Offline Groover
    • Scooteropolis
« on: October 05, 2023, 07:57:48 AM »
Hello, the fork-steering stopper on frame broke off on my G5. Until fixed properly (frame or at least forks off to weld somewhere around here), is there an easy temporary solution that I can do (or buy) that will prevent the forks from hitting the tank when parking and such? Was thinking of leveraging the engine guards / crash bar somehow.
Thank you
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Online John A
Re: Fork-Steering Stopper on Frame
« Reply #1 on: October 05, 2023, 09:40:16 AM »
It’s usually the aluminum nubs on the triple tree that get sheared off by the frame stop because the frame stop is too far away. I bend the frame stop as close to the base of the stops as possible. If the frame part is broken off maybe you can make one that bolts to the two socket head bolts that are at the top where the frame down tubes meet. Or maybe clamp some rubber bumpers on the crash bars that will hit on the fork legs. When they went to 45mm forks, they are so strong that it deforms the lower bearing mount in the neck before the forks bend. I’ve repaired them by cutting off the bearing cup and welding on a new one I made on the lathe. Welding on a new piece for a frame stop should be able to be done fairly easily after you take a bunch of stuff off.
Offline Groover
    • Scooteropolis
« Reply #2 on: October 05, 2023, 11:26:02 AM »
Thank you Jon, I'll try something like that. The tab on the frame is completely gone..
1980 Vespa SI Moped
Paul_Tim
« Reply #3 on: October 06, 2023, 08:01:24 AM »
When I built a cafe racer, in the long ago past, it was possible to buy a clamp that was fitted round the fork leg and had a pin that stuck out so it could be positioned to hit the headstock when on full lock, not seen any for years but reasonably simple to machine something up to do the job.
Offline Groover
    • Scooteropolis
« Reply #4 on: October 06, 2023, 02:44:30 PM »
Used HVAC grade copper line insulation on the upper forks, does the job for now.  :azn:
« Last Edit: October 06, 2023, 02:50:15 PM by Groover »
1980 Vespa SI Moped
« Reply #5 on: October 06, 2023, 04:09:41 PM »
That is what I have on my LM3 clip on's that are on the Sport 1100 forks. I had to bend the stop away from the big knob on lower tripple tree for a steering stabilizer. My tank doesn't get scratched w/no stop.  I can bolt a stop to the old one, once I make one.
I also thought of making one that comes off the x member your crash bars are on.
« Last Edit: October 06, 2023, 04:17:53 PM by guzzisteve »
